Replying to my own post, I think I managed to do what @brillb mentioned he did
Created airthings-cron.py with the following code (removed the while loop and a few other things - warning I’m not a coder, but it appears to work!):
#!/usr/bin/python3
# Copyright (c) 2021 Mark McCans
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
import logging, time, json, sys, os, toml
import paho.mqtt.publish as publish
from paho.mqtt import MQTTException
from airthings import AirthingsWaveDetect
# DEBUG: Remove old imports
#from pygatt.exceptions import NotConnectedError, BLEError, NotificationTimeout
_LOGGER = logging.getLogger("airthings-mqtt-ha")
CONFIG = {} # Variable to store configuration
DEVICES = {} # Variable to store devices
# Default configuration values
CONFIG_DEFAULTS = {
"general": {"refresh_interval": 150, "retry_count": 10, "retry_wait": 3, "log_level": "INFO"},
"devices": [],
"sensors": [],
"mqtt": {"host": "localhost", "port": 1883}
class ATSensors:
sensors_list = []
def __init__(self, scan_interval, devices=None):
_LOGGER.info("Setting up Airthings sensors...")
self.airthingsdetect = AirthingsWaveDetect(scan_interval, None)
# Note: Doing this so multiple mac addresses can be sent in instead of just one.
if devices is not None and devices != {}:
self.airthingsdetect.airthing_devices = list(devices)
else:
_LOGGER.info("No devices provided, so searching for sensors...")
self.find_devices()
# Get info about the devices
if not self.get_device_info():
# Exit if setup fails
_LOGGER.error("Failed to set up Airthings sensors. Exiting.")
sys.exit(1)
_LOGGER.info("Done Airthings setup.")
def find_devices(self):
try:
_LOGGER.debug("Searching for Airthings sensors...")
num_devices_found = self.airthingsdetect.find_devices()
_LOGGER.debug("Found {} airthings device(s)".format(num_devices_found))
if num_devices_found != 0:
# Put found devices into DEVICES variable
for d in self.airthingsdetect.airthing_devices:
DEVICES[d] = {}
else:
# Exit if no devices found
_LOGGER.warning("No airthings devices found. Exiting.")
sys.exit(1)
except:
_LOGGER.exception("Failed while searching for devices. Exiting.")
sys.exit(1)
def get_device_info(self):
_LOGGER.debug("Getting info about device(s)...")
for attempt in range(CONFIG["general"]["retry_count"]):
try:
devices_info = self.airthingsdetect.get_info()
#except (NotificationTimeout, NotConnectedError):
# _LOGGER.warning("Bluetooth error on attempt {}. Retrying in {} seconds.".format(attempt+1, CONFIG["general"]["retry_wait"]))
# time.sleep(CONFIG["general"]["retry_wait"])
except:
_LOGGER.exception("Unexpected exception while getting device information.")
return False
else:
# Success!
break
else:
# We failed all attempts
_LOGGER.exception("Failed to get info from devices after {} attempts.".format(CONFIG["general"]["retry_count"]))
return False
# Collect device details
for mac, dev in devices_info.items():
_LOGGER.info("{}: {}".format(mac, dev))
DEVICES[mac]["manufacturer"] = dev.manufacturer
DEVICES[mac]["serial_nr"] = dev.serial_nr
DEVICES[mac]["model_nr"] = dev.model_nr
DEVICES[mac]["device_name"] = dev.device_name
_LOGGER.debug("Getting sensors...")
try:
devices_sensors = self.airthingsdetect.get_sensors()
except:
_LOGGER.exception("Unexpected exception while getting sensors information.")
return False
else:
# Success!
break
else:
_LOGGER.exception("Failed to get info from sensors after {} attempts.".format(CONFIG["general"]["retry_count"]))
return False
# Collect sensor details
for mac, sensors in devices_sensors.items():
for sensor in sensors:
self.sensors_list.append([mac, sensor.uuid, sensor.handle])
_LOGGER.debug("{}: Found sensor UUID: {} Handle: {}".format(mac, sensor.uuid, sensor.handle))
return True
def get_sensor_data(self):
_LOGGER.debug("Getting sensor data...")
try:
sensordata = self.airthingsdetect.get_sensor_data()
return sensordata
except:
_LOGGER.exception("Unexpected exception while getting sensor data.")
return False
else:
# Success!
break
else:
_LOGGER.exception("Failed to get sensor data after {} attempts.".format(CONFIG["general"]["retry_count"]))
return False
return True
def mqtt_publish(msgs):
# Publish the sensor data to mqtt broker
try:
_LOGGER.info("Sending messages to mqtt broker...")
