Well you can put the entities in a group and run the alert off that. You lose the ability to determine which member of the group started the alert though.
Hi @xrapidx, I just came across this topic.
Not sure if you’ve resolved this by now but I did this by combining my doors into a group and setting up some shamelessly copied and amended code for the actual notification:
alert:
door_open_for_long:
name: A door is still open!
entity_id: group.alarm_doors
state: 'on' # Optional, 'on' is the default value
message: >-
{%- if is_state("group.alarm_all", "off") %}
All doors and windows are CLOSED!
{% else %}
Open are: {%- set entities = [states.binary_sensor.konnected_41, states.binary_sensor.konnected_44, states.binary_sensor.konnected_25, states.binary_sensor.konnected_24, states.binary_sensor.konnected_32 ] -%}
{%- for entity in entities -%}
{%- if entity.state == 'on' %}
- {{ entity.name }}
{%- endif %}
{%- endfor -%}
{%- endif %}
repeat: 5
can_acknowledge: true # Optional, default is true
skip_first: true # Optional, false is the default
notifiers:
- mobile_app
good workaround but a fairly strange limitation of the alert implementation. is there an enahcement/feature request or new information to use multiple entities for the alert implementation?
It’s the only one I’ve found so far and it works reliably form me so I stopped looking for other options and keep re-using it for other alerts as well.
