Hi @philwilldo,
Thanks - for some reason FGLair decided to go nuts, I removed the A/C from FGLair and reconnected - all good now.
Thanks Simon
Hi @philwilldo,
Thanks Simon
Hi @Marco_Simon,
Itâs a bit flaky since 0.96 of hass.io @philwilldo made some code changes which I think are pending merge into the master.
Have a read of the post from Aug 4 2019 - some good information there.
regards Simon
Hi @philwilldo,
Iâve finally loaded the code changes you made back on Aug 14 - works great thanks.
I think this is the processâŚ
Pull the code from https://github.com/xerxes87/pyfujitsu_for_homeassistant as opposed to the original repo and follow instructions in same locale.
Youâll need some additional files from https://github.com/xerxes87/pyfujitseu/releases/tag/0.9.3.0 put these into config\deps\lib\python3.7\site-packages\pyfujitsu
Good luck.
Iâve removed the original files from <custom_components/fujitsu_general_heatpump>
And replaced it with the files from https://github.com/xerxes87/pyfujitsu_for_homeassistant
<config/deps> was empty folder
I created <config\deps\lib\python3.7\site-packages\pyfujitsu>
and put this files in https://github.com/xerxes87/pyfujitseu/releases/tag/0.9.2.9
Put the next info in confguration.yaml
climate:
the pass and username are in the secretfile
Reboot home assistant, and got the next error:
Wed Oct 09 2019 16:42:54 GMT+0200 (Midden-Europese zomertijd)
Error while setting up platform fujitsu_general_heatpump
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/config/custom_components/fujitsu_general_heatpump/climate.py", line 77, in setup_platform
if not fglairapi._authenticate():
File "/config/deps/lib/python3.7/site-packages/pyfujitsu/api.py", line 118, in _authenticate
f = open(self._ACCESS_TOKEN_FILE, "w")
TypeError: expected str, bytes or os.PathLike object, not NoneType
created token.txt in
added --> tokenpath: âtoken.txtâ in configuration.yaml
Rebooted.
and the error changed to:
Wed Oct 09 2019 17:09:41 GMT+0200 (Midden-Europese zomertijd)
return fut.result()
File "/config/custom_components/fujitsu_general_heatpump/climate.py", line 84, in setup_platform
add_entities(FujitsuClimate(fglairapi, dsn) for dsn in devices)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 199, in _schedule_add_entities
list(new_entities),
File "/config/custom_components/fujitsu_general_heatpump/climate.py", line 84, in <genexpr>
File "/config/custom_components/fujitsu_general_heatpump/climate.py", line 106, in __init__
self._swing_mode = self.swing_mode
File "/config/custom_components/fujitsu_general_heatpump/climate.py", line 195, in swing_mode
return self._fujitsu_device.get_swing_mode_desc()
File "/config/deps/lib/python3.7/site-packages/pyfujitsu/splitAC.py", line 145, in get_swing_mode_desc
if self.af_vertical_direction['value'] is not None:
TypeError: 'NoneType' object is not subscriptable
Hi @Marco_Simon,
Great to have you in the Fujitsu team.
Seems like you used release 0.9.2.9. Please use current one from here: https://github.com/xerxes87/pyfujitseu/releases/tag/0.9.3.0
Some Fujitsu AC models (like yours) seem to have different swing types.
BR
Ah yes @philwilldo
I corrected my post to keep it all in one place - thanks for pointing that out
cheers Simon
I changed the files with the one u mentioned.
in dev. tools the error was gone but still no components added.
When looking at the log file the next error was found
ERROR (SyncWorker_4) [homeassistant.loader] Error parsing manifest.json file at /config/custom_components/fujitsu_general_heatpump/manifest.json: Expecting value: line 9 column 5 (char 307)
the manifest.json:
"domain": "https://github.com/Mmodarre/pyfujitsu_for_homeassistant",
"name": "fujitsu_general_heatpump",
"documentation": "https://github.com/Mmodarre/pyfujitsu_for_homeassistant/blob/95e3ba879214aa9abf70979185ae189776ba4846/README.md",
"dependencies": [],
"codeowners": [
"@Mmodarre",
"@xerxes87",
"requirements": ["pyfujitsu==0.9.0"],
"homeassistant": "0.96.0"
I donât see the error
Hi @Marco_Simon,
I did an update on manifest.json. Find it here: https://github.com/xerxes87/pyfujitsu_for_homeassistant
Hopefully it will work now.
