that is super cool! thanks for sharing @akarpenkoua
I have some issues after upgrading to 112.1 and newly released Ajax integration 0.3.2. When I hover the red icon it says (translated) âResetâ.
The status icon for the alarm that I had in my dashboard that usually says âArmed/Disarmedâ now says âUnavailableâ.
Not really sure how to help identify this as I havenât seen anything when looking in the logs, but if there is any information I can provide please let me know.
Edit: I can also see that in the Ajax app it says âNot connectedâ when looking under the Hub and (translated) âSecurity centralâ.
Edit again: Downgrading to 0.2.4 solved the issue.
Hi, I just upgraded my own to 0.112.1 and with SIA 0.3.2 and everything works, you might have to make a slight change in your system so it retries the connection, I have heard that sometimes if a alarm system canât reach the server (in this case HA) it doesnât retry but just goes offline, so if the upgrade took a long time and it wasnât able to reach it, but that doesnât explain why downgrading does work, could you run some logging for it?
I have a small database so upgrade to 112.1 went fast. Iâm happy to debug if you explain it to me like you would explain to your grandma since Iâve never tried debugging before
sure, enable this in your configuration.yaml https://www.home-assistant.io/integrations/logger/
with custom_components.sia: debug
as one of the rows, and then in your Logs (now in Configuration under Logs) you should be able to see something going on and make sure to reupgrade to 0.3.2 because the old one I donât want to do something with anymore.
Like this?
logger:
default: info
logs:
Under Configuration > Logs there is nothing SIA related. There are 335 entries in the complete log but canât say I found anything alerting. What should I look for?
Noticed now that this one went from âDisconnectedâ to âConnectedâ now all of a sudden:
that means there is nothing coming from the alarm, maybe put default to warning to you only see sia. and then maybe try to make a slight settings change in your alarm
Changed debug setting to âwarningâ and now the log only has the following about SIA:
2020-07-03 17:11:10 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sia which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
In the Ajax app the connection is âDisconnectedâ again now.
I changed the configuration setting âAccountâ just to âtouchâ the settings but no difference.
Configuration.yaml:
sia:
port: 8124
hubs:
- name: AJAX
account: BEA
ping_interval: 5
zones:
- zone: 1
sensors:
- alarm
- smoke
sorry, for the new component you have to setup through a config flow, if you go to integrations and add it there it should connect, you can delete the config entry in configuration.
My bad, I must have missed the instructions completely, sorry for that. Works like a charm again
Good to hear!
@eavanvalkenburg Iâve just updated to the new version of your SIA plugin and it works really great! Iâve got a question though, how do I customize the new alarm component? When I press any of the buttons I get the following error pop up:
Failed to call service alarm_control_panel/alarm_arm_away. unsupported operand type(s) for &: 'NoneType' and 'int'
Before the update I had manually created an alarm control and then used simple automations such as:
automation:
- alias: "Alarm: Arm away"
- platform: event
event_type: call_service
event_data:
domain: alarm_control_panel
service: alarm_arm_away
- service: mqtt.publish
data_template:
topic: ajax/alarm
payload: arm
It still works with the new one, but the error pops up every time you press the button(s).
Is the solution to not use the included alarm component and create a custom one where I keep the state in sync manually?
Hi all,
with this Alarm and this integration, is it possible to armed/disarmed the alarm with Home assistant ?
No, you can only read the status since Ajax doesnât allow anything else. But that part opens up for really cool stuff and works great
Ok thank you!
I was thinking⌠if you can hide a remote, maybe a switchbot permits to control the alarm with home assistant !
@eavanvalkenburg Iâve updated to the SIA integration. But now my Ajax system is visible after a reboot for about one minute and then it goes offline. In the Ajax app I can see the âmeldkamerâ going to red (no connection).
I donât use encryption. I enter the port number and account number. nr of zones is 3 interval is 1 minute.
Am I missing something? It worked before in the older version.
Did you setup through the config flow?
yes I did? I entered the same data as I had in my config.
# sia:
# port: 158
# hubs:
# - name: Thuis
# account: 158
# ping_interval: 1
# zones:
# - zone: 3
# name: Thuis
# sensors:
# - alarm
# - moisture
This was in my config.
In the flow I had to select 3 zones (Only zone 3 is needed)
hmm, I hadnât realized you might have a non 1 starting zone, but I guess it will work, just a lot of sensors to disable in that case, can I ask why it is setup that way? and the port is a bit low, I use a different approach to networking in the new version and usually open ports should be in the 1000+ range, I tend to use 8125 (8123 is HA itself), so maybe that causes an issue, could you test with a higher port and turn on logging when you do?
