Add latest model of Switchbot Lock Pro
Set it up without any problems, but I’m missing the night latch function. Is there any chance to implement this ? Also, the integration seems to don’t know if it’s in lock state or not e.g. when using the Switch Bot App to lock / unlock.
Great work so far, hopefully it’ll be even better soon :+1::wink:
Maybe install a bluetooth proxy near the lock?
For correctly support nightlatch it would be helpful if people using this feature can post their lock’s ADV from HA debug log.
Commands for it are already in the code but the detection if the feature is on not working.
Will be happy to provide the needed logs in 2 weeks after my vacation. Thanks for now!
I couldn’t see the lock after updating core to 2024.7.1 initially. After disabling passive scanning in bluetooth settings the lock appeared! Finally!
-65 to -85db should be good enough. It’s not about the bluetooth connection. Other bluetooth devices in that location work well.
My signal strenght is about the same and my server is a meter (~3 feet) from the lock so yes, it’s not about the connection and bluetooth proxy would have no effect.
Tried a different normal USB Blutooth Adapter and it works now without any problems. Used the rpi built in bluetooth previously, which didn’t work at all. I got the SABRENT BT-UB40 (CSR8510A10) mentioned in the bluetooth documentation as working. Distance from HA to Lock is about 2,5m with a wall inbetween.
Binary sensor is still not working, showing state “closed” no matter what
Did this and its working perfect with instant response time!
Will I definitely have to create a new SwitchBot account in order to get the encryption key? Or will I be able to retrieve the key using the “pySwitchbot” mentioned in
SwitchBot Bluetooth - Home Assistant ?
If I can use the python script, can someone give a hint how that is used? What MAC address is to be used? IIRC the lock pro is not in my wifi, just connected to the Hub mini? So I guess I’ll have to use the BT MAC address? And I guess the python script has to be run on a device that has bluetooth (maybeon on my home assistant Pi)?
Thanks in advance :slight_smile:
Same here, get used to do some automation with Lock binar sensor, but for Pro model still not working at all
Oh ok, alomst working perfect. If I unlock manually it doesn’t detect in HA. But it seems to work going from Unlock to locked though…
Connected the Lock Pro over Bluetooth and it works fine, but if I unlock it from the switchbot app the status in HA still shows as locked.
If I unlock using HA then the status shows as unlocked, if I then lock it using the switchbot app then the HA status updates.
I don’t plan on using the switchbot app, I still need to confirm If HA updates when manually locked/unlocked.
The old lock was synced in all scenarios
Lock states are slightly shifted in Lock Pro ADV. This should be fix in 2024.7.3.
2024.7.3 has fixed the previous issues. The last issue i have is that door sensor always says it’s open in HA and Switchbot app.
I’m pretty confident it was working, but a newer firmware broke something. I even took the magnet off and tried putting it right next to the lock and the status still shows open.
Tried removing the batteries, nothing works.
Edit: it’s working now after recalibration
Amazing, now even my nightlatch lock works fine after upgrading. Much appreciated!
I upgraded to 2024.7.3 and lock firmware to 1.19 (from memory, I mean the version from a week ago).
What services do you see in HA? I still only have lock and unlock, which also still opens the door😭
Did you reset or reinstall anything?
I’m hoping for lock, unlock and open to be separate commands.
I currently still have the lock connected via Matter, which also works perfectly.
There are currently only two open/close statuses via Matter.
There seem to be a few more entities via Bluetooth, so I have also ordered an external Bluetooth adapter.
One thing I haven’t found yet, however, is the following - and as far as I can see there is still no solution:
I have an automation that closes the door in the evening.
This should also be triggered in the morning.
As I have a door latch, it would also open the door latch so that the door is really open.
Is there already a solution for just opening the door without the door latch?
Bluetooth or Matter?
With latest Home Assistant version 2024.7.3 I now have 3 distinct locking and unlocking options via the Switchbot bluetooth integration for my German lock: lock, unlock and open. Matter still only provides lock and unlock whereas unlock would always pull the latch and open my door (no option to just unlock the lock without opening the door). My lock also has firmware version as 1.19. I didn’t reset or re-install anything and neither recalibrated the lock yet, just applied normal updates.
