miki3421
(Miki3421)
December 21, 2020, 2:50pm
1
Hello, this is my first post here, so apologies if I’m not in the proper section.
I’m trying to visualize in this lovelace card custom:circle-sensor-card
I’ve configured as below, but it’s not working.
type: 'custom:circle-sensor-card'
entity: sensor.echo_dot_di_michele_next_timer
attribute: >
{{ ((state_attr('sensor.echo_dot_di_michele_next_timer', 'sorted_active') |
from_json)[index][1].remainingTime/ 1000)| round(0) }}
Can someone help me ?
Thanks so much
I would recommend to create a template sensor in your configuration.yaml first.
timer_wohnzimmer:
friendly_name: "Timer Wohnzimmer"
value_template: >
{% if states('sensor.echo_wohnzimmer_next_timer') != 'unavailable' %}
{{ ((as_timestamp(states('sensor.echo_wohnzimmer_next_timer')) - as_timestamp(now()))/60) | int + 1 }}
{% else %}
0
{% endif %}
unit_of_measurement: Minutes
icon_template: hass:timer
Then you can use the resulting entity in any lovelace card you like.
miki3421
(Miki3421)
December 21, 2020, 3:18pm
3
Thanks Andrej,
but I want use the sensor that is exposed by the integration with Alexa Echo Dot.
i just need to understand the code that I need to insert on the card configuration.
This won’t work without adding the template sensor first. After that, you can use the resulting entity for your lovelace card. In the code I showed, the template sensor would be named sensor.timer_wohnzimmer. Then you can use the following card:
min: 0
max: 100
You can change the max value.
miki3421
(Miki3421)
December 21, 2020, 3:38pm
5
i’ve just copied and pasted your code in the configuration.yaml and I’ve this error on the check.
Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See /home/pi/.homeassistant/configuration.yaml, line 34).
I have another session in the file called sensor:
Witch platform I need to use?
Without seeing what you did in configuration.yaml, I can’t help you.
miki3421
(Miki3421)
December 21, 2020, 7:38pm
7
this is the sensor part
- platform: systemmonitor
resources:
- type: disk_use_percent
- type: processor_use
- type: processor_temperature
- platform: time_date
display_options:
- 'time'
- 'date'
- 'date_time'
- 'date_time_utc'
- 'date_time_iso'
- 'time_date'
- 'time_utc'
- 'beat'
timer_wohnzimmer:
value_template: >
{% else %}
0
{% endif %}
Sorry, there was something missing in my reply. Here is the correct code:
resources:
display_options:
- 'time'
- 'date'
- 'date_time'
- 'date_time_utc'
- 'date_time_iso'
- 'time_date'
- 'time_utc'
- 'beat'
sensors:
timer_wohnzimmer:
value_template: >
{% if states('sensor.echo_dot_di_michele_next_timer') != 'unavailable' %}
{{ ((as_timestamp(states('sensor.echo_dot_di_michele_next_timer')) - as_timestamp(now()))/60) | int + 1 }}
{% else %}
0
{% endif %}
miki3421
(Miki3421)
December 21, 2020, 8:11pm
9
thanks!!!
Now configuration is ok and I have the new entity
however the result is this one
with this code in the card
min: 0
max: 100
font_style:
color: red
font-size: 1.5em
text-shadow: 2px 2px black
font-family: Trebuchet MS
miki3421
(Miki3421)
December 21, 2020, 8:15pm
10
what I want to display is the count-down like this one.
Please replace this with your template sensor. In my code, it was named sensor.timer_wohnzimmer.
miki3421
(Miki3421)
December 21, 2020, 8:36pm
12
Super!!!
with this code this is result!!! Amazing thanks so much
Do you think is possibile also to show the seconds? Or is it too much?
entity: sensor.timer_wohnzimmer
min: 0
max: 60
font_style:
color: Black
font-size: 4em
font-family: Arial
If it should only be a number that should be displayed, then you have to decide between seconds and minutes. Otherwise you have to calculate a timestamp and pass it to the card. I don’t know if the card can visualize timestamps.
Just to confirm you all are getting the timer from the Alexa install in HACS correct?
miki3421
(Miki3421)
December 23, 2020, 9:28am
16
no problem, perfect like this… thanks for your help and have a good holiday.
Anyone having issues with the timer? Used to say “unavailable “ when the timer was done, now it goes negative. And has issues with multiple timers. Screenshot below.
If I set multiple timers the first one just goes below 0 and never shows the second one.
FYI I fixed this had to reset my echo dot.
Hi there,
I use several Dots in my flat - if I understand your code correct, i have to create for each alexa this code?
Eg. Wohnzimmer, Küche, Bad etc?
Or is there a way to include all Alexa dots in one code?
miki3421
(Miki3421)
January 17, 2021, 5:51pm
19
Correct you need to create a sensor for each Echo Dot.
okay thanks…
can you tell me, where I can find the correct names of the echos to add them to the script?
