I noticed an alert on my HA dashboard that Genie is changing their API and it will break the connection to HA but that they are working on a new integration but no date listed on when it will be available. Had anyone heard anything on a timeframe?
man, we need to put more pressure on them. Saying “We are working on it but have no timeframe” seems kind of unacceptable considering that they just remotely crippled a product that I paid for and own.
kinda a crappy solution but an easy trick around this is to add your garage door to smart things, then the smart things integration in HA. The door should show up
I just installed home bridge in a container and added the home bridge-genie-aladdin-connect addon, logged into it which allowed home bridge to create the two HomeKit devices(one for each garage) and then in HA I had the devices discovered because I already had HomeKit integration created(which is sounds like you do also).
This worked for me as well, thanks for the idea @bcre3306!
I imagine if Genie doesn’t follow through with an updated integration, we could rewrite the old integration to emulate the Aladdin Connect mobile app like the Homebridge plugin does.
I have homekit bridge running on my NAS. HA has it under integrations but I dont see the garage door devices. If I login to my homekit bridge I see the garage doors but HA doesnt see them.
Ensure you have homebridge-genie-aladdin-connect installed. Set that up, then reboot the whole Home Assistant instance. I recall not seeing them until after the reboot.
Could not create mDNS advertisement. The HAP-Server won't be discoverable: Error: No such interface found
[3/7/2024, 9:53:06 PM] [Garage Doors] Restoring existing accessory from cache: Door 2
[3/7/2024, 9:53:06 PM] [Garage Doors] Restoring existing accessory from cache: Door 1
[3/7/2024, 9:53:06 PM] [Garage Doors] Restoring existing accessory from cache: Door 3```
