Ok, bad news, now the Aeotec Minimote is no more available! Still in the Configuration…Devices list but no more in the Z-Wave Devices list. Seems to me that the DSA22 Keyfob has taken his place, How’s that possible?? No way to use both remotes?
Try to add node again:
2019-10-27 18:04:19.958 Detail,
2019-10-27 18:04:19.959 Info, Node005, Sending (WakeUp) message (Callback ID=0x68, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x84, 0x08, 0x25, 0x68, 0x23
2019-10-27 18:04:19.966 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-27 18:04:19.966 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-27 18:04:19.983 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x68, 0x00, 0x00, 0x03, 0x80
2019-10-27 18:04:19.983 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x68 received (expected 0x68)
2019-10-27 18:04:19.983 Info, Node005, Request RTT 24 Average Request RTT 24
2019-10-27 18:04:19.983 Info, Node005, Node 5 has been marked as asleep
2019-10-27 18:04:19.984 Detail, Expected callbackId was received
2019-10-27 18:04:19.984 Detail, Expected reply was received
2019-10-27 18:04:19.984 Detail, Message transaction complete
2019-10-27 18:04:19.984 Detail, Node005, Removing current message
2019-10-27 18:04:19.984 Detail, Node005, Notification: Notification - Node Asleep
2019-10-27 18:04:32.281 Info, Node005, Value::Set - COMMAND_CLASS_CONFIGURATION - Mode - 250 - 1 - Scene
2019-10-27 18:04:32.281 Info, Node005, Configuration::Set - Parameter=250, Value=1 Size=1
2019-10-27 18:04:32.281 Detail,
2019-10-27 18:04:32.281 Detail, Node005, Queuing (WakeUp) ConfigurationCmd_Set (Node=5): 0x01, 0x0c, 0x00, 0x13, 0x05, 0x05, 0x70, 0x04, 0xfa, 0x01, 0x01, 0x25, 0x69, 0x22
2019-10-27 18:04:32.282 Detail,
2019-10-27 18:04:32.282 Detail, Node005, Queuing (WakeUp) ConfigurationCmd_Get (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x70, 0x05, 0xfa, 0x25, 0x6a, 0x20
Now it works, but had to add Minimote again in z-wave, bug ?
