"trace": {
"trigger/27": [
"path": "trigger/27",
"timestamp": "2025-11-12T17:39:19.250222+00:00",
"changed_variables": {
"this": {
"entity_id": "automation.heizung_bad_og",
"state": "on",
"attributes": {
"id": "1736011028409",
"last_triggered": "2025-11-12T16:42:33.831326+00:00",
"mode": "queued",
"current": 0,
"max": 10,
"friendly_name": "Heizung Bad OG"
"last_changed": "2025-11-12T17:39:04.785208+00:00",
"last_reported": "2025-11-12T17:39:04.785208+00:00",
"last_updated": "2025-11-12T17:39:04.785208+00:00",
"context": {
"id": "01K9WJCKE9CPPF2YCH404CF61T",
"parent_id": null,
"user_id": "db9c3fbfc93644759f69855bf28c41f5"
"trigger": {
"platform": "template",
"entity_id": "binary_sensor.thermostat_bad_og_enforce_comfort",
"from_state": {
"state": "on",
"attributes": {
"friendly_name": "Thermostat Bad OG Enforce Comfort"
"last_changed": "2025-11-12T17:38:32.472248+00:00",
"last_reported": "2025-11-12T17:38:32.472248+00:00",
"last_updated": "2025-11-12T17:38:32.472248+00:00",
"context": {
"id": "01K9WJBKWQKXPS1SRJH5GJJ7XT",
"parent_id": null,
"to_state": {
"state": "off",
"attributes": {
"last_changed": "2025-11-12T17:39:17.239725+00:00",
"last_reported": "2025-11-12T17:39:17.239725+00:00",
"last_updated": "2025-11-12T17:39:17.239725+00:00",
"context": {
"id": "01K9WJCZKQH7X4FX9DCKT09MXW",
"parent_id": null,
"id": "temperature_change_party_off",
"idx": "27",
"alias": null,
"for": {
"__type": "<class 'datetime.timedelta'>",
"total_seconds": 2
"description": "binary_sensor.thermostat_bad_og_enforce_comfort via template"
"input_trvs": [
"climate.thermostat_bad_og"
"input_temperature_sensor": [],
"is_temperature_sensor_defined": false,
"input_persons": [],
"input_mode_guest": "binary_sensor.thermostat_bad_og_enforce_away",
"input_people_entering_home_duration": {
"hours": 0,
"minutes": 0,
"seconds": 2
"input_people_leaving_home_duration": {
"hours": 0,
"minutes": 0,
"seconds": 2
"input_person_count": 0,
"is_person_defined": true,
"is_guest_mode_defined": true,
"input_schedulers": [
"schedule.zeitplan_heizen_bad_og"
"input_scheduler_selector": null,
"input_scheduler_presence": null,
"is_scheduler_presence_defined": false,
"input_temperature_comfort": "input_number.temperatur_komfort",
"input_temperature_eco": "input_number.temperatur_oko",
"input_hvac_mode": "heat",
"factor": 1,
"is_heat_only_if_below_real_temp": false,
"input_mode_winter": "input_boolean.heizbetrieb",
"input_mode_outside_temperature": "weather.forecast_h27",
"input_mode_outside_temperature_threshold": 15,
"input_mode_room_temperature_threshold": 18,
"input_mode_room_temperature": false,
"input_invert_winter_mode_value": false,
"input_mode_party": [
"input_adjustments": "[]",
"input_calibration_timeout": {
"hours": 0,
"minutes": 1,
"seconds": 0
"input_windows": [
"binary_sensor.fenster_bad_og_contact"
"input_presence_sensor": null,
"is_presence_sensor_defined": false,
"input_presence_reaction_on_time": {
"hours": 0,
"minutes": 5,
"seconds": 0
"input_presence_reaction_off_time": {
"hours": 0,
"minutes": 5,
"seconds": 0
"input_proximity": null,
"input_proximity_duration": {
"hours": 0,
"minutes": 2,
"seconds": 0
"input_proximity_distance": 500,
"input_frost_protection_duration": {
"days": 0,
"hours": 0,
"minutes": 0,
"seconds": 0
"input_liming_protection": false,
"input_liming_protection_day": "Mon",
"input_liming_protection_time": "12:00:00",
"input_liming_in_winter": false,
"input_liming_protection_duration": 1,
"input_temperature_comfort_entity": "input_number.temperatur_komfort",
"input_temperature_comfort_static": 22,
"input_temperature_eco_entity": "input_number.temperatur_oko",
"input_temperature_eco_static": 19,
"input_frost_protection_temp": 12,
"input_windows_reaction_time_open": {
"hours": 0,
"minutes": 1,
"seconds": 0
