Alexa can't find exposed devices
did anyone work this out ?? Missing Alexa …
Sadly, no.
I’m having a crack at Haaska, will let you know if I make it work
I got Haaska working, I posted my results in this thread : Haaska Echo Error
Thanks. I guess I’ll install Haaska soon.
Ok, it’s been a month now, has anyone found the solution? I have reinstalled Hassio, tried two different RPI3’s and two Sd cards. Yelled at Echo to discover and I’m getting sick of Her voice now.
Also, tried different variations of;
emulated_hue:
host_ip: 192.168.1.59
listen_port: 8300
I am able to see the devices listed and the xml. I’d rather not have to go back to Hassbian, but if it works…
Any assistance would be greatly appreciated, as I want to get the system back online before the family and guests arrive for the holidays.
I’m not sure if I’m missing something people are trying to do but I just setup emulated hue the other day and have no issues getting her to see devices… here is my config (in reference to a specific device but I have no issues getting this to appear in my Alexa devices) TP-Link Smart Plug HS100 w/Alexa
Thank You Bartem for replying.
Yep, I have read several comments about doing this. I have tried both
expose_by_default: true
and
expose_by_default: false
then added just one light as exposed.
Alexa ONLY see’s the actual hue lights controlled via the hue hub.
Did anyone had any luck how to fix this? She cant find my devices.
Has it ever worked for you? At the bottom of the page https://www.home-assistant.io/components/emulated_hue/ is a troubleshooting section … going to the URL listed will at least give you an idea if the emulated hue is working and just not exposing devices or if it is not working at all.
Okay, so after having this problem again i found the solution, When you try to link home assistant to Alexa, When you log in to the skills-store-amazon.com make sure to have the first letter in lower case. Helped me 2 times now.
First letter of what?. I am having the same issue, but everything is all lower case.
