Good afternoon.
Can you tell if you can see the clicks on the ScaceControl Key Fob in Home Assistant
Depending on the button pressed on the keychain, I want to create different scenarios.
Whether alarm is fully armed, disarmed or armed night, it triggers an event you may catch and retrieve either the state value or various attributes value. For instance you may retrieve the last_message value that tells what device send the command. You may look at what is happening in Developer tools to adapt your automation
Thank you very much, Iām still weak in this, but I seem to have begun to understand how to do it.
Hi there!
I tried to add the integration, but the āMonitoring stationā stays ānot connectedā in the Ajax App.
I can see the entities in HA (both for Zone 1 and Zone 2), but without any state update. The only update I noted is a ā2022 ISO8601ā appeared in the Last Heartbeat entity after 2-3 days.
Could it be a port problem? How can I select a proper port for communication?
Thanks everyone!!!
Help, how to get the last_message I can not figure out how to do it. If I understand correctly, this is necessary to get to know the id of the spacecontrol.
Indeed. From where I am I do not have access to my HA ( as a matter of fact I discovered that VSC needs 4Mb of RAM, and HA is currently crashed, I need to remove this integration). However, from memory, you get access with this YAML instruction.
'{{state_attr(trigger.entity_id,''last_message'')}}'
Maybe this post will help you How to get alarm attributes and states and act accordingly
In my case any alarm change is send to another system with a Restfull command
If you have the last heartbeat sensor then you are using the custom component, the official integration is a bit more stable and in 2022.3 should also have a connectivity sensor and tighter behaviour for the entity attributes.
The port is up to you, on the server side (your HA system) it should be an open port (so not something like 80 or 443) and also not the HA port (default is 8123) but anything else (I usually use something like 8124) and then just make sure you have the same port set in your alarm.
Thank you Eduard! I was able to solve my issue thanks to the official integration.
Now I can see correctly the status update and its history.
Since Iām using Homey as main domotic hub, I would like to create āvirtual sensorsā in HA indicating āarmedā or ādisarmedā, to create flows depending on the state. The current entity is not seen by Homey as a device
Thanks again, going to study a solution
From my experience, last_message is linked to the device that acted on the alarm (Ajax App account, Space Control, ā¦). To my knowledge, there is no way to anticipate what could be the value, but when it is reported once it will stay forever the same. So far I rely on that to detect who did what.
Thank you very much.
@eavanvalkenburg: is there a way to customize this card in order to size it down and remove unecessary buttons (arm away and arm home). Four zones are managed, as it can be seen, it takes too much place. Thank you
I donāt know, Iām no front-end expert, but potentially there are people making custom visuals for alarms!
Thank you @eavanvalkenburg. It just happen that I was about to post the solution. Iām not expert either, still on the learning curve Until now, I did not make the switch to Lovelace personalization. Once that move is made, it is straighforward to remove the two buttons (just edit the card and set properties accordingly).
What was wrong and made it work?
Iāve triedā¦a lot. Still Not connected from the Ajax app. IP is correct, ID of Ajax hub is correctā¦ Donāt know what to do.
Good morning, can you put examples of your templates? some users have put some and I am very grateful but I am a novice and it is difficult for me to create them.
