I had the same issue, but hard reset (unplugging RPi from power) did the trick! Hopefully this will help others.
Great many thanks. Exactly this solution is working!!. How easy
I had the same issue upgrading from pi3 to x86 (both hass os). Add-ons displayed as not started despite supervisor logs showing a lot of âXXX already started!â warnings. Did a partial restore (add-ons only) from the same snapshot used for the initial restore followed by a host reboot and everything is working now. Iâm not sure if the partial restore was necessary. Thanks to this thread to help me resolve w/o rebuilding from scratch!
I had the same problem, that after the snapshot restore the addons no longer worked. For me, the solution was quite simple.
I restarted the host, after everything had booted up I only restarted the Pi via âRestartâ, then everything worked again.
Homematic also found the devices again.
System Respberry Pi 3, second system Raspberry Pi 4 with 4GB
++ migrated to a new eMMC Module this morning and the hard reboot (and some patience) resulted in not having to do anything crazy
Migrated from HAOS VM to Pi 4 - hard reboot solved the issue. Migrated HACS as well.
Hard reboot solved the issue in 2022.9.5. I had to restore from a snapshot and the add ons couldnât be started. Thanks!
For anyone that cannot find the hard reboot, its under Settings > System > Hardware > 3 dots at the top > Reboot Host
(Restart from the Developer options page did not fix the add-ons not starting, Reboot Host did)
This resolved the Add-ons not starting after restore. Many thanks for all of the suggestions!!
Not sure why this option is hidden under 2000 clicks, took me 10 minutes to find a simple reboot, but there we are, better option to just tanking the power to RPi.
Thank you!
I just restored from backup and had the add on issue. Power cycling fixed it.
Z wave network is incredibly slow but I am hoping a heal + waiting overnight will improve things
Absolutely, it worked for me.
Can confirm, was in the same boat.
Migrated from RPi3 to RPi4 and did a full restore - add ons showed they were working in the logs but would not actually turn on.
Instead of wiping everything and going through the restore process with partial backups, I just did a hard restart (not through UI) and everything was back!
Thanks for the great advice everyone who suggested it!
When in doubt⌠Turn it off and back on againâŚ
Thank you very much, this helped me a lot!
This worked for me too. Thanks.
Simply reboot the os solve the problem
This worked for me too. Obviously there is some difference between a soft restart and a complete hardware restart.
Restart only restarts the HA container.
Host reboot pulls everything down, reboots and loads everything up.
Ok, thanks for making that distinction clear.
I eneded up here because I googled âhome assistant restore addons greyed outâ
Even with the latest 2022.12.0 this is still an issue
I went from Pi4 to a NUC - a hard reboot cured most of the issue but the File Editor and Home Assistant Google drive backup were still grey and the HACS icon was missing
I removed File Editor and added Studio code server and all returned to normal
worked for me. Thanks a lot
worked for me like a charm, thanks!!
