Adding Additional Nest Cams - Not showing up
Hi Everyone,
I searched the forums and couldn’t find this exact issue.
I have 3 Nest cams currently installed working great - 1 Nest Hello Doorbell, 2 Nest Hub Max with Cameras.
I have 4 more Outdoor Nest Cams to add to Home Assistant. I’ve installed 2 so far but they are not showing up in the Nest Integration. I was hoping they would be auto-discovered.
I have tried restarting the integration, restarting Home Assistant, etc. to no avail. Also went through the detailed setup from start to finish but couldn’t find any place to bring in new devices.
How can I get this working?
Thanks in advance.
UPDATE: Had no choice but to uninstall the integration and re-add. Works perfectly once this is done.
Did you need to redo the entire process or just remove and readd the integration?
Just remove and re-add the integration.
Yes, this is right. Home assistant can’t get access to the new devices unless you re-authorize home assistant. The simplest way is to just delete and re-add and everything will be back in place.
We could add an option to reauthorize in the future which may seem less scary, and be easier to use, but its really the same thing.
So I have a Nest Outdoor Camera, Nest Thermostat (both show up), and I just purchased and installed the Nest Wired Doorbell 2nd Generation. I removed the Nest integration and added it again but only the Camera and Thermostat show up. Is there something I need to do so that the Doorbell shows up, or is it so new it isn’t detecting it yet… I also went to the nestservices.google.com/partnerconnections and I only see my Camera and Thermostat.
I am having this same problem. I have six cameras which includes the battery 2nd doorbell all working. But the new wired 2nd gen doorbell will not show up. I’ve deleted everything and re-setup the integration but can not get it to show.
@tacogy3 and @redkiwi my impression from Supported Devices  |  Device Access  |  Google Developers is these are not yet supported devices. When they start showing up as available in the partner connections manager and supported by the API, I’m happy to ensure they’ll work in home assistant.
Is this something we will have to re-auth to have show up? Or will it just pop into existence within Home assistant once the access is added?
You don’t need to re-auth, You just go to the site and give access to your existing session, then reload the integration or restart home assistant.
Sweet thanks! how do I give access to the existing session? In the past I have deleted the integration and then redid it to add my new cameras
Check out the nest integration docs and see the first link in troubleshooting. (On mobile, so don’t have it handy)
Thanks, I will take a look.
For future readers of this thread, here are the troubleshooting instructions which include an easy method to add new cameras to an existing integration: Google Nest - Home Assistant
Google’s Partner Connection Manager was the missing piece I needed.
Correct. It’s Work with my case
I have the new Nest Cam Indoor 3rd gen, and I can’t find it in the Google Partner Connection Manager, I can only find my existing Nest Cams and Doorbell.
Any advice on how I should proceed to add it?
Same with me, it looks like the new Google Nest cameras arent publishing in the API :frowning:
Probably takes some time for them to add to API, can open issue on the Nest SDM API forums. Typical Google lol.
Ugh. Same issue here. I replaced my Nest Hello doorbell with the Gen 3 and also installed a new Nest Outdoor Camera in my backyard. Neither appear in the Partner Connections Manager. Is it possible this is the end of even limited access to Nest devices from Home Assistant? Perhaps time to return those devices and buy Reolink or something else?
Good news - google just added support for these to the API. They show up for me and working in home assistant. (both the doorbell and camera)
