That helped a lot, however still strugeling with the settings, In the documents the full configuration is mentioned. I did not get all the options in the config flow. How and where do I put them? Eg. The zone name?
Hi @Markus69 the config does not happen in yaml anymore, just in a config flow, so indeed go to integrations and add it from there, after adding the component through HACS, the config above will do nothing. Zonenames are not editable anymore, I will check the docs to see if those are still up to date.
Hi Eduard,
First thanks for all the good work, much appreciated. Under HACS Integrations SIA --> information there is a link to a page mentioning as I understand now old information. Thatâs what got me confused. It is working now so again thanks!!
I got this working. But I have one major issue. When the esp+remote is connected to power i cant restart home assistant. It doesnt start up. But when i unplug the esp+remote it works as it should. I am using wemos d1 mini.
That is really strange. Should have something to do with the MQTT server but I cannot understand why HA doesnât ignore that integration after a while/timeout. Or if there are other manual entities failing due to the switch not being set up properly through MQTT. Do you have retain set on or off in the MQTT config?
Yes, it reflects the state of your alarm, but you canât update it, since your alarm sends a message to the SIA server if something changes, it is reflected in HA very quickly.
Hi! Iâm having a bit of issue understanding how the installation of eavanvalkenburg custom component works⌠Iâm running regular Home Assistant (not Hass.io) through docker. Not sure how the config flow thing worksâŚ
Click install. <-- where do I find install?
The latest version is only available through a config flow.
After clicking the add button in the Integration pane, you full in the below fields.
Also, what is the status of getting Ajax in as an integration?
@Freland, you need to enable HACS and then you will be able to search for and install SIA (that is the click install) and then go to regular Integrations in HA and click add.
Iâve had my Ajax-home assistant (Docker with 0.116.3) setup working without any problems for a while now (thanks @eavanvalkenburg !). However, that last 2 days (in the middle of the night, 05:16 and 04:32) the alarm status in home assistant has switched over to âArmed Awayâ without the status in Ajax being changed. Iâve checked the logs in Home assistant but nothing strange there. Any ideas why?
I am not using @eavanvalkenburgâs integration but I have noticed that the Ajax alarm very often sends an unknown encrypted message and sometimes cuts the SIA connection during the night. Most often around 0400-0430. I also get a broken pipe error in the log. Since it happens every now and then I guess there is something going on. Maybe an update check or a scheduled reset or something. I do not have any problems with wrong statuses though.
Also havenât seen this before, and mine still works fine and I donât see any messages, so please turn on logging for the component to see whatâs going on! @Freland
