Request for a new component to integrate with AlarmDecoder (http://www.alarmdecoder.com/) which supports Ademco / Honeywell and DSC alarm panels. AlarmDecoder has devices for either serial, USB or RaspberryPi.
There is already a python project to interact with the devices on github, created and maintained by the AlarmDecoder team.
I haven’t purchased one yet, but I was planning to when I was considering OpenHAB, which has a binding for AlarmDecoder.
Same here. I just got an AD2PI device and got it to work with my Raspberry Pi (I have a legacy Vista 20P already wired, that came with the house). I am in the process of using Home Assistant for my home automation needs and I am wondering how to “connect/integrate” this device with Home Assistant.
I am not so sure if it is possible to connect it via MQTT. Any help or guidance will be highly appreciated.
It will cost you some money, but I also have a vista 20p, and I have it fully integrated into home-assistant. I use an envisalink evl3. I put together the envisalink component. It tracks all zones, arm/disarm, and also shows the alpha message that you’d see if you have a full alphanumeric keypad. I currently have an automation to arm/disarm whenever my phone comes within Bluetooth range of my ha server, I also get a text message if my alarm is triggered for more than 30 seconds.
I have been working on adding native support for AD, but wanted to see what you guys might be looking for.
Right now I have:
alarmdevice component
alarm_control_panel shows status and allows arm/disarm
binary_sensor for all zones configured
sensor for a panel display, shows the text from the keypad display. This is off by default, enabled via the config.
I have it working with my AD2PI device using the ser2sock with HA on a different machine. It connects to my alarm, configured with doors, windows and motion sensors all updating in real time and automation is working to send email on arm/disarm events.
What else would you guys want to see or something I might have missed.
My TODO list:
Fix arm away vs arm home (currently all arm away)
More testing, need to handle AD2PI disappearing or socket errors
Adding some optional groups like: group.all_alarmdevice_zones and group.all_alarmdevice_X where X is motion, doors, windows, smoke, etc
How is this project going? I was looking into buying sensors when my friend told me to save my money and try to utilize my pre-existing equipment with the use of alarm decoder.
Here are my changes here… Still working on hacking in allowing network or serial support within 1 file. For now, its a second file. https://github.com/gottsman/ad2ha
My panel is a dinosaur Vista 10SE without wireless so it lacks some of the newer RFX features. I will upgrade one day. I am stuck with the on_message property.
Bad news, few days after I posted, my laptop went belly up and I thought I lost everything. Luckily I was able to back up everything before it was completely dead. Now I am in the process of getting another laptop ordered.
Good news is I have a working VirtualBox image again with my source on another machine. This weekend I ported the code to the asyncio model, with the exception of the extra groups. For some reason I can’t get them working, so I might scrap them for now. If all goes well, I will try to open a PR this week/weekend to start the process to get it added.
Sorry for the silly question… I have a Vista 20P with the AD2PI, so far I got it to “work” by reading the values as a REST device. Obviously I cannot arm disarm the alarms… so In order to use your MQTT solution, do I need to clone the code and install it on the same raspberry pi that I am running my alarmdecoder? Thanks for your help!
Thanks for setting this up. I installed it on my system using an ad2usb and ser2sock and it seems to works well. I know I could directly use the serial conntection, but I like ser2sock because it lets me share the ad2usb with HA and a virtual keypad
I am sad that this platform did not make it to this release… what it needs to be done to be accepted? We are talking about a popular component that has support on OpenHab, Smarthings and Vera… Please include it!!
I am working on the changes requested by the code reviewer. Once that is done, I am betting it will be in the following release. I figured it would take 1-3 releases cycles before accepted, so it is right on target right now.
