I think there is no topic just for Transmission Openvpn addon, so I am posting here. I am still trying to figure out why my HA crashes when running torrents (Help needed: Running Transmission/qBittorrent add-on crashes the Home Assistant OS almost instantly). I checked the logs of Transmission and see some strange errors there, so I want to share the logs:
- It looks like Transmission starts “update to v3” every time I run it - why?
- There is a warning that TRANSMISSION_HOME is not set to the default location, but I did not change it. Should I follow the instructions to move it?
- Two more warnings regarding NordVPN config - NORDVPN_COUNTRY empty and NORDVPN_CATEGORY empty.
Starting...
/etc/cont-init.d/00-banner.sh: executing
Add-on: Transmission Openvpn
Docker container running Transmission torrent client with WebUI over an OpenVPN tunnel
Add-on version: v5.2.0
You are running the latest version of this add-on.
System: Home Assistant OS 11.1 (aarch64 / odroid-n2)
Home Assistant Core: 2023.10.5
Home Assistant Supervisor: 2023.10.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums
Provided by: https://github.com/alexbelgium/hassio-addons
Defining permissions for main user :
User UID: 0
User GID : 0
/etc/cont-init.d/00-local_mounts.sh: executing
/etc/cont-init.d/00-smb_mounts.sh: executing
/etc/cont-init.d/01-custom_script.sh: executing
[12:03:05] INFO: Execute /config/addons_autoscripts/transmission-openvpn.sh if existing
[12:03:05] INFO: ... no script found
/etc/cont-init.d/32-nginx_ingress.sh: executing
/etc/cont-init.d/90-dns_set.sh: executing
[12:03:06] INFO: DNS SERVERS set to 1.1.1.1 8.8.8.8
/etc/cont-init.d/99-run.sh: executing
[12:03:06] INFO: Updating transmission to v3
[12:03:06] WARNING: If your previous version was v2, remove and add torrents again
--2023-10-28 12:03:06-- https://keyserver.ubuntu.com/pks/lookup?op=get&search=0xa37da909ae70535824d82620976b5901365c5ca1
Resolving keyserver.ubuntu.com (keyserver.ubuntu.com)... 185.125.188.26, 185.125.188.27, 2620:2d:4000:1007::70c, ...
Connecting to keyserver.ubuntu.com (keyserver.ubuntu.com)|185.125.188.26|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1804 (1.8K) [text/plain]
Saving to: '976b5901365c5ca1.key'
0K . 100% 666M=0s
2023-10-28 12:03:06 (666 MB/s) - '976b5901365c5ca1.key' saved [1804/1804]
debconf: delaying package configuration, since apt-utils is not installed
[12:03:11] INFO: Exporting variables
DEBUG=false
DNS_server=8.8.8.8,1.1.1.1
LOCAL_NETWORK=192.168.178.0/24
OPENVPN_PASSWORD=xxxxxxxxxxxxxxxxx
OPENVPN_PROVIDER=nordvpn
OPENVPN_USERNAME=xxxxxxxxxxxxxxxxx
PGID=0
PUID=0
TRANSMISSION_DOWNLOAD_DIR=/media/Transmission
TRANSMISSION_HOME=/config/addons_config/transmission
TRANSMISSION_INCOMPLETE_DIR=/media/Transmission/incomplete
TRANSMISSION_V3_UPDATE=true
TRANSMISSION_WATCH_DIR=/media/Transmission/watch_dir
TRANSMISSION_WEB_UI=flood-for-transmission
Updating variables
Using PUID 0 and PGID 0
[12:03:15] INFO: Custom openvpn provider not selected, the provider nordvpn will be used
[12:03:16] INFO: Running userscript
Transmission will run as
User name: root
User uid: 0
User gid: 0
[12:03:16] INFO: Starting app
Starting container with revision: 48299204d160d2d699ce6dd5ccdfcba0ecf13c83
TRANSMISSION_HOME is currently set to: /config/addons_config/transmission
WARNING: TRANSMISSION_HOME is not set to the default /config/addons_config/transmission_openvpn/transmission-home, this is not recommended.
TRANSMISSION_HOME should be set to /config/addons_config/transmission_openvpn/transmission-home OR another custom directory on /config/addons_config/transmission_openvpn/<directory>
If you would like to migrate your existing TRANSMISSION_HOME, please stop the container, add volume /config/addons_config/transmission_openvpn and move the transmission-home directory there.
Using OpenVPN provider: NORDVPN
Running with VPN_CONFIG_SOURCE auto
Provider NORDVPN has a bundled setup script. Defaulting to internal config
Executing setup script for nordvpn
/etc/openvpn/nordvpn/..
INFO: OVPN: Checking curl installation
INFO: OVPN: DNS resolution ok
INFO: OVPN: ok, configurations download site reachable
INFO: OVPN: Removing existing configs in /etc/openvpn/nordvpn
Checking NORDPVN API responses
INFO: OVPN:Selecting the best server...
WARNING: OVPN: empty or invalid NORDVPN_COUNTRY (value=). Ignoring this parameter. Possible values are:AL,AR,AU,AT,BE,BA,BR,BG,CA,CL,CO,CR,HR,CY,CZ,DK,EE,FI,FR,GE,DE,GR,HK,HU,IS,ID,IE,IL,IT,JP,LV,LT,LU,MY,MX,MD,NL,NZ,MK,NO,PL,PT,RO,RS,SG,SK,SI,ZA,KR,ES,SE,CH,TW,TH,TR,UA,AE,GB,US,VN, or Albania,Argentina,Australia,Austria,Belgium,Bosnia and Herzegovina,Brazil,Bulgaria,Canada,Chile,Colombia,Costa Rica,Croatia,Cyprus,Czech Republic,Denmark,Estonia,Finland,France,Georgia,Germany,Greece,Hong Kong,Hungary,Iceland,Indonesia,Ireland,Israel,Italy,Japan,Latvia,Lithuania,Luxembourg,Malaysia,Mexico,Moldova,Netherlands,New Zealand,North Macedonia,Norway,Poland,Portugal,Romania,Serbia,Singapore,Slovakia,Slovenia,South Africa,South Korea,Spain,Sweden,Switzerland,Taiwan,Thailand,Turkey,Ukraine,United Arab Emirates,United Kingdom,United States,Vietnam,. Please check https://haugene.github.io/docker-transmission-openvpn/provider-specific/#nordvpn
WARNING: OVPN: empty or invalid NORDVPN_CATEGORY (value=). ignoring this parameter. Possible values are: legacy_double_vpn,legacy_onion_over_vpn,legacy_ultra_fast_tv,legacy_anti_ddos,legacy_dedicated_ip,legacy_standard,legacy_netflix_usa,legacy_p2p,legacy_obfuscated_servers,europe,the_americas,asia_pacific,africa_the_middle_east_and_india,anycast-dns,geo_dns,grafana,kapacitor,legacy_socks5_proxy,fastnetmon,. Please check https://haugene.github.io/docker-transmission-openvpn/provider-specific/#nordvpn
INFO: OVPN:Searching for technology: openvpn_tcp