I put mine can someone help me interpret the data in the template and simplify them. Now to know which user arms and others I create several identitiesā¦
I do it by template because the alarm identity when a zone is opened says that it is in alarm but when it is closed it goes into normal armed modeā¦ thanks
Iām sorry for my English
template:
#### HUB AJAX ULTIMO TEST
- trigger:
- platform: event
event_type: sia_event_5000_2222
event_data:
code: "RP"
- name: "Ajax HUB ultimo test"
unique_id: ajax.test
state: "{{trigger.event.data.timestamp}}"
device_class: timestamp
unit_of_measurement: ISO8611
icon: mdi:clock-check-outline
#### AJAX HUB USUARIO
- trigger:
- platform: event
event_data:
code: 'CG' # Area Cerrada
ri: '1'
- platform: event
event_data:
code: 'OG' # Area Abierta
ri: '1'
- name: "Ajax USUARIO HUB A1"
unique_id: ajax.usuario.a1
icon: mdi:account
state: "{{trigger.event.data.message}}" # Lee el usuario que a hecho la accion
- sensor:
- name: "USUARIO A1"
icon: mdi:account
state: >
{% if is_state('sensor.ajax_usuario_hub_a1', '501') %}
Alberto Pro
{% elif is_state('sensor.ajax_usuario_hub_a1', '8') %}
Mando Reserva
{% elif is_state('sensor.ajax_usuario_hub_a1', '502') %}
Alberto Normal
{% else %}
Desconocido
{% endif %}
- trigger:
- platform: event
event_data:
ri: '2'
- platform: event
event_data:
code: 'OG' # Area Cerrada
ri: '2'
- name: "Ajax USUARIO HUB A2"
unique_id: ajax.usuario.a2
icon: mdi:account
- sensor:
- name: "USUARIO A2"
icon: mdi:account
state: >
{% if is_state('sensor.ajax_usuario_hub_a2', '501') %}
Alberto Pro
{% elif is_state('sensor.ajax_usuario_hub_a2', '8') %}
Mando Reserva
{% elif is_state('sensor.ajax_usuario_hub_a2', '502') %}
Alberto Normal
{% else %}
Desconocido
{% endif %}
- trigger:
- platform: event
event_data:
ri: '3'
- platform: event
event_data:
ri: '3'
- name: "Ajax USUARIO HUB A3"
icon: mdi:account
- sensor:
- name: "USUARIO A3"
icon: mdi:account
state: >
{% if is_state('sensor.ajax_usuario_hub_a3', '501') %}
Alberto Pro
{% elif is_state('sensor.ajax_usuario_hub_a3', '8') %}
Mando Reserva
{% elif is_state('sensor.ajax_usuario_hub_a3', '502') %}
Alberto Normal
{% else %}
Desconocido
{% endif %}
#### HUB ARMADO Area 1
- trigger:
- id: 'armada'
platform: event
event_data:
code: 'CG' # Area armada
ri: '1'
- id: 'desarmada'
platform: event
event_data:
code: 'OG' # Area desarmada
ri: '1'
binary_sensor:
- name: Armada A1 Exterior
state: "{{ trigger.id == 'armada' }}"
icon: mdi:shield-home
#### HUB ARMADO Area 2
- trigger:
- id: 'armada'
platform: event
event_data:
code: 'CG' # Armada Area
ri: '2'
- id: 'desarmada'
platform: event
event_data:
code: 'OG' # Desarmada Area
ri: '2'
binary_sensor:
- name: Armada A2 Interior
#### HUB ARMADO Area 3
- trigger:
- id: 'armada'
platform: event
event_data:
ri: '3'
- id: 'desarmada'
platform: event
event_data:
ri: '3'
binary_sensor:
- name: Armada A3 Trastero
#### HUB ARMADO Areas Noche
- trigger:
- platform: event
event_data:
code: "NL" # Armado Areas noche
- platform: event
event_data:
code: 'NP' # Desarmada Areas noche
binary_sensor:
- name: Armado Modo Noche
unique_id: ajax.modo.noche
state: "{{ trigger.event.data.code == 'NL' }}"
icon: mdi:shield-moon
#### HUB ESTADO AREA 1
- sensor:
- name: "A1 Exterior"
unique_id: ajax.estado.area1
icon: mdi:pool
state: >
{% if is_state('binary_sensor.armado_modo_noche', 'on') %}
Armado modo Noche por {{ states('sensor.usuario_a1') }}
