All gone to Pot! Last two updates causing issues
Greetings!
So I did the previous to last update (0.105.2) and lost several bits of functionality (Errors. Updated to Home Assistant 0.105.2)
An update came available this morning so did it!
After that update I lost GUI interface from the usual IP address. Long faff later. I removed docker from Ubuntu. Purged and reinstalled docker and Hassio.
Fresh install done (like the new waiting HA Loading page btw!).
Did a WIPE and RESTORE of an overnight snaphot made last night.
Now I cant get into the GUI again.
Hassio is running…
Deleted DB, new one generated.
Any tips?
Logs:
2020-02-11 14:15:04 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for anniversaries which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-11 14:15:04 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-11 14:15:04 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-11 14:15:04 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for auto_backup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-11 14:15:10 WARNING (MainThread) [homeassistant.components.group] The 'view' option (with value 'True') is deprecated, please remove it from your configuration. This option will become invalid in version 0.107.0
2020-02-11 14:15:12 WARNING (SyncWorker_3) [homeassistant.components.influxdb] Database host is not accessible due to 'HTTPConnectionPool(host='192.168.1.111', port=8086): Max retries exceeded with url: /write?db=hassio (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fb4c3428110>: Failed to establish a new connection: [Errno 111] Connection refused'))', please check your entries in the configuration file (host, port, etc.) and verify that the database exists and is READ/WRITE. Retrying again in 60 seconds.
2020-02-11 14:15:12 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for youtube which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-11 14:18:54 WARNING (MainThread) [homeassistant.components.frontend] Overwriting integration hacs
2020-02-11 14:18:56 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 415, in _async_add_entity
    raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: sensor.hacs. Platform hacs does not generate unique IDs
homeassistant.exceptions.HomeAssistantError: Entity id already exists: device_tracker.jim_jimsmobile. Platform owntracks does not generate unique IDs
2020-02-11 14:19:01 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Foscam onvif', but will retry later. Error: Cannot connect to host 192.168.1.107:2021 ssl:None [Connect call failed ('192.168.1.107', 2021)]
2020-02-11 14:19:01 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 30 seconds.
2020-02-11 14:19:02 WARNING (SyncWorker_3) [homeassistant.components.influxdb] Database host is not accessible due to 'HTTPConnectionPool(host='192.168.1.111', port=8086): Max retries exceeded with url: /write?db=hassio (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fb4bbe7d050>: Failed to establish a new connection: [Errno 111] Connection refused'))', please check your entries in the configuration file (host, port, etc.) and verify that the database exists and is READ/WRITE. Retrying again in 60 seconds.
2020-02-11 14:19:13 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:10
2020-02-11 14:19:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:10
2020-02-11 14:19:31 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 2 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 3 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 4 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 6 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 7 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 8 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 9 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 10 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 11 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 12 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 13 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 14 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 15 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 16 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 16 Switch (node_id: 16) not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 17 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 18 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 18 Switch (node_id: 18) not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 19 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 24 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 26 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 26 Sensor (node_id: 26) not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 29 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 34 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 34 Sensor (node_id: 34) not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 38 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 38 Sensor (node_id: 38) not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 41 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 41 Sensor (node_id: 41) not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 43 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 43 Sensor (node_id: 43) not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 45 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 45 Sensor (node_id: 45) not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 57 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 58 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:32 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 59 not ready after 30 seconds, continuing anyway
2020-02-11 14:19:35 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Foscam onvif', but will retry later. Error: Cannot connect to host 192.168.1.107:2021 ssl:None [Connect call failed ('192.168.1.107', 2021)]
2020-02-11 14:19:35 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 60 seconds.
2020-02-11 14:19:46 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:10
2020-02-11 14:19:57 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:10
2020-02-11 14:20:03 WARNING (SyncWorker_4) [homeassistant.components.influxdb] Database host is not accessible due to 'HTTPConnectionPool(host='192.168.1.111', port=8086): Max retries exceeded with url: /write?db=hassio (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fb4bb39f390>: Failed to establish a new connection: [Errno 111] Connection refused'))', please check your entries in the configuration file (host, port, etc.) and verify that the database exists and is READ/WRITE. Retrying again in 60 seconds.
2020-02-11 14:20:19 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:10
2020-02-11 14:20:30 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:10
2020-02-11 14:20:40 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Foscam onvif', but will retry later. Error: Cannot connect to host 192.168.1.107:2021 ssl:None [Connect call failed ('192.168.1.107', 2021)]
2020-02-11 14:20:40 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 90 seconds.
Update.
After commenting out Influx DB and a custom component in configuration.yaml
HA GUI has loaded.
However none of the add ons (bar MQTT) are running or able to start… Configurator, duckdns etc
