Add-on Store stuck on loading (spinning circle)
Hi everyone,
Just started my journey on Home Assistant. I’ve got a Raspberry Pi 4 Model B 4GB, and have followed the instructions on https://home-assistant.io/getting-started/
I’ve now got it all set up and running but when I go to the Add-On Store, it’s just stuck on the loading / spinning circle. Does it typically take a long time to load on first installation? It’s been spinning for about 30mins - see attached photo.
I’ve had a quick look in the community and on Google, but can’t seem to find anyone else with the same issue - no errors are produced.
Other info that may help:
  • It’s currently connected via ethernet
  • Raspberry Pi and SD card are completely new
  • Tried setting up wifi during installation via USB method but didn’t work
  • During installation I unplugged and replugged power to the Raspberry Pi two separate times due to wifi not working properly, no spare power ports…
  • I’ve tried restarting the server
  • I’m located in New Zealand
Key questions:
  • does it typically take a while to load the add on store, especially after a new install, or is the indicative of something not working as expected?
  • what are my options for troubleshooting, or is it easier to start from scratch again?
  • if starting from scratch, is there any documentation that I could be referred to please?
Thanks!
Regards,
Chom
Click the 3 dots then hit reload, it that does not help there will be logs in the system tab
Thank you!!!
I’ve got almost identical situation.
Brand new RPi4/4GB with new 32GB SD card. Fresh installation of hassio 2020.12.7
Unfortunately, “reload” trick didn’t work for me.
What’s interesting is that in “repositories” I have " No repositories". I’m not sure if it’s OK. And I do not know how to add “default” repo.
Also, in system logs I can see
20-12-29 16:28:07 ERROR (MainThread) [supervisor.jobs] Unhandled exception: 'NoneType' object has no attribute 'active_branch'
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 61, in wrapper
    return await self._method(*args, **kwargs)
  File "/usr/src/supervisor/supervisor/store/git.py", line 143, in pull
    branch = self.repo.active_branch.name
AttributeError: 'NoneType' object has no attribute 'active_branch'
20-12-29 16:28:07 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-851' coro=<Repository.update() done, defined at /usr/src/supervisor/supervisor/store/repository.py:101> exception=JobException()>
  File "/usr/src/supervisor/supervisor/store/repository.py", line 105, in update
    await self.git.pull()
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 67, in wrapper
    raise JobException() from err
supervisor.exceptions.JobException
Regards,
K.
Hmmm, problem solved by… reboot. It looks like installation wasn’t finished properly, but have no idea why :-\
Ctrl + F5 worked for me. If not, reboot and Ctrl + F5 seems to be the standard troubleshooting approach.
This helps for my case:
docker stop hassio_supervisor
docker start hassio_supervisor
