Still won’t start for me with this error log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Transmission
The torrent client for Hass.io with OpenVPN support
Add-on version: dev
You are running the latest version of this add-on.
System: Ubuntu 19.04 (amd64 / intel-nuc)
Home Assistant version: 0.97.2
Supervisor version: 181
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
/var/run/s6/etc/cont-init.d/10-requirements.sh: line 27: bashio::config.get: command not found
/var/run/s6/etc/cont-init.d/10-requirements.sh: line 27: bashio::file_exists: command not found
/var/run/s6/etc/cont-init.d/10-requirements.sh: line 28: bashio::config.get: command not found
/var/run/s6/etc/cont-init.d/10-requirements.sh: line 28: bashio::die: command not found
[cont-init.d] 10-requirements.sh: exited 127.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
