I managed to find the component. So far so good.
But my errorlog i filled with these;
2020-06-12 14:31:32 WARNING (MainThread) [pysiaalarm.base_sia_server] Last line:D02C0054"*NULL"0000L0#346EC[80A0860CF3623F2C505289ABE45A71118B3D7544D08FF1B32208564114D6AE98 could not be parsed as a SIAEvent.
That is a strange one, it doesnât follow the exact SIA pattern, that should be 4 characters CRC, four characters length, and then either *SIA-DCS for a encrypted message or SIA-DCS for unencrypted, yours shows NULL instead of SIA-DCS which is why the parsing fails, what kind of system is it?
That is great to hear @Mathias_Jensen, seems that was in a bug in or did you put your Ajax to Ajax Translator instead of SIA Protocol? Let me know, there might be more information through that channel, so I might want to investigate that one!
Well, the custom component integrates it, it is waiting for review before being merged into HA itself, the used protocol does not allow arming/disarming so that is not going to happen with the current method, maybe if ajax releases an API that might become possible.
Such an amazing component you have here - controlling things based on the alarm status is awesome. Thanks for your hard work on this!
Iâm running v. 0.2.4 and everything is working perfectly. Should I remove this integration and re-configure it all once the integration can be found under Supervisor > Add-on store?
This looks amazing, but I have a different brand Alarm system that im testing with your component. I use an ATS1000A-IP-SM Alarm. And it looks like it supports (?) SIA:
But i am not able to get any messages from the Alarm to Home Assistant. The only logging I get is:
2020-06-18 10:53:01 ERROR (Thread-3) [custom_components.sia] TCP: Handle: last line gave error: [Errno 104] Connection reset by peer
2020-06-18 10:53:09 ERROR (Thread-3) [custom_components.sia] TCP: Handle: last line gave error: [Errno 104] Connection reset by peer
2020-06-18 10:53:36 ERROR (Thread-3) [custom_components.sia] TCP: Handle: last line gave error: [Errno 104] Connection reset by peer
There is another great piece of software developed here; https://github.com/tdeckers/utcar, (but this works via XSIA). I can get messages read from it:
Very cool that youâre testing it, it seems it works but the last step of the sia protocol is to send an acknowledgement back to the sending device (your alarm) and when that device does not wait for the response the connection reset message is usually given. Which version of the sia component are you using? and please turn on debug logging for the component (in your configuration.yaml add this
I enabled the debug logging already. I tried both OH+SIA and OH+XSIA but with the same results. I am not sure what the exact SIA version it is that the alarm uses and if it is compatible. Can we check if the messages are correct somehow? The only logs i get are those:
2020-06-18 15:53:01 ERROR (Thread-3) [custom_components.sia] TCP: Handle: last line gave error: [Errno 104] Connection reset by peer
2020-06-18 15:53:09 ERROR (Thread-3) [custom_components.sia] TCP: Handle: last line gave error: [Errno 104] Connection reset by peer
2020-06-18 15:53:36 ERROR (Thread-3) [custom_components.sia] TCP: Handle: last line gave error: [Errno 104] Connection reset by peer
No other logs are displayed. Can it be that my alarm does not do anything with the acknowledgement or it is send to late?
If i look at the utcar software there is also something of an ack mechanism in there:
so the component actually waits for messages from the alarm system, so if there is nothing happening, then you wouldnât see anything change, that is how the protocol works. However in the ajax system that I have there is a setting for the ping_interval, which is basically the alarm system letting a monitoring station now it is still online, is that set somewhere in your alarm as well?
You can see that in the Utcar docker container i used, there is a âHeartbeatâ recieved every minute so the Alarm works. Should that not be visible in the component logging normally?
I also tried setting/ triggering the alarm but no go .
