Alfen Eve Single-Pro EV chargepoint controller via Node-Red
A while ago I wanted to have more control over my Alfen ChargePoint.
The firmware didn’t allow charging with ‘solar only’, and there was no ‘power-charge’ mode, to force hi-power charging if needed.
Then I stumbled on the topic from @hollie who started the same a while ago. : https://community.home-assistant.io/t/alfen-eve-pro-ev-chargepoint-interface-via-tcp-modbus
So if you’re more into scripts & automation, please check that topic !
Starting from his project, and the replies on that, I wanted to implement this fully in Node-Red.
In my case, I’m using 1fase 230V 32A charging (max 7.4kW)
What is needed :
  • A switch, for enabling power-charging : input_boolean.power_charge
  • Max powercharge current : input_number.max_powercharge_current : (0…32A) defines the max total current that can be drawn from the net during charge
  • Car Charge Ampere : input_number.car_charger_ampere : (in my case 5…30A) the values that are valid for sending to the chargepoint
Why 5A? when it’s below 6A but not 0A, the car won’t charge, but will stay ‘active’ and just pause the charging process.
in your configuration.yaml, you need to add the modbus part, and a template to make the chargepoint levels readable (credits @hollie )
template:
  - sensor:
      - name: mode3_sanitized
        state: "{{states('sensor.laadpaal_mode3_state').replace('\0','') }}"
      - name: chargepoint_status
        state: >
          {% set m3 = states('sensor.mode3_sanitized') %}
          {% if m3 in ['A', 'E'] %} available
          {% elif m3 in ['B1', 'B2', 'C1', 'D1'] %} connected
          {% elif m3 in ['C2', 'D2'] %} charging
          {% else %} {{ m3 }}
          {% endif %}
modbus:
  - name: laadpaal
    type: tcp
    host: 192.168.x.x
    port: 502
    sensors:
      - name: laadpaal_name
        slave: 200
        address: 100
        count: 17
        data_type: string
      - name: laadpaal_temperature
        slave: 200
        address: 1102
        data_type: float32
        unit_of_measurement: °C
      - name: laadpaal_active_max_current
        slave: 200
        address: 1100
        data_type: float32
        unit_of_measurement: A
      - name: laadpaal_real_power_sum
        slave: 1
        address: 344
        data_type: float32
        unit_of_measurement: W
      - name: laadpaal_mode3_state
        slave: 1
        address: 1201
        count: 5
        data_type: string
        scan_interval: 5
      - name: laadpaal_actual_applied_maxcurrent
        slave: 1
        address: 1206
        data_type: float32
      - name: laadpaal_modbus_maxcurrent
        slave: 1
        address: 1210
        data_type: float32
      - name: laadpaal_socket1_current_valid_time
        slave: 1
        address: 1208
        data_type: uint32
        unit_of_measurement: s
The flow :
  • Flow starts every 20sec
  • first check if car is connected (sensor.chargepoint_status)
  • If not connected, do nothing
  • if connected, check if powercharge button (input_boolean.power_charge) is active an send state to flow.powerbutton for use later
  • Poll my digital meter
  • take an average of the last 3 readings (to filter out small spikes)
  • powerbutton NOT active :
  • set ‘set power level’ switch node (ampere) -2 -1 +1 +2, according to injected or consumed power
  • powerbutton active :
  • Check Powercharge current set in UI (input_number.max_powercharge_current) and use it in flow
  • translate current to power (in my case current x 230)
  • make negative
  • create array with powercharge power & DM power
  • add them togehter to create a value that allows us to draw the extra power from the net
  • inject this into the ‘set power level’ switch node
  • read currecnt state of ‘input_number.car_charger_ampere’
  • create float32 value from current (credits : @DelfuegoNL)
  • write float32 value to charger over modbus
If you have questions, better flows, please respond, this is still version 0.1 beta, so I’m testing it, but it looks like it’s working :
My dashboard looks like :
Node red flow :
Node-Red code can be downloaded here :
https://flows.nodered.org/flow/21b7e6ce0a2614ada8dd2d277450afff
With this setup I managed to get it fully working.Light color is solar power, dark color is the charging power.
As soon as I inject more then 1400W the charger starts, and the power goes to the car.
I manage to change as soon as there is a peak in consumption :
Hi Erwin,
Thank a lot for your node-red integration and json file, this has helped me to implement something similar and it works,
Thanks thanks thanks!
Hi Erwin,
Thanks for your post and node-red code. I am trying to get this up and running myself, but very new in HA and Node Red.
Now, when I import your node-red code, my installation does not recognize the calculator-nodes.
Any idea how I can install those on my system?
Thanks!
Ronny
Unfortunately the note red flow seems to be offline, was hoping to give it a test since my EV is arriving next week and Aflen is already installed. Would it be possible to share it again?
Thank you for your great contribution.
I’ve put the (updated) node-red script back online.
Now (for belgium) with also the Capacity Tarif in mind.
And estra button is ‘CapTar’. When enabling this one, the script reads the max capacity value for this month from the DM, then it uses this value added with the solar power that’s left. So you can charge faster, without pushing your monthly capacity tarif up.
