thanks for the info! I’ll have a look
It didn’t work. The path is:
/config/addons_config/fireflyiii_data_importer/configurations
ANd I added this also, restart the add-on but no pulldown…
in the configuration folder I have add the 2 json files I use for the import
* Store the files in `storage/configurations`
* Mount a local directory to the `/var/www/html/storage/configurations` directory in Docker.
* Change the `JSON_CONFIGURATION_DIR` to any custom directory (mount it if you want to), and place them there.
Is the earth for the JSON_CONFIGURATION_DIR link to /var/www/html/storage/configurations
EDIT:
Using config file found in /config/addons_config/fireflyiii_data_importer/config.yaml
Config file is a valid yaml
config.yaml:
JSON_CONFIGURATION_DIR=config/addons_config/fireflyiii_data_importer/configurations
Have you tried JSON_CONFIGURATION_DIR: config/addons_config/fireflyiii_data_importer/configurations
My yaml interpreter looks at “:” symbols to export the env variables. Strange I didn’t think a = value was accepted by yaml I’ll have to modify the script
Mappings
Mapping gives you the ability to list keys with values. This is useful in cases where you are assigning a name or a property to a specific element.animal: pets
YAML Syntax | Grav Documentation
Solved it: (Fireflyiii Data Importer)
JSON_CONFIGURATION_DIR: /config/addons_config/fireflyiii_data_importer/configurations
This is the correct path.
Inside the configurations you add the json files for each bank you want to use it.
Restart Add-On and you’re done!
Thanks for sharing!
Hi, I’ve added a new automatic upload of the configurations files if they are stored in /config/addons_config/fireflyiii_data_importer/configurations (or whatever path you set in the addon config + /configurations at the end)
Btw, there seems to be another way of auto-import : https://github.com/alexbelgium/hassio-addons/issues/203
I think that is a method to import CSV files from you bank.
Can you please add Plex-Meta-Manager? It is supported bij linuxserver: linuxserver/plex-meta-manager - LinuxServer.io
Thank you
Hi I don’t have much time now but I’ve created a request on github to keep track of it here https://github.com/alexbelgium/hassio-addons/issues/206
As it is based on linuxserver it should be rather easy to adapt
Thank you
Hello, v1.0 is pushed. Please let me know how it goes ! At first run, a config.yml will be created. You’ll then need to customize the file in /config/addons_config/plex-meta-manager/config.yml according to the infos on the site, then restart. And then hopefully it should work
You will.become the Addon master sooner or later! You’re githhb has so many Addons at the moment
Ahah, thanks! But there will be a moment where I won’t be able to continue adding addons or it will take too long supporting them all… But as long as its good I continue
Unable to update the latest Transmission, get this in config:
22-02-22 23:29:11 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image db21ed7f/amd64-addon-transmission_ls:3.00-r2-ls109 to db21ed7f/amd64-addon-transmission_ls:3.00-r5-ls112
22-02-22 23:29:11 INFO (SyncWorker_4) [supervisor.docker.addon] Starting build for db21ed7f/amd64-addon-transmission_ls:3.00-r5-ls112
22-02-22 23:29:13 ERROR (SyncWorker_4) [supervisor.docker.addon] Can't build db21ed7f/amd64-addon-transmission_ls:3.00-r5-ls112: The command '/bin/sh -c sed -i "s|config|config/transmission|g" /etc/services.d/transmission/run && sed -i 's/bash/bashio/g' /etc/cont-init.d/10-adduser && sed -i 's/{PUID:-911}/(bashio::config "PUID")/g' /etc/cont-init.d/10-adduser && sed -i 's/{PGID:-911}/(bashio::config "PGID")/g' /etc/cont-init.d/10-adduser && ln -s /usr/share/transmission/web/style /transmission-web-control && ln -s /usr/share/transmission/web/images /transmission-web-control && ln -s /usr/share/transmission/web/javascript /transmission-web-control && ln -s /usr/share/transmission/web/index.html /transmission-web-control/index.original.html' returned a non-zero code: 1
22-02-22 23:29:13 ERROR (SyncWorker_4) [supervisor.docker.addon] Build log:
Step 1/23 : ARG BUILD_FROM
Step 2/23 : ARG BUILD_VERSION
Step 3/23 : FROM ${BUILD_FROM}
---> 6c28d3c47712
Step 4/23 : RUN sed -i "s|config|config/transmission|g" /etc/services.d/transmission/run && sed -i 's/bash/bashio/g' /etc/cont-init.d/10-adduser && sed -i 's/{PUID:-911}/(bashio::config "PUID")/g' /etc/cont-init.d/10-adduser && sed -i 's/{PGID:-911}/(bashio::config "PGID")/g' /etc/cont-init.d/10-adduser && ln -s /usr/share/transmission/web/style /transmission-web-control && ln -s /usr/share/transmission/web/images /transmission-web-control && ln -s /usr/share/transmission/web/javascript /transmission-web-control && ln -s /usr/share/transmission/web/index.html /transmission-web-control/index.original.html
---> Running in d2ac2565673d
ln: failed to create symbolic link '/transmission-web-control/style': File exists
Removing intermediate container d2ac2565673d
Not gonna pretend i understand what’s going wrong here.
