building on the radio setup in Chromecast Radio with station and player selection by @Bob_NL, I’ve expanded a bit and have wakeup and sleep radios. to cut it short, I have a few sensors like below, that use templates with nested templates…
wakeup_radio_state:
friendly_name: Wakeup radio state
entity_id:
- sensor.wakeup_radio
- sensor.wakeup_radio_state
- sensor.wakeup_radio_volume
- input_select.radio_station_wakeup
- input_select.wakeup_radio
- timer.increase_volume_delay
value_template: >
{{states(states('sensor.wakeup_radio'))}}
icon_template: >
{% set state = states('sensor.wakeup_radio_state') %}
{% if state == 'playing' %} mdi:play
{% elif state == 'stopped' %} mdi:stop
{% elif state == 'paused' %} mdi:pause
{% elif state == 'off' %} mdi:power-off
{% else %} mdi:play-pause
{% endif %}
and
wakeup_radio_volume:
friendly_name: Wakeup radio volume
entity_id:
- input_boolean.wakeup_radio
- input_boolean.snooze
value_template: >
{{state_attr(states('sensor.wakeup_radio'),'volume_level')|float|round(2) }}
use the state of:
wakeup_radio:
value_template: >
{% set state = states('input_select.wakeup_radio') %}
{% if state in ['Woonkamer','Hobbykamer','Hall', 'Master bedroom'] %} media_player.googlehome_{{(state)|lower|replace(' ','_')}}
{% elif state == 'Gym' %} media_player.chromecastaudio_gym
{% else %} group.broadcast
{% endif %}
the state sensor needs the many entity_ids to change state accordingly, and I have it working as it should now finally, thanks to @lolouk44 who taught me the nesting was possible in the first place…
I now have a new challenge: When I say ‘hey Google, stop’ to my playing media_player it won’t change the state of the above sensors… Now how could I add that to the triggering entity_id’s of the sensor? Or isn’t this possible.