"input_windows_reaction_time_close": {
"hours": 0,
"minutes": 0,
"seconds": 30
"input_window_open_temperature": 0,
"input_party_legacy_restore": false,
"input_window_legacy_restore": false,
"is_legacy_restore": false,
"input_force_max_temperature": [],
"input_force_eco_temperature": "binary_sensor.thermostat_bad_og_enforce_eco",
"input_calibration_delta": 0.5,
"input_calibration_generic": false,
"input_calibration_step_size": "auto",
"input_calibration_key_word": "calibration",
"input_generic_calibration_offset": 5,
"input_aggressive_mode_offset": 0,
"input_aggressive_mode_range": 0,
"input_aggressive_mode_calibration": false,
"input_away_offset": 10,
"is_scheduler_away_mode": false,
"is_presence_away_mode": true,
"presence_ignor_people": false,
"is_reset_temperature": false,
"is_off_instead_min": false,
"is_not_off_but_min": false,
"is_fahrenheit": false,
"is_physical_change_enabled": false,
"is_off_if_nobody_home": false,
"input_action_call_delay": {
"hours": 0,
"minutes": 0,
"seconds": 2
"input_custom_action": null,
"input_startup_delay": {
"hours": 0,
"minutes": 0,
"seconds": 0
"input_fully_open_difference": 1,
"input_valve_opening_keyword": "valve_opening_degree",
"input_valve_positioning_step_size": "10",
"input_valve_positioning_mode": "off",
"input_valve_positioning_timeout": {
"hours": 0,
"minutes": 20,
"seconds": 0
"input_valve_positioning_max_opening": 100,
"invalid_states": [
"unknown",
"unavailable"
"value_temperature_sensor": "unknown",
"valid_temperature_sensor": false,
"current_time_stamp": "2025-11-12 18:39:19.242959+01:00",
"is_metric": true,
"up_time_sensor": "sensor.uptime",
"is_uptime_defined": true,
"uptime": "2025-11-11 12:49:31+00:00",
"startup_delay": null,
"state_outside_temp": true,
"state_ahc": true,
"is_proximity_defined": false,
"state_proximity_arrived": false,
"state_proximity_way_home": false,
"is_guest_mode": false,
"is_anybody_home": false,
"is_anybody_home_or_proximity": false,
"active_scheduler": "schedule.zeitplan_heizen_bad_og",
"is_scheduler_defined": true,
"state_scheduler": true,
"is_presence_scheduler_defined": false,
"state_presence_scheduler": false,
"state_presence_sensor": false,
"state_presence": false,
"is_force_max_temperature": false,
"is_force_eco_temperature": false,
"active_party_entity": null,
"state_party": false,
"party_temp": null,
"is_away": false,
"state_window": false,
"is_aggressive_mode": false,
"is_aggressive_mode_calibration": false,
"is_frost_protection": false,
"is_liming_protection": false,
"valves": [
"valves_unsupported": [],
"valves_off_mode": [
"valves_without_off_mode": [],
"valves_tado": [],
"valves_xiaomi_xiaomi": [],
"valves_xiaomi_aqara": [
"valves_xiaomi": [
"valves_danfoss": [],
"valves_popp": [],
"valves_hive": [],
"valves_dph": [],
"valves_calibration_common": [],
"last_comfort_entity_change": "2025-11-11 12:49:29.900362+00:00",
"last_eco_entity_change": "2025-11-11 12:49:29.900471+00:00",
"latest_entry_today": null,
"latest_entry_day_before": null,
"entry": null,
"entry_time": "",
"entry_comfort_temp": null,
"entry_eco_temp": null,
"entry_calibration": true,
"entry_mode": "auto",
"trigger_id_defined": true,
"is_calibration_trigger": false,
"is_generic_calibration_trigger": false,
"is_generic_calibration": false,
"is_aggressive_mode_trigger": false,
"is_change_trigger": false,
"set_max_temperature": false,
"is_pysical_change": false,
"is_adjustment_trigger": false,
"is_reset": false,
"is_changes_trigger": true,
"is_scene_create_trigger": false,
"is_scene_apply_trigger": true,
"is_scene_destroy_trigger": false,
"scene_entities": [
"scene_window_id": "scene.heizung_bad_og_window",
"scene_party_id": "scene.heizung_bad_og_party",
"scenes_all": [
"scene_to_apply": "scene.heizung_bad_og_party",