Today i got a chance to test the new file.
It needed a hard reboot,
But then âŚyes⌠iâve got it up and running
Thank you for your kind and patient help
Still not 100% working.
Iâve got the climate component for the bedroom airco.
If i change the name in the fglair app after refresh it changes in hassio.
I can see the graph of the set temp and it changes if i turn on the airco by the fglair app.
And with a little bit of patience also by the component.
Fanmodes doesnât seem to work, setting the fan to high doesnât change the fan settings.
I donât use this that often yet, so doesnât bother me so far.
But i havenât yet found a way to turn the airco on or off bij the component.
And this is a feature i really do like to have.
Please provide a screenshot of your componentâs detail view. Attached is mine, action is set to off.
You seem to have a different model, where fan and swing modes are handled in an other way. Fixing this would need further API investigation from your side.
The delay is usual behavior, because the component regularly pulls the status.
When i put the climate component to cool.
Nothing hapens. In fglair app it states airco is on, but in fact the airco is off.
When i turn the airco on by the fglair app. Then set the airco component to heat, nothing changes but i also donât get a error message
When i press swingmodus i get a error.
In the log it says:
Thu Oct 24 2019 13:30:53 GMT+0200 (Midden-Europese zomertijd)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1233, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1258, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
self._platforms.values(), func, call, service_name, required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 348, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 370, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 423, in async_set_swing_mode
await self.hass.async_add_executor_job(self.set_swing_mode, swing_mode)
File "/config/custom_components/fujitsu_general_heatpump/climate.py", line 204, in set_swing_mode
self._fujitsu_device.changeSwingMode(swing_mode)
File "/config/deps/lib/python3.7/site-packages/pyfujitsu/splitAC.py", line 122, in changeSwingMode
self.af_vertical_direction = 0
File "/config/deps/lib/python3.7/site-packages/pyfujitsu/splitAC.py", line 335, in af_vertical_direction
self._api._set_device_property(self.af_vertical_direction['key'],properties)
I see your AC has a lot more functionality than mine. Still, I ran into the same issue you described last week after an electricity outage. After a lot of trying, I was able to fix it today. I just disconnected my AC from the power for 1 minute and connected it again.
Afterwards everything worked again.
BTW, I added a lot of Debug logs. You can activate them by setting:
custom_components.fujitsu_general_heatpump: debug
custom_components.fujitsu_general_heatpump.climate: debug
In the logger.
Try to avoid playing around with swing modus for now. Just set a valid one with your remote and donât touch it within Home Assistant.
All new versions stored locally on my Pi.
But still only error: âPlatform error climate.fujitsu_general_heatpump - Integration âfujitsu_general_heatpumpâ not found.â
It drives me nuts
All help appreciatedâŚ
Hi @vandenbogerd,
Have you followed the notes from @qwackers :
Add Support for Fujitsu wireless Air Conditioning control app - FGLair - #84 by qwackers
How is your file structure in your custom_components/fujitsu_general_heatpump folder
Have you enabled logging, described here:
Hi @philwilldo
Logger activated. Not going further than: â2019-11-11 09:34:42 ERROR (MainThread) [homeassistant.components.hassio] Platform error climate.fujitsu_general_heatpump - Integration âfujitsu_general_heatpumpâ not found.â
Yes I followed the notes from @qwackers.
The filestructure is as followed:
I had to work on the electricity so put the power down for several minutes.
But still canât turn the airco on with the climate unit.
Iâve activated the logger so see what turns out of that.
Hey All,
Anyone having issues with Home Assistant controlling their Fujitsu in the last week?
My hass install has been rock solid for months right up to a week ago coinciding with an update to the FGLAir app.
Logs throwing no errors, only evidence of not working is the A/C does not turn off or on. FGLAir app works perfectlyâŚ
Howâs the experience for others?
Thanks Simon
For me it isnât working at all.
Not even status updates when i use the remote control
