yes, as I mentioned in the thread ✔️🆒Argon One Active Cooling Addon - #242 by Mariusthvdb
you posted there too, so read the 4 posts up… before asking here
Er… Oops…
Thanks for the addon. I’ve installed it but the Statistics card doesn’t pick it up. How did you get the nice graph you show?
Thanks!
Is this addon still relevant? I just tried to install but the link to the repository was declined in supervisor.
I would need to change the name of the Entity in Ha, is it going to do it?
Sorry, no that is not supported.
There are integrations which support this functionality though.
Edited: Found in the docs it may be possible to CURL from the remote Pi. What should $HASSIO_TOKEN be?
Can I use this to monitor a remote sensor - HA is running on one Pi and my temp sensor on another? Actually the remote sensor is a DS18B20 measuring my hot water tank.
I am competent doing most aspects of this … apart from HA where I am still a newbie despite running it for a few months!! I have looked at posts doing something with MQTT but it appears to be quite messy/complicated.
Still works with HASSOS 2024