"scenes_to_destroy": [],
"scene_to_create": "scene.heizung_bad_og_party",
"set_comfort": false,
"mode": "heat",
"temperature_comfort_of_entity": 21,
"temperature_eco_of_entity": 17,
"temperature_comfort": 21,
"temperature_away": 11,
"temperature_eco": 17,
"target_temperature": 17,
"changes": {},
"positioning": [],
"reset_data": [],
"is_reset_trigger": false,
"is_native_calibration": false,
"is_native_calibration_trigger": false,
"rounding_mode": "auto",
"calibration_tado": {},
"calibration_xiaomi": {},
"calibration_dph": {},
"calibration_common": {},
"calibration_value_set": {},
"no_changes": false,
"scene_trigger": true,
"change_trigger": false,
"reset_trigger": false,
"calibration_trigger": false,
"positioning_trigger": false,
"automation_name": "Heizung Bad OG",
"warnings": [],
"climates_information": [
"entity_id": "climate.thermostat_bad_og",
"state": "heat",
"temperature": 17,
"current_temperature": 19.8
"condition/0": [
"path": "condition/0",
"timestamp": "2025-11-12T17:39:19.250259+00:00",
"result": {
"result": true
"condition/0/conditions/0": [
"path": "condition/0/conditions/0",
"timestamp": "2025-11-12T17:39:19.250294+00:00",
"result": {
"result": false,
"entities": []
"condition/0/conditions/1": [
"path": "condition/0/conditions/1",
"timestamp": "2025-11-12T17:39:19.250437+00:00",
"result": {
"result": true,
"entities": []
"action/0": [
"path": "action/0",
"timestamp": "2025-11-12T17:39:19.250831+00:00",
"context": {
"id": "01K9WJD1JAWNNSR87SYEM17CRW",
"parent_id": "01K9WJCZKQH7X4FX9DCKT09MXW",
"user_id": null
"is_delayed": false
"action/1": [
"path": "action/1",
"timestamp": "2025-11-12T17:39:19.251402+00:00",
"result": {
"params": {
"domain": "system_log",
"service": "write",
"service_data": {
"message": "AHC - Heizung Bad OG \n automation delayed: False",
"level": "warning",
"logger": "blueprints.panhans.heatingcontrol"
"target": {}
"running_script": false
"action/2": [
"path": "action/2",
"timestamp": "2025-11-12T17:39:19.252146+00:00",
"wait": {
"remaining": null,
"completed": true
"result": {
"wait": {
"remaining": null,
"completed": true
"action/3": [
"path": "action/3",
"timestamp": "2025-11-12T17:39:19.252752+00:00",
"scene_to_apply_tmp": null
"result": {
"choice": "default"
"action/3/choose/0": [
"path": "action/3/choose/0",
"timestamp": "2025-11-12T17:39:19.252895+00:00",
"result": {
"result": false
"action/3/choose/0/conditions/0": [
"path": "action/3/choose/0/conditions/0",
"timestamp": "2025-11-12T17:39:19.253199+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/0": [
"path": "action/3/default/0",
"timestamp": "2025-11-12T17:39:19.253835+00:00"
"action/3/default/0/if": [
"path": "action/3/default/0/if",
"timestamp": "2025-11-12T17:39:19.253976+00:00",
"result": {
"result": false
"action/3/default/0/if/condition/0": [
"path": "action/3/default/0/if/condition/0",
"timestamp": "2025-11-12T17:39:19.254282+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/1": [
"path": "action/3/default/1",
"timestamp": "2025-11-12T17:39:19.254988+00:00",
"result": {
"event": "ahc_event",
"event_data": {
"state": true,
"mode": "eco",
"automation": "automation.heizung_bad_og",
"party_temp": null,
"is_away": false,
"entry_time": "",
"thermostats": [
"hvac_mode": "heat",
"last_trigger_id": "temperature_change_party_off",
"warnings": false
"action/3/default/2": [
"path": "action/3/default/2",
"timestamp": "2025-11-12T17:39:19.263778+00:00"
"action/3/default/2/if": [
"path": "action/3/default/2/if",
"timestamp": "2025-11-12T17:39:19.263918+00:00",
"result": {
"result": false
"action/3/default/2/if/condition/0": [
"path": "action/3/default/2/if/condition/0",
"timestamp": "2025-11-12T17:39:19.264227+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/3": [
"path": "action/3/default/3",
