Install
Click on this badge to import :
Note: You can also find the blueprint code here knx-climate-entitie-control · GitHub
Main features
This blueprint can be used to fully control a Daikin Stylish HVAC (climate entity added with Daikin integration, it may work with other models) from KNX telegrams, including mode, temperature, speed, swing, preset and streamer.
It includes state feedback to KNX for any change of those parameters, and answer “GroupValueRead” telegrams for those parameters as well.
There are inputs to directly switch the cooling mode ON/OFF, but also the performance, eco and holiday modes.
Finally, it includes extra inputs to show/hide controls which are normally not available in particular modes (ie. when performance mode is enabled, it should hide temperature and fan speed controls).
This blueprint has been designed with the idea of controlling the HVAC unit from a KNX Zennio Z35 screen, but it can be used with any KNX device you like (all input parameters are optional).
Prerequisites
An HVAC climate entity which matches the modes of a Daikin Stylish unit :
hvac_modes: fan_only, dry, cool, heat, heat_cool, off
fan_modes: Auto, Silence, 1, 2, 3, 4, 5
preset_modes: none, away, eco, boost
swing_modes: Off, Vertical, Horizontal, 3D
And of course a functional KNX integration.
Setup
Create a new automation based on this Blueprint, and fill the inputs with the “Group Address” that you want to use to control the HVAC or to get its state feedback. Every input (= GA) is optional, except the climate entity obviously.
Changelog
2023-04-28 : Initial release
2023-06-14 : Fix some DPT errors