if "username" in CONFIG["mqtt"] and CONFIG["mqtt"]["username"] != "" and "password" in CONFIG["mqtt"] and CONFIG["mqtt"]["password"] != "":
auth = {'username':CONFIG["mqtt"]["username"], 'password':CONFIG["mqtt"]["password"]}
else:
auth = None
publish.multiple(msgs, hostname=CONFIG["mqtt"]["host"], port=CONFIG["mqtt"]["port"], client_id="airthings-mqtt", auth=auth)
_LOGGER.info("Done sending messages to mqtt broker.")
except MQTTException as e:
_LOGGER.error("Failed while sending messages to mqtt broker: {}".format(e))
except:
_LOGGER.exception("Unexpected exception while sending messages to mqtt broker.")
if __name__ == "__main__":
logging.basicConfig()
_LOGGER.setLevel(logging.INFO)
# Load configuration from file
try:
CONFIG = toml.load(os.path.join(sys.path[0], "config.toml"))
except:
# Exit if there is an error reading config file
_LOGGER.exception("Error reading config.toml file. Exiting.")
sys.exit(1)
# Fill in any missing configuration variable with defaults
for key in CONFIG_DEFAULTS:
if key not in CONFIG: CONFIG[key] = CONFIG_DEFAULTS[key]
for val in CONFIG_DEFAULTS[key]:
if val not in CONFIG[key]: CONFIG[key][val] = CONFIG_DEFAULTS[key][val]
# Set logging level (defaults to INFO)
if CONFIG["general"]["log_level"] in ["CRITICAL", "ERROR", "WARNING", "INFO", "DEBUG"]:
_LOGGER.setLevel(CONFIG["general"]["log_level"])
# Pull out devices (if any) configured
for d in CONFIG["devices"]:
if "mac" in d: DEVICES[d["mac"]] = {}
a = ATSensors(180, DEVICES)
# Update sensor values in accordance with the REFRESH_INTERVAL set.
# Get sensor data
sensors = a.get_sensor_data()
# Only connect to mqtt broker if we have data
if sensors is not None:
# Variable to store mqtt messages
msgs = []
# Send HA mqtt discovery messages to broker on first run
_LOGGER.info("Sending HA mqtt discovery configuration messages...")
for mac, data in sensors.items():
# Create device details for this device
device = {}
device["connections"] = [["mac", mac]]
if "serial_nr" in DEVICES[mac]: device["identifiers"] = [DEVICES[mac]["serial_nr"]]
if "manufacturer" in DEVICES[mac]: device["manufacturer"] = DEVICES[mac]["manufacturer"]
if "device_name" in DEVICES[mac]: device["name"] = DEVICES[mac]["device_name"]
if "model_nr" in DEVICES[mac]: device["model"] = DEVICES[mac]["model_nr"]
for name, val in data.items():
if name != "date_time":
try:
config = {}
s = next((item for item in CONFIG["devices"] if item["mac"] == mac), None)
if s != None:
if name in s:
config["name"] = s[name]["name"]
if "device_class" in s[name] and s[name]["device_class"] is not None:
config["device_class"] = s[name]["device_class"]
if "icon" in s[name] and s[name]["icon"] is not None:
config["icon"] = s[name]["icon"]
if "unit_of_measurement" in s[name] and s[name]["unit_of_measurement"] is not None:
config["unit_of_measurement"] = s[name]["unit_of_measurement"]
config["uniq_id"] = mac+"_"+name
config["state_topic"] = "airthings/"+mac+"/"+name
config["device"] = device
msgs.append({'topic': "homeassistant/sensor/airthings_"+mac.replace(":","")+"/"+name+"/config", 'payload': json.dumps(config), 'retain': True})
except:
_LOGGER.exception("Failed while creating HA mqtt discovery messages.")
# Publish the HA mqtt discovery data to mqtt broker
mqtt_publish(msgs)
_LOGGER.info("Done sending HA mqtt discovery configuration messages.")
msgs = []
time.sleep(5)
first = False
# Collect all of the sensor data
_LOGGER.info("Collecting sensor value messages...")
if isinstance(val, str) == False:
if name == "temperature":
val = round(val,1)
else:
val = round(val)
_LOGGER.info("{} = {}".format("airthings/"+mac+"/"+name, val))
msgs.append({'topic': "airthings/"+mac+"/"+name, 'payload': val})
mqtt_publish(msgs)
Ran crontab -e and added the following at the bottom so that the above runs every 5 minutes (adjust path of airthing-cron.py to suit your config):
*/5 * * * * python3 /home/pi/airthings/airthings-cron.py
Hope that helps somebody else! Thanks to the OP
