I am trying to set up the Alexa Media Player integration from HACS. The installation via HACS ran without any problems. Then when I want to add the integration, I enter my Amazon credentials and click submit.
Hi all. I have the same issue and no idea how to fix. I’ve tried with us and oz accounts. I use a Pi but that should not be an issue
posted this on the facebook page-
Hi all, I’m trying to get Alexa media player working so I can see my echo devices in HA. I do everything as instructed (OTP, key etc) but then once I get to /auth/alexamedia/proxyverify I get a 404 error. Any idea what I’m doing wrong?
Hi all,
did you find a solution for this topic? I have the same issue, HA runs on a Synology DS220+, my cloudflare tunnel also works but the Alexa media player integration alsways ends with the 404 failure…
I have the exact same issue, wanted to add the Alexa Media Player in my Home Assistant, and felt on the 404 not found page.
Since this post is now months old, should I understand the feature is broken and will not be repaired? I can’t imagine letting people with no solution for months …
Okay, found the solution on reddit where I found a link to a video from Mark Watt Tech, you should enable 2FA authentication on your Amazon account, then it works. At least it worked for me !
No im having same issues, ive been using the Alexa media player for well over a year but the last 2 months i cannot reconnect? i just keep getting 404: Not Found when trying? anyone else having frustrating issues. Does not help that the Alexa integration in home assistant is not easy to understand.
Just to add I’ve also hit a similar problem. Running HA in Docker, 2FV is enabled. After entering the 2FV code and continuing, it opens a webpage at https:///auth/alexamedia/proxy/errors/validateCaptcha which gives a 404 not found.
