I’m running hass.io on docker environment and after updating to 0.108.9 from 0.106.2 earlier today I cannot access most of the panels anymore.
Overview is working and entities show states fine. Map, Logbook, History, Notifications and “user page” are not loading - only spinning circle appears on the screen no error messages, only ring keeps spinning on the screen no matter how long I wait.
I can also access Developer Tools page but States, Services, Template, Events and MQQT panels are not loading (same spinning circle).
I’ll add my report that I find pretty much exactly the same as you do @Kryzek I amd also on docker environment on a QNAP NAS in Container Station although for me it was in 0.108.8 after updating from my previous fallback position of 0.107.7. I had previously tried moving to 0.108.1 but found that when I tried to load the Dev Tools…or Configuration…nothing loaded. (see original post here).
Oh, I must report that as far as I could see all my modbus entities were working in .0.108.8 though.
Due to my workload here I was forced to just fallback to 0.107.7 for now and wait to see what is ahead for 0.108.xx? It seems to me that this 0.108.xx series has been a failed excercise though so maybe I’ll just wait until 0.109.xx proves itself or not?
I too am having issues with various pages not loading beyond 0.108.x. History often says ‘Loading state history…’ and that’s it. Other pages like Developer Tools and Supervisor randomly just display nothing. The only way to get it back is to close the browser tab and open it again. Tried CTRL + F5 numerous times but this does not help. Happening on FF and Chrome. Might have to roll back to 107 to try if others are saying that works. Running HassOS 3.13 on Intel NUC.
Cleared the browser cache. Here is the sign the something is not right. This has been happening most recently but I don’t know if it was after 0.108.x or 0.109.x as the LL page is new.
I’m trying to get to the bottom of this and would appreciate it if you could share whether you have any of the same custom integrations I have that may be contributing to the issue? Integrations:
HACS
Plugins:
Bar Card
button-card
Canvas Gauge Card
Custom Header
Mini Graph Card
It seems that any GUI item that needs to draw a graph (relying on my recorder history) is causing my problem. Don’t know why the recorder history is taking so long to load so trying another SSD today. I switched my MariaDB add-on to a local HA database and this made no difference.
Lastly, any issues rolling back to 0.107.7 I need to be aware of?
I did still have the Bar Card listed as a resource in ui-lovelace.yaml but have just removed that.
None of those other custom integrations are used.
Fallback to 0.107.7 was painfree but it’s very easy using docker as all I have to do is stop the troublesome container and restart the 0.107.7 container.
Whatever these problems are they appear to be in HA itself I believe. I run one only custum component and a reasonably small list of core integrations anyway.
This is the list of Integrations here developer-tools/info
Nailed it!!! Problem is to do with multiple Lovelace dashboards and the Synology Surveillance Station integration. If I remove the SSS integration and restart, the GUI is fully responsive and never falters and the graphs all load instantly and present their states history in <1 second. If I add back in cameras using the generic method, the GUI still loads perfectly and the graphs all respond as they should.
If I remove all dashboards expect for the default one, things are also a lot snappier and graphs load instantly. I’m now going to test the SSS integration with just one dash and see if it will work like that.
UPDATE: Adding in generic cameras also causes a problem when displaying on secondary dashboards.
