This is the relevant section of the log after turning on debugging for the integration and restarting HA. The 9 dampers / covers are being detected (group_number=0 - 8), but no entities are being created for these dampers. So a total of 3 devices are added (1 for the Airtouch panel and 2 for the ACs), and 7 entities are added. For comparison, the Airtouch 4 (PUSH) integration creates 2 devices with 29 entities.
2024-01-18 19:13:46.398 DEBUG (MainThread) [pyairtouch.comms.socket] ... Header : At4Header(to_address=176, from_address=128, packet_id=4, message_id=43, message_length=54)
2024-01-18 19:13:46.399 DEBUG (MainThread) [pyairtouch.comms.socket] ... Message : GroupStatusMessage(groups=[GroupStatusData(group_number=0, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=100, set_point=None), GroupStatusData(group_number=1, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=0, set_point=None), GroupStatusData(group_number=2, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=100, set_point=None), GroupStatusData(group_number=3, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=100, set_point=None), GroupStatusData(group_number=4, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=100, set_point=None), GroupStatusData(group_number=5, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=100, set_point=None), GroupStatusData(group_number=6, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=100, set_point=None), GroupStatusData(group_number=7, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=100, set_point=None), GroupStatusData(group_number=8, power_state=<GroupPowerState.OFF: 0>, control_method=<GroupControlMethod.DAMPER: 0>, spill_active=False, supports_turbo=False, has_sensor=False, battery_status=<SensorBatteryStatus.NORMAL: 0>, temperature=None, damper_percentage=100, set_point=None)])
2024-01-18 19:13:46.726 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up airtouch.binary_sensor
2024-01-18 19:13:46.732 INFO (MainThread) [homeassistant.components.climate] Setting up airtouch.climate
2024-01-18 19:13:46.732 DEBUG (MainThread) [custom_components.airtouch.binary_sensor] Found entities [<AcSpillEntity: AC1 (00:00:00:00:00:00_ac0_spill)>, <AcSpillEntity: AC2 (00:00:00:00:00:00_ac1_spill)>]
2024-01-18 19:13:46.734 INFO (MainThread) [homeassistant.components.cover] Setting up airtouch.cover
2024-01-18 19:13:46.735 DEBUG (MainThread) [custom_components.airtouch.climate] Found entities [<AcClimateEntity: AC1 (00:00:00:00:00:00_ac0)>, <AcClimateEntity: AC2 (00:00:00:00:00:00_ac1)>]
2024-01-18 19:13:46.737 INFO (MainThread) [homeassistant.components.sensor] Setting up airtouch.sensor
2024-01-18 19:13:46.737 DEBUG (MainThread) [custom_components.airtouch.cover] Found entities []
2024-01-18 19:13:46.740 INFO (MainThread) [homeassistant.components.update] Setting up airtouch.update
2024-01-18 19:13:46.741 DEBUG (MainThread) [custom_components.airtouch.sensor] Found entities: [<AcTemperatureEntity: AC1 (00:00:00:00:00:00_ac0_temperature)>, <AcTemperatureEntity: AC2 (00:00:00:00:00:00_ac1_temperature)>]
2024-01-18 19:13:46.743 DEBUG (MainThread) [custom_components.airtouch.update] Found entities: [<AirtouchUpdateEntity: AirTouch 4 (00:00:00:00:00:00)>]
2024-01-18 19:13:46.861 DEBUG (MainThread) [pyairtouch.comms.socket] Read Raw
