- input number for window open temperature
- fallback option (off/heat) if weather entity or ouside temperature get unavailable or unknown
- persons could be replaced by device trackers (recommended)
- minimal configuration revised (window detection, liming protection)
- event based restore after liming protection
- static temperatures renamed to fallback temperatures
- fallback temperature (static temperatures) could be replaced by input number entities
- revised sections, selectors, and descriptions
- idle temperature when automation is turned off (winter mode off)
- dedicated hvac actions for eco mode and comfort mode
- new logic for physical or ui / thermostat cards changes
- summarized calibration logic:
- calibration on/off toggle
- automatic detection of offset or external temperature source for calibration
- thermostats with external calibration get keep alives every 10 min automatically
BREAKING CHANGES
- off instead of eco has been removed (set hvac mode off in eco mode options)
- physical change is independent of UI changes now. check your settings if you like.
- using calibration by offset be sure the calibration entity id contains the word โoffsetโ
