Add a color coding option to Home Assistant Automation/Script/Scene builder UI
Sometimes when building long and/or complicated scripts/automations/etc in the UI, I find it difficult to quickly discover where I’m at since everything is pretty monochromatic; especially when scrolling fast. I know I can minimize sections, but sometimes that’s just not a feasible solution or I have to do more scrolling to get to arrow. I also do use the yaml option, but other than custom stuff you can’t really do in the UI, I like UI better.
It could be very beneficial for building these in the UI to be able to set each block as a different color, much like you are able to do in node red:
You could set colors to mark different levels where you can easily distinguish between a parent or child level, and/or set up multiple colors within the same level, such as a Choose with several Options where you want to tell easily what option you’re in.
Anyone else think this is a good idea???
Hello Bob,
This appears to be a Frontend Related Feature Request as it is asking for changes to Frontend Menus, Dashboards, or Sections.
These Feature Requests are handled in a different system, and will not be seen by the right people if posted in the HA forums.
Please add your Feature Request into GitHub here:
home-assistant/frontend Other Feature Requests · Discussions · GitHub.
See more info about Feature Requests HERE
