@eavanvalkenburg I took a little piece of log. You can find hereunder.
Maybe could be useful for your debugging.
Tell us if you need something more.
Thank you for your support.
2023-01-10 22:01:19.378 WARNING (MainThread) [pysiaalarm.base_server] Code not found, replying with DUH to account: 001
2023-01-10 22:01:30.428 WARNING (MainThread) [pysiaalarm.base_server] Code not found, replying with DUH to account: 001
2023-01-10 22:01:43.915 DEBUG (MainThread) [pysiaalarm.base_server] Incoming line: 0F310038"SIA-DCS"4613L0#001[#001|Nri1/PE502]_21:01:23,01-10-2023
2023-01-10 22:01:43.916 DEBUG (MainThread) [pysiaalarm.event] Content matches: {'account': '001', 'ti': None, 'id': None, 'ri': '1', 'code': 'PE', 'message': '502', 'xdata': None, 'timestamp': '21:01:23,01-10-2023'}
2023-01-10 22:01:43.922 WARNING (MainThread) [pysiaalarm.base_server] Code not found, replying with DUH to account: 001
I should have said that I logged an issue on github: https://github.com/home-assistant/core/issues/85386. If you think it may be due to a change in alarm panel, is it the right place to post the issue? Could someone take ownership?
Beside the icon color defect, I noticed that alarm control panels get disconnected very often which never occurred before. It has been running flawlessly for months. After I upgraded to 2013.1.0, it turns out that a few days later hub+ firmware got automatically upgraded as well. It is now running EU 2.14.0. So it is quite hard to make an assumption on what made this regression. To be honest I’m not very keen to downgrade.
EDIT
I must add that I’m using the default theme. I set-up now card_mod as a workaround. Here is the code. However I haven’t found yet how to do it for the button of the main alarm control panel.One step at a time
What’s happened to this integeration? It’s totally unrealiable now. I keep getting “Unavaiable” status and in my logs this morning it’s even got an entry as being Disarmed and shut down my wifi cameras.
It’s completely screwed for me as well. So unreliable is it that somehow it’s decided that my system was disarmed and turned off my cameras about 10 minutes after I left theh house.
Please also check with Ajax, because there were no code changes to the SIA integration so this is either a issue with Ajax (and mine still works fine) or something generic in HA or particular to your setup…
I have emailed Ajax support to ask if there is any issue.
I started having issues with this with the last December update of HA and it has followed through to the January builds.
Nothing has changed with the integration.
Only 32 minutes ago did it go to Unavailable again and it triggered some automatons that are only supposed to go on when the alarm is armed. So this is very concerning.
Another thing, the dashboard Alarm card doesn’t always reflect the status of the entity.
Maybe you should try to deactivate all addons and reactivate them one by one to see how it goes. My AJAX SIA integration works fine as well. Is your Ajax hub connected to Ethernet of WIfi?
So, after reconfiguring everything I have stability but checking the log it seems I get this unavailable status almost on an hourly basis for nearly a minute. Is this normal behaviour?`It’s almost like the inverse of what I had before, constant “unavailable” messages and sporadic moments of connectivity.
