Hi all,
I have a few issues with my zwave network that I was hoping someone smarter than me might be able to offer some advice.
I recently migrated my HA from a raspberry pi to docker in a container on my QNAP NAS, mostly for stability reasons. After creating a new instance of HA on my NAS, I copied my HA config from the rPi to the new HA instance and then moved my whole network over to a new Aeotec Z-stick plus (to work with the NAS) by excluding on the rPi and including every device on the newly created HA instance/z-stick. After finally adding all the devices, I then went through my config and updated all references to the new device names. PITA but had to do it.
Since doing that I am finding that I am having all kinds of issues with devices becoming unresponsive after about 3 days of use and the only way I can get them to work again is to power cycle all the aeotec devices via my meter board breakers. Heals, refreshes, reboots etc don’t make any difference, only a power cycle or exclude/re-include fixes them. They don’t go dead or anything, they just get very high RTTs and stop working. Directly after a reboot their RTTs are quite normal. I’m not positive but I suspect my network becomes slightly slower each day and is its fastest after a power cycle. Could just be my imagination tho.
Although many of my devices have energy metering, all of them have it turned off and is using basic report type to minimise chatter. I have no devices that require polling and the network is about 30-40 devices, nearly all of them powered, all in close proximity. The Zwave ‘graph’ panel shows nearly all of them as only 1 hop and most have RTT between 40 and 120ish. When newly rebooted and not having issues, the devices respond nearly instantly all over the house.
If I try trigger a switch that has stopped responding in HA, it locks up the rest of the zwave network for about 10 seconds. Once it has timed out, all the other devices work fine.
In trying to work out what is happening I have noticed that a bunch of my single nano switches are named/referenced as Dual nano switches which is very weird. For example, one nano single switch has an entity name of zwave.aeotec_zw132_dual_nano_switch_5 in the states tab of developer tools. This device is definitely not a dual unit. All I can think of is that when I copied my config over before adding all the new devices, HA has gotten confused data after adding the new devices and is confusing its name with whatever device had that nodeID in the old network. This might be a separate issue and may not be having and impact on my zwave network but some of these wrongly named devices are the ones which are becoming unresponsive on the network.
Does anyone know whether there is a chance that HA or OZW has a file I can delete that rebuilds or something that might clean up the entity data? I tried deleting zwcfg_XXXX.xml but all that did is make half of my devices ‘unknown’ and I had to exclude and re-include again.
Hope this all makes sense and I really appreciate any help people might be able to offer.
Thanks all!
