I want an option to access my Rpi’s in my home network via a SSH server running on Homeassistant.
Looks like webssh2 can solve my problem.
My plan is to make this available on a domain via Nginx and then monitor/update the Rpi’s remotely.
Have you tried this?
I think this addon is to access Homeassistant instance using SSH.
My requirement is to access other RPi which are locally available to access remotely using Webssh2.
You mean like this?
That’s me using SSH to log into one of my pi3 boards from the home assistant addon.
Thanks, I was not aware I can do SSH from this terminal.
