Right now the supported vacuums are the XIAOMI Vacuums but there are viomi ones that need a different protocol.
with the miiocli instead of miiocli vacuum you just say miiocli viomivacuum.
root@odroid:~# miiocli viomivacuum
Usage: miiocli viomivacuum [OPTIONS] COMMAND [ARGS]...
Options:
--ip TEXT [required]
--token TEXT [required]
--help Show this message and exit.
Commands:
add_timer Not implemented yet.
carpet_mode Set the carpet mode.
clean_mode Set the cleaning mode.
consumable_status Return information about consumables.
delete_map Delete map.
delete_timer Not implemented yet.
dnd_status Returns do-not-disturb status.
get_current_position Return the current position.
get_maps Return map list.
get_rooms Return room ids and names.
get_scheduled_cleanup Not implemented yet.
home Return to home.
info Get miIO protocol information from the device.
led Switch the button leds on or off.
move Manual movement.
pause Pause cleaning.
raw_command Send a raw command to the device.
rename_map Rename map.
set_dnd Set do-not-disturb.
set_edge Vacuum along edges.
set_fan_speed Set fanspeed [silent, standard, medium, turbo].
set_language Set the device's audio language.
set_map Change current map.
set_remember_map Set remember map state.
set_repeat Set or Unset repeat mode (Secondary cleanup).
set_route_pattern Set the mop route pattern.
set_sound_volume Switch the voice on or off.
set_water_grade Set water grade.
start Start cleaning.
start_with_room Start cleaning specific rooms.
status Retrieve properties.
stop Validate that Stop cleaning.
test_properties Helper to test device properties.
I tested it with my vacuum and it works. But since my HA is in a docker container I can’t just exec scripts on my bash.
Is there a way to support that protocol and add this vacuum?