Thanks, it’s actually easy : they merged in the upstream image a fix I had put in my on addon, so the code is now in duplicate I’ll publish a new version. Thanks!
Thank you so much for the addons, it’s all I ever needed for my Home Assistant, you made the OS x10 more useful with your work.
Portainer has been removed from the community add-on store, so I tried to install your portainer add-on today but it failed to start…
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-aaa_dockerfile_backup.sh: executing...
Executing script
[cont-init.d] 00-aaa_dockerfile_backup.sh: exited 22.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
Any ideas what the problem is?
Hi, mmh an invalid argument without error details. I’ve pushed a new version with debug mode turned on. Could you please update and copy paste the log here please? Thanks
Here you go:
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 30-nginx.sh: executing...
[cont-init.d] 30-nginx.sh: exited 0.
[cont-init.d] portainer.sh: executing...
[cont-init.d] portainer.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[23:32:18] INFO: Starting Portainer...
[services.d] done.
[23:32:18] INFO: Waiting for port 9000 to open...
[23:32:18] INFO: ... password set to default
[23:32:18] INFO: ... non-addon containers hidden
[23:32:18] INFO: ... portainer launched
INFO 2022/03/07 23:32:19 Encryption key file `portainer` not present
INFO 2022/03/07 23:32:19 Proceeding without encryption key
INFO 2022/03/07 23:32:19 Loading PortainerDB: portainer.db
level=info msg="2022/03/07 23:32:19 [INFO] [internal,ssl] [message: no cert files found, generating self signed ssl certificates]"
INFO 2022/03/07 23:32:19 Created admin user with the given password.
2022/03/07 23:32:19 server: Reverse tunnelling enabled
2022/03/07 23:32:19 server: Fingerprint 6f:b6:d9:19:bf:47:c2:6c:60:be:a0:0f:33:4c:57:d1
2022/03/07 23:32:19 server: Listening on 0.0.0.0:8000...
INFO 2022/03/07 23:32:19 [INFO] [cmd,main] Starting Portainer version 2.11.1
level=info msg="2022/03/07 23:32:19 [DEBUG] [chisel, monitoring] [check_interval_seconds: 10.000000] [message: starting tunnel management process]"
level=info msg="2022/03/07 23:32:19 [DEBUG] [internal,init] [message: start initialization monitor ]"
level=info msg="2022/03/07 23:32:19 [INFO] [http,server] [message: starting HTTPS server on port :9443]"
level=info msg="2022/03/07 23:32:19 [INFO] [http,server] [message: starting HTTP server on port 0.0.0.0:9000]"
[23:32:20] INFO: Starting NGinx...
EDIT:
I also now get this when I try to load portainer (port 9000) in browser:
ERR_SSL_PROTOCOL_ERROR
Whenever I do that, i get this showing in the logs:
[07/Mar/2022:23:33:05 +0000] 400 -(192.168.101.13) \x16\x03\x01\x02\x00\x01\x00\x01\xFC\x03\x03\x8F\x7Fn\xB9\xAE\xEFq\xDF\xDB>\x80\xFC\x88M\xF8\x88\xE7\x1D\xD3w\x18\xAB_\xC5\xF3\x839\x096=\x8F\xDB \xDF\x0B\xA8\x7F\xA5UT\xE93\xDB\x22z\x19\xEC\xB1BE\xF0\x88\x81\xC8+\x94\xFF\x92'\xCDm\x04\x90\x11\x0B\x00 \x1A\x1A\x13\x01\x13\x02\x13\x03\xC0+\xC0/\xC0,\xC00\xCC\xA9\xCC\xA8\xC0\x13\xC0\x14\x00\x9C\x00\x9D\x00/\x005\x01\x00\x01\x93\x9A\x9A\x00\x00\x00\x00\x00\x15\x00\x13\x00\x00\x10homeassistant-vm\x00\x17\x00\x00\xFF\x01\x00\x01\x00\x00 (-)
Hi, I’ll need a few more infos. As I understand :
- Initially you had an error message with “00-aaa_dockerfile_backup.sh: exited 22”, but now it starts correctly and you have the ERR_SSL_PROTOCOL_ERROR message ?
- Have you just accepted the error message and seen if you can still connect ? If you are using a self signed ssl certificate (as described in the log), then the certificate won’t match your url and you will have such an error. However, you can safely accept it.
- Have you tried to connect using Ingress instead of ip:port (by simply clicking open UI in HA) ?
- If you confirm that 2) and 3) don’t work, could you please post your full log? You’re missing the banner and steps before (the execution of the “00-aaa_dockerfile_backup.sh”)
Thanks!
EDIT : the ssl certificate is only used to connect to the internal portainer container. However, you need to access it from an http address - http://homeassistant.local:9000 . This is what causes your error message, and the message in portainer log (replicated on my system)