"timestamp": "2025-11-12T17:39:19.264937+00:00"
"action/3/default/3/if": [
"path": "action/3/default/3/if",
"timestamp": "2025-11-12T17:39:19.265067+00:00",
"result": {
"result": false
"action/3/default/3/if/condition/0": [
"path": "action/3/default/3/if/condition/0",
"timestamp": "2025-11-12T17:39:19.265372+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/4": [
"path": "action/3/default/4",
"timestamp": "2025-11-12T17:39:19.266071+00:00"
"action/3/default/4/if": [
"path": "action/3/default/4/if",
"timestamp": "2025-11-12T17:39:19.266200+00:00",
"result": {
"result": false
"action/3/default/4/if/condition/0": [
"path": "action/3/default/4/if/condition/0",
"timestamp": "2025-11-12T17:39:19.266532+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/5": [
"path": "action/3/default/5",
"timestamp": "2025-11-12T17:39:19.267202+00:00"
"action/3/default/5/if": [
"path": "action/3/default/5/if",
"timestamp": "2025-11-12T17:39:19.267331+00:00",
"result": {
"result": false
"action/3/default/5/if/condition/0": [
"path": "action/3/default/5/if/condition/0",
"timestamp": "2025-11-12T17:39:19.267666+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/6": [
"path": "action/3/default/6",
"timestamp": "2025-11-12T17:39:19.268342+00:00",
"action/3/default/7": [
"path": "action/3/default/7",
"timestamp": "2025-11-12T17:39:19.269550+00:00",
"result": {
"choice": "else"
"action/3/default/7/if": [
"path": "action/3/default/7/if",
"timestamp": "2025-11-12T17:39:19.269684+00:00",
"result": {
"result": false
"action/3/default/7/if/condition/0": [
"path": "action/3/default/7/if/condition/0",
"timestamp": "2025-11-12T17:39:19.269988+00:00",
"result": {
"result": true,
"entities": []
"action/3/default/7/if/condition/1": [
"path": "action/3/default/7/if/condition/1",
"timestamp": "2025-11-12T17:39:19.270549+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/7/else/0": [
"path": "action/3/default/7/else/0",
"timestamp": "2025-11-12T17:39:19.271162+00:00"
"action/3/default/7/else/0/if": [
"path": "action/3/default/7/else/0/if",
"timestamp": "2025-11-12T17:39:19.271299+00:00",
"result": {
"result": false
"action/3/default/7/else/0/if/condition/0": [
"path": "action/3/default/7/else/0/if/condition/0",
"timestamp": "2025-11-12T17:39:19.271627+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/7/else/1": [
"path": "action/3/default/7/else/1",
"timestamp": "2025-11-12T17:39:19.272277+00:00"
"action/3/default/7/else/1/if": [
"path": "action/3/default/7/else/1/if",
"timestamp": "2025-11-12T17:39:19.272412+00:00",
"result": {
"result": false
"action/3/default/7/else/1/if/condition/0": [
"path": "action/3/default/7/else/1/if/condition/0",
"timestamp": "2025-11-12T17:39:19.272731+00:00",
"result": {
"result": true
"action/3/default/7/else/1/if/condition/1": [
"path": "action/3/default/7/else/1/if/condition/1",
"timestamp": "2025-11-12T17:39:19.273026+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/8": [
"path": "action/3/default/8",
"timestamp": "2025-11-12T17:39:19.273839+00:00"
"action/3/default/8/if": [
"path": "action/3/default/8/if",
"timestamp": "2025-11-12T17:39:19.273966+00:00",
"result": {
"result": false
"action/3/default/8/if/condition/0": [
"path": "action/3/default/8/if/condition/0",
"timestamp": "2025-11-12T17:39:19.274265+00:00",
"result": {
"result": false,
"entities": []
"action/3/default/9": [
"path": "action/3/default/9",
"timestamp": "2025-11-12T17:39:19.274938+00:00"
"action/3/default/9/if": [
"path": "action/3/default/9/if",
"timestamp": "2025-11-12T17:39:19.275063+00:00",
"result": {
"result": false
"action/3/default/9/if/condition/0": [
"path": "action/3/default/9/if/condition/0",
"timestamp": "2025-11-12T17:39:19.275363+00:00",
"result": {
"result": false,
"entities": []
