Feeling silly now!
Thanks for that, Iāve installed bodymiscale as suggested and itās working perfectly.
Thanks @Ernst!
like @Eoin Iām currently using ESPHome and also in combination wiht the BodyMiscal custom component.
The benefit of using Xiaomi BLE rather than ESPHome is that the scaleās signal will be picked up by any ESPHome BLE device rather than the single ESPHome devices on which Iāve configured it currently using ESPHome.
However Iām wondering whether using Xiaomi BLE I can replicate this functionality I have in ESPHome?
What the below code does:
- checks whether I have disabled logging the weight or not (variable āscaleconnectionā, which is toggled by scanning an NFC tag that Iāve attached to the scale).
- Based on the weight identifies whether itās my, my partner or one of the kids and assigns the measurements to the right variables.
- notifies that a measurement was done (event āscaleusedā) so that my smart speaker can announce the weight change or for example that the measurement wasnāt logged because scaleconnection is switched off.
- platform: xiaomi_miscale
mac_address: '53:FD:19:31:40:60'
weight:
name: "Xiaomi Mi Scale Weight"
on_value:
then:
- lambda: |-
if (id(scaleconnection).state) {
if (id(weight_miscale).state >= 76 && id(weight_miscale).state <= 87.00) {
return id(weight_john).publish_state(x);}
else if (id(weight_miscale).state >= 64.00 && id(weight_miscale).state <= 75.99) {
return id(weight_jane).publish_state(x);}
else if (id(weight_miscale).state >= 30.01 && id(weight_miscale).state <= 40.00) {
return id(weight_son).publish_state(x);}
else if (id(weight_miscale).state >= 21.00 && id(weight_miscale).state <= 30.00) {
return id(weight_daughter).publish_state(x);};
else {
impedance:
name: "Xiaomi Mi Scale Impedance"
on_value:
then:
- lambda: |-
return id(impedance_john).publish_state(x);}
return id(impedance_jane).publish_state(x);}
return id(impedance_son).publish_state(x);}
return id(impedance_daughter).publish_state(x);}
- homeassistant.event:
event: esphome.scaleused
I am using the new integration via a Shelly relay. It works well and can do your first two bullets and mostly the third one as well (I am using AppDaemon for that but it could work with Home Assistant scripts as well).
However, there is an issue with the scaleused
event. In particular, when the measurement is exactly the same as before, the sensor does not update and thus the speaker does not announce anything. This is a surprisingly frequent issue.
I think using force_update
for the sensor could help with my issue, or the integration itself could emit an event.
I was wondering how a relay comes into play for the Xiaomi scale. It took me a while to understand that the Shelly relay also has Bluetooth and can act as a gateway
Where exactly do you put the logic that I currently do in ESPHome when using the Xiaomi BLE integration.
Iām not sure why but yes I have the same experience as you that it doesnāt work when the measurement is identical to the previous one. I donāt consider this an important problem so never really tried to solve it.
The Xiaomi BLE integration creates a mass sensor with the last measurement.
I would then make a trigger-based template sensor for each person, watching the mass sensor state and update itself (only) if the new measurement is within that personās weight range.
(I did not actually do this, my current setup is similar but mostly built in AppDaemon.)
is there any plan to add impedance to the Xiaomi BLE integration?
Impedance is only available for the V2 MiScales. Make sure you wait long enough after weighing, impedance is only send after the weight is stabilized.
need some help here. Mi Scale V2 wont show up in BLE Monitor. Is it required to pair the MiScal with the MiScale App first?
Yes, you need the Zepp Life app once for the initial setup of the Mi Scale. After the initial setup you can safely remove the app from your phone.
Thanks that worked.
2 more question.
- do i need to unpair within bluetooth from the Zepp App before removing it?
- do i need to delete all data from Zepp App before removing it?
Cheers
PX80
No.
No.
After the initial setup of the Mi Scale you can just remove it from your phone or simply donāt use it anymore. Zepp Life is just needed for connecting your scale to your bt network.
but it will be fine to delete the account iāve created with Zepp App, right?
Well, I can not answer you this one. I just left it alone after having finished the initial setup. Doesnāt hurt me anyway
How good is the Bluetooth on that MiScale? Seem i have to move it from bathroom to PC Room to get a signal. other devices in that room reports fine. is there a way to increase/enhance the BT Signal as other devices wor well with my RPi4 BLE
For the Mi Scale 2 I am using ESPHome with Bluetooth Proxy here. Works quite well although the scale is in the 2nd floorās bathroom while the HA device itself is far away on the 1st floor, all concrete walls.
think issue could be due to SSD in my RPi4 see Migrated to PI 4, bad range? (USB3 2.4GHz interference) Ā· Issue #430 Ā· custom-components/ble_monitor Ā· GitHub
Any recommendation for a BT Dongle foir RPi4 ?
Does anyone find solutions for the new Xiaomi Scale S400 yet? My old Scale 2 was out of order so I bought a new Xiaomi S400 Scale but unable to add into HA via BLE, ESPhome, Xiaomi BLE. None of these integrations got broadcast from this scale.
Hereās its information
Try to collect some ble data by enabling debugging in the Bluetooth integration and post the logs here. I can try to add it, if I get some BLE data logs.
Thank you, and sorry for may late response.
Iāll try but actually I donnāt know how to enabling debugging in the Bluetooth integration and getting logs for this.
Iāll try to learn
