finity
1
The old zwave 1.4 integration supplied the “node_id” of the zwave device in the attributes of the child entities.
Right now you have to click thru each device in the devices section to find which device/entity is associated with each node.
Before you could simply go to the states page and filter on “node_id” in the attributes to list all zwave entities with their associated nodes.
It would definitely be more user friendly if they were included in the entity attributes as well.
petro
(Petro)
2
For the time being, just output the list in developer tools → template editor
{% set ns = namespace(devices=[]) %}
{%- for device_id in states | map(attribute='entity_id') | map('device_id') | unique | reject('eq', none) %}
{%- set identifiers = device_attr(device_id, 'identifiers') | list | selectattr('0', 'eq', 'zwave_js') | selectattr('1', 'search', '^([0-9]+)-([0-9]+)$') | list | first | default %}
{%- if identifiers %}
{%- set node = identifiers[-1].split('-')[-1] | int %}
{%- set ns.devices = ns.devices + [(node, device_entities(device_id))] %}
{%- endif %}
{%- endfor %}
{%- for node, entities in ns.devices | sort(attribute='0') %}
{{ node }}:
{%- for entity in entities %}
- {{ entity }}
{%- endfor %}
{% endfor %}