I managed to get it to work, thanks for the flow!
To try and change it so it can pull 3000W max from the net (I know that a monthly peek is above 2.5 but we never got one below 3 so might as well use it), is it just toying around with the values in “Set power level Charger”?
I’ve set it to 1: 3000 for example.
I can send you an updated flow, where you have 2 choices :
You can set an extra ‘amperage’ to use from the net (PowerCharge), OR, you can use the max value from your current monthly peak as a max, so it uses as much power from the net, without exceeding the monthly peak you have at that point ?
the “Set power level Charger” is only a switch node to check if the Amperage can be updated with 1 or 2 at a time, it doesn’t change the power from the net.
Thanks for the reply, I only messed around a bit with it before going to bed as the car started and stopped charging constantly in short bursts. But I might have just used a wrong value somewhere, so I am re-evaluating those now.
I also couldn’t use monthly peek yet, as I use a separate DSMR-reader for my smart meter. But since I see monthly peek is only on the roadmap for december 2024 I am migrating to the Home Assistant integration.
Apparently all I needed was a few days off and work and to look back at it :). It was a Pebkac issue, I had set a value wrong in the charging point itself (max current for connector 1 was still 6 Amps from the time I manually had to change it for the charger, so with modbus I couldn’t go over it).
Only one small question. I see in the flow at the bottom the following:
It’s unclear to me if I need to create that input_number. As I don’t have it in Home Assistant. Just making sure I’m not missing something.
@erwin.fiten I’have made a similar script then you but i have the problem that if i go to 4A, then i am not able to start charging again because my stops charging… I see that you mention also in your original post that going to 0 stops the session but i have the same problem, any other way to keep the session active? It is for a Ford Kuga plugin hybrid.
Setting it to 5A works in my case. When I set to 0A, charging stops completely.
Hello Erwin,
I’m very interested in this post and would like to integrate it in my Home Assistant. As I’m also living in Belgium the ‘CapTar’ is very useful. Is it possible to upload your latest version?
Thank you!
Jeanke
Hi @erwin.fiten I would also be interested in the flow.
I’ve updated the flow.
I use the Alfen Wallbox plugin now from fwestenberg :to poll and update my Alfen, so I don’t need my modbus hack anymore.
Here is the repository (also in HACS) : GitHub - fwestenberg/alfen_wallbox: Alfen wallbox - Home Assistant Component
Flow can be found at : Home Assistant flow for Alfen charger (flow) - Node-RED
@erwin.fiten I stumbled across this a couple of days ago and decided to give this a go. First time doing something in Node-Red and also quite new to HA. Have a similar setup as you, with an Alfen eve Single-Pro hooked up on a monophase connection, with a cable going to the meter’s P1 port and just today added the other cable for ethernet/network connection over LAN. Also using the P1 meter from Home Wizard with integration in HA.
I’m trying to get this working. In your flow, on the “Set LB Power to DSMR” it’s using “input_number.dsmr_power_loadbalancing” but I’m not sure what this is and where it’s being used. Is the flow you shared complete, or are there other integrations or flows needed to make this work?
Hi Victor,
I checked, and this was a helper for one of my previous versions, you can delete it. I will also update my flow on Github. Thanks for noticing.
You need a reading from you (digital) meter, so the system knows if you are producing power, or getting it from the net (I use the HomeWizard dongle with his integration, but it should work with any),
And I use the integration for the Alfen charger : GitHub - fwestenberg/alfen_wallbox: Alfen wallbox - Home Assistant Component
Thanks @erwin.fiten I managed to get it working yesterday. This morning it seemed to be working for a bit, before clouds started moving in.
Had to adjust something in the path for CapTar charging, as I was pulling the monthly peak value from the HomeWizard integration in Watts but in your flow it
expects a current, so I added another calculator to convert to Amps :slight_smile:
Actually this whole thing could be simplified to just get the CapTar value in units of power and subtracting 230 W from it for the safety margin but I digress.
EDIT: Just found a bug with the current version of your flow I think. On the node “Update DSMR” it is setting msg.payload to the value flow.DSMR, but this needs to be reversed in order to work actually. At least for the case of charging in CapTar mode at night. It wouldn’t charge earlier but now it’s working.
Also I noticed on the node “Check if charging” it’s checking whether sensor.alfen_charger has the value “Load Balancing Limited” to conclude that the car is plugged in but not yet charging. However with my charging station the state from socket 1 in that case is “Load Balancing Forced Off” actually. So I changed it to that to make things work, but not sure if this is correct or not.
Correct, didn’t notice that one :slight_smile: I have a template sensor for that
- sensor:
    - name: "CapTarCurrent"
      unit_of_measurement: "A"
      state_class: measurement
      state: "{{ ( states('sensor.p1_meter_peak_demand_current_month') | float / 230 ) | round(0) }}"
Ad for the “Check if charging” it was a bit trial and error for me to get this right, so this can be different.
What is important is that you turn OFF the loadbalancing function in your charger !
