hi
whatever you changed in this version to the latest 5.2.16, all my automations with an external temp sensor and generic calibration didn’t set neither eco nor comfort temp via a sheduler!
Or is it fixed with the 5.3.1?
Updated to 5.3.1 and it looks like its working again
You can set the state of the sensor in the developer tools / state section. Filter for it, click on it, manipulate the state and click set state. Or you set an input boolean as a fake window.
Hi everyone,
thanks for providing this exceptional blueprint. I migrated away from better thermostat, since the temperatur was unreliable. But I currently am missing a nice way of controlling the room temperature. I was used to set up heating plans in Scheduler card and they also got this nice component better-thermostat-ui-card
Is there anyway to achive something similar, for the widget or the scheduling?
Hi there, for a few days now I have a problem with AHC. Whenever there is a change in the state of a scheduler, the respective thermostat will be set to off. It used to work properly for quite some time.
I am not sure if this is some kind of bug? I updated to 5.3.1, but that didn’t solve the problem.
It would be nice if somebody can point me in the right direction to solve that issue. - Thanks.
Thank you for your great blueprint.
I have several questions.
For the Proximity option, I would like to be able to set the temperature separately with an input_number entity, which is controlled when I am outside the range. Is this possible?
With the window open option, I would also like to be able to control the temperature using an input_number entity, is there a way to do that?
At night I would like to lower the temperature, I use the window option with a time of day sensor, would it be possible to implement this as a single option?
There is a holiday integration in HA, I would like to automatically treat the holidays like weekends. Is there a way to set that?
Thank you in advance for the help and thank you for the great blueprint.
Edit:
I also have to explain that I need another temperature in addition to the Comfort temperature when I’m at home. I use the Eco temperature for this.
Could you check the state of your outside temperature sensor if it is below you threshold temperature? Also try to remove it temporarily from your ahc configuration.
This really did the trick. I just realized that my outside temp sensor is unavailable.
Now I have another issue: For one of my AHC rules, the window sensor has an issue. The thermostat will be set to off when the window will be opened. However, the temperature won’t be set back to its previous value when the window has been closed.
I checked all the settings but couldn’t find any obvious error. Here’s the respective trace back: https://controlc.com/7b9e3032
First of all, thank you very much for all your work. Unfortunately, I can’t find a solution to my problem. I have a sonoff heating thermostat with an external temperature sensor and a window sensor. When the window is opened, the thermostat returns to the preset low temperature. If the window is closed, whether after a few minutes or hours, the temperature remains at the low value. Has anyone solved a similar problem?
