tufand
(Tufan Deveci)
1
hi,
some add-ons for example esphome need container limit cpus setting prevent compile process has a froze crash.
I solve the problem by manually setting it, but it is not a permanent solution because the add-ons re-create every time the system is started.
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
2
If you think it’s a good idea, you should vote for it. I did…
Suggested Reading:
Feature Request Guidelines
- Feature Requests - Home Assistant Community.
