Ok, I have about 8 of these things and I have constant issues with them. They are super annoying and I am hoping someone else has had experiences and being able to resolve them. They detect as zwave.aeon_labs_zw096_smart_switch_6 in HASS.
I only seem to be able to use them if they are within 10 meters of the ZWave controller. I add them to the network at the controller/at my desk and then when I try to move them out as soon as you try to use them they turn up as a dead node, the ZWave controller can not find it, you get an error as below:
2020-03-15 16:54:52.489 Info, Node033, WARNING: ZW_DELETE_RETURN_ROUTE failed. No ACK received - device may be asleep.
2020-03-15 16:54:52.489 Warning, Node033, WARNING: Device is not a sleeping node.
2020-03-15 16:54:52.490 Detail, Node033, Removing current message
2020-03-15 16:54:52.494 Detail, Node033, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=33): 0x01, 0x06, 0x00, 0x46, 0x21, 0x01, 0x38, 0xa7
2020-03-15 16:54:52.498 Info, Node033, Sending (Command) message (Callback ID=0x38, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=33): 0x01, 0x06, 0x00, 0x46, 0x21, 0x01, 0x38, 0xa7
2020-03-15 16:54:52.513 Detail, Node033, Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
2020-03-15 16:54:52.513 Info, Node033, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
2020-03-15 16:54:52.630 Detail, Node033, Received: 0x01, 0x05, 0x00, 0x46, 0x38, 0x01, 0x85
2020-03-15 16:54:52.630 Info, Node033, WARNING: ZW_ASSIGN_RETURN_ROUTE failed. No ACK received - device may be asleep.
2020-03-15 16:54:52.630 Warning, Node033, WARNING: Device is not a sleeping node.
2020-03-15 16:54:52.631 Detail, Node033, Removing current message
2020-03-15 16:55:18.904 Info, Node033, NoOperation::Set - Routing=true
2020-03-15 16:55:18.904 Detail, Node033, Queuing (NoOp) NoOperation_Set (Node=33): 0x01, 0x09, 0x00, 0x13, 0x21, 0x02, 0x00, 0x00, 0x25, 0x39, 0xda
2020-03-15 16:55:18.905 Info, Node033, Sending (NoOp) message (Callback ID=0x39, Expected Reply=0x13) - NoOperation_Set (Node=33): 0x01, 0x09, 0x00, 0x13, 0x21, 0x02, 0x00, 0x00, 0x25, 0x39, 0xda
2020-03-15 16:55:18.916 Detail, Node033, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-03-15 16:55:18.916 Detail, Node033, ZW_SEND_DATA delivered to Z-Wave stack
2020-03-15 16:55:22.997 Detail, Node033, Received: 0x01, 0x07, 0x00, 0x13, 0x39, 0x01, 0x01, 0x99, 0x4b
2020-03-15 16:55:22.998 Detail, Node033, ZW_SEND_DATA Request with callback ID 0x39 received (expected 0x39)
2020-03-15 16:55:22.998 Info, Node033, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2020-03-15 16:55:22.998 Warning, Node033, WARNING: Device is not a sleeping node.
2020-03-15 16:55:22.998 Error, Node033, ERROR: node presumed dead
There are plenty of other zwave devices around the network is working really well these days due to some upgrades but these GPOās are the last remaining thorn in my side. Any ideas? Thanks