{% elif state_attr('binary_sensor.armado_modo_noche', 'off') %}
Desarmada por {{ states('sensor.usuario_a1') }}
{% elif is_state('binary_sensor.armada_a1_exterior', 'on') %}
Armada A1 por {{ states('sensor.usuario_a1') }}
{% elif is_state('binary_sensor.armada_a1_exterior', 'off') %}
Desarmada A1 por {{ states('sensor.usuario_a1') }}
{% else %}
Desconocido
{% endif %}
#### HUB ESTADO AREA 2
- sensor:
- name: "A2 Interior"
unique_id: ajax.estado.area2
icon: mdi:home-circle-outline
state: >
Armado modo Noche por {{ states('sensor.usuario_a2') }}
Desarmada por {{ states('sensor.usuario_a2') }}
{% elif is_state('binary_sensor.armada_a2_interior', 'on') %}
Armada por {{ states('sensor.usuario_a2') }}
{% elif is_state('binary_sensor.armada_a2_interior', 'off') %}
{% else %}
Desconocido
{% endif %}
#### HUB ESTADO AREA 3
- sensor:
- name: "A3 Trasero"
unique_id: ajax.estado.area3
state: >
Armado modo Noche por {{ states('sensor.usuario_a3') }}
Desarmada por {{ states('sensor.usuario_a3') }}
{% elif is_state('binary_sensor.armada_a3_trastero', 'on') %}
Armada por {{ states('sensor.usuario_a3') }}
{% elif is_state('binary_sensor.armada_a3_trastero', 'off') %}
{% else %}
Desconocido
{% endif %}
##---------ZONA: 1 --------------------------- (MULTITRANSMITER TAMPER)
- trigger:
- platform: event
event_type: sia_event_5000_2222 # puerto y abonado
event_data:
code: 'TA' # Tamper abierto
message: '1' # Numero de dispositivo
- platform: event
event_data:
code: 'TR' # Tamper Cerrado
binary_sensor:
- name: Multitransmiter TAMPER (Z1)
device_class: safety
state: "{{ trigger.event.data.code == 'TA' }}"
##---------ZONA: 1 --------------------------- (MULTITRANSMITER FALLO 220V)
- trigger:
- platform: event
event_data:
code: 'AT' # 220 fallo
- platform: event
event_data:
code: 'AR' # 220 restauracion
binary_sensor:
- name: Multitransmiter FALLO 220V (Z1)
device_class: power
state: "{{ trigger.event.data.code == 'AT' }}"
##---------ZONA: 2 --------------------------- (BOCA 1)
- trigger:
- id: 'on'
platform: event
event_data:
code: 'BA' # ALARMA zona
message: '2' # Numero de dispositivo
- id: 'off'
platform: event
event_data:
code: 'BR' # RESTAURACION zona
- platform: homeassistant
event: start
- platform: event
event_type: event_template_reloaded
binary_sensor:
- name: Z1 (ZX2)
device_class: motion
state: "{{ trigger.id == 'on' }}"
auto_off: 10
##---------ZONA: 3 --------------------------- (BOCA 2)
- trigger:
- id: 'on'
platform: event
event_data:
message: '3' # Numero de dispositivo
- id: 'off'
platform: event
event_data:
event: start
- platform: event
binary_sensor:
- name: Z2 (ZX3)
auto_off: 10
##---------ZONA: 4 --------------------------- (BOCA 3)
- trigger:
- id: 'on'
platform: event
event_data:
message: '4' # Numero de dispositivo
- id: 'off'
platform: event
event_data:
event: start
- platform: event
binary_sensor:
- name: Z3 (ZX4)
auto_off: 10
##---------ZONA: 5 --------------------------- (BOCA 4)
- trigger:
- id: 'on'
platform: event
event_data:
message: '5' # Numero de dispositivo
- id: 'off'
platform: event
event_data:
event: start
- platform: event
binary_sensor:
- name: Z4 (ZX5)
auto_off: 10
##----- Alarma disparada ----
- trigger:
- id: 'on'
platform: event
event_data:
- id: 'off'
platform: event
event_data:
code: 'OG' # Area desactivada
binary_sensor:
- name: "Alarma disparada"
icon: mdi:alarm-panel
auto_off: 10
It was due to a setting in my router (blocked port). I changed the port and it solved my issue!
