I had a short power outtage and later noticed all z wave light devices came up grey in HA interface and also z wave sirens and danalock. But, I do have a fibaro water sensor that shows up (temperature is updating) and a aetoc z wave water sensor that shows up (temperature is updating). But the aetoec sensor placed 1meter from the HA is not showing up nore are any fibaro wallplugs or wallswitches/dimmers our outdoor plugs/dimmers using z wave.
Tried restarting both stick and HA but no luck. I got the discolights flasing atleast.
Z wave JS version 0.1.53 also tried with latest 0.1.54. Earlier today I updated to 0.1.54 and core from 2022.2.5 to 2022.2.9 I first thought it might have something to do with these updates so used backup to restore back to core 2022.2.5 and z wave 0.1.53.
Under diagnostics it sais Driver: 8.11.5 , Serverversion: 1.14.1
I tried repair network.
Running on Pi 4 Model B 8RAM.
Anything else I can do or should or do I need to buy a new stick or did something on Pi itself broke perhaps?
I use Z-WaveJS2MQTT, so debugging IMO is much easier, but I believe you can use the log in zwavejs (see screenshot) ? Make sure it’s on at least 'info" level.
Thanks. Found the correct place for logs with your help. In the logs I see alot of this
The controller response indicated failure after 1/3 attempts. Scheduling next try in 100 ms.
[Node 006] refreshing neighbor list failed…
[Node 006] refreshing neighbor list (attempt 2)…
The only backups I have is for 0.1.53 before I updated to 0.1.54 and I have restored to 0.1.53 currently.
Also noticed my driver sais 8.11.5 were your sais 8.11.14
How many nodes involved in the logs? Do you see one node more then others?
The reason why I ask, sometimes if a node(s) gets stupid, (non stop broadcasts, etc…) it can bring much of the network down. In the last 8 years (with HomeSeer) I’ve experienced this 3 times. It can be a pain to find the offending node.
Currently healing network so perhaps logs are being filled with more than normal but I only see Node 4 5 and 6 in the logs.
[Node 006] requesting node neighbors…
[Node 006] node neighbors received: 4
[Node 004] treating BasicCC::Set as a report
[Node 006] Sending node back to sleep…
[Node 005] failed to update the neighbor list after 5 attempts, healing failed
Ok. I managed to get it fixed. ”Have you tried turning it off and on again” did the trick. A hard reset unplugging power to the Pi. So in order to fix the problems I got from the power outtage I had to simulate a power outtage. Go figure.
