I remember seeing that somewhere too… good idea.
I tried implementing it, but my HA install seems to be a bit off today. I have one file loaded as a package. It used to be called ZigbeeRainMeter.yaml
, then I renamed it to zigbee_rain_meter.yaml
. For some reason, when I reload the YAMLs in HA now (did the check configuration button go away btw?), it still gives me an error for duplicate keys in ZigbeeRainMeter.yaml
, even though that file doesn’t exist anymore.
I feel like the bottom error is worse though: “Mapping values are not allowed here in…”
I removed the include of the packages and restarted HA, that got rid of the old filename error. The only error I’m getting now is the one I was dreading before.
Line 17 in the configuration.yaml
file:
The extra space in front of packages
is intentional, otherwise you get an error saying that the integration ‘packages’ can’t be found.
And the contents of the only YAML file in the projectYamls
folder:
# Package: zigbee_rain_meter.yaml
# RAIN METER BASED USING DOOR AND WINDOW SENSOR
# Standard tipping style rain meter, using the Aqara Door and Window sensor
# Model: Aqara MCCGQ11LM
# Battery: CR1632
# Entities used and not defined here:
# HELPER ENTITIES
# Calculate amount of rain in liter or mm per m² based on funnel size and volume required to tip the bucket
# Measurements: 1 liter tips bucket 152, 174 and 168 times. Assuming 170 is correct.
template helper:
- sensor:
- name: "Aqara Rain Meter - Rainfall per tick"
unique_id: '0a7476cc-d6c1-40ba-8351-606518c3497sdfs'
state_class: total
unit_of_measurement: l/m²
state: >
{# Fill funnel radius and ticksPerLiter #}
{% set funnelRadius = 0.055 %}
{% set ticksPerLiter = 170 %}
{# Don't change anything below #}
{% set litersPerTick = 1 / 170 %}
{{ (1 / (pi * ( funnelRadius**2 ))) * literPerTick }}
# Convert rain meter ticks into rainfall intensity in mm/h / l/h
binary_sensor:
- platform: trend
sensors:
aqara_rain_sensor_rainfall_trend:
friendly_name: "Rainfall trend"
entity_id: sensor.aqara_rain_sensor_rainfall_today
max_samples: 10
sample_duration: 300
template helper2:
- sensor:
- name: "Aqara rain intensity"
state_class: measurement
device_class: precipitation
unit_of_measurement: 'mm/h'
unique_id: aqara_rain_sensor_rainfall_per_hour
state: >-
{% set rain_hour = ((state_attr('binary_sensor.aqara_rain_sensor_rainfall_trend', 'gradient') | float(0)) * 3600) | round(1, 'floor') %}
{% if rain_hour >= 0 %}
{{ rain_hour }}
{% else %}
{{ 0 }}
{% endif %}
# SENSORS & BINARY SENSORS
# Flips ON | TODAY
# Determines how many times the sensor was in the ON state today
- platform: history_stats
unique_id: "aqara_rain_sensor_flips_on_today"
name: "Aqara rain sensor flips/on (Today)"
entity_id: binary_sensor.aqara_dw_2_open_closed
state: "on"
type: count
start: "{{ now().replace(hour=0, minute=0, second=0, microsecond=0) }}"
duration:
hours: 24
# Flips OFF | TODAY
# Determines how many times the sensor was in the OFF state today
unique_id: "aqara_rain_sensor_flips_off_today"
name: "Aqara rain sensor flips/off (Today)"
state: "off"
type: count
duration:
hours: 24
# Flips ON | YESTERDAY
# Determines how many times the sensor was in the ON state yesterday
unique_id: "aqara_rain_sensor_flips_on_yesterday"
name: "Aqara rain sensor flips/on (Yesterday)"
state: "on"
type: count
start: "{{ now().replace(hour=0, minute=0, second=0, microsecond=0) - timedelta(hours=24) }}"
duration:
hours: 24
# Flips OFF | YESTERDAY
# Determines how many times the sensor was in the OFF state yesterday
unique_id: "aqara_rain_sensor_flips_off_yesterday"
name: "Aqara rain sensor flips/off (Yesterday)"
state: "off"
type: count
duration:
hours: 24
# TEST TEST TEST
# Flips TOTAL | TODAY
# Determines how many times the sensor toggled today
unique_id: "aqara_rain_sensor_flips_total_today"
name: "Aqara rain sensor flips/total (Today)"
state:
- "off"
- "on"
type: count
duration:
hours: 24
template main:
- sensor:
# Calculate rain volume for the current day based on flips on and off for today
- name: "Aqara Rainfall (Today)"
state_class: total_increasing
unit_of_measurement: mm
unique_id: aqara_rain_sensor_rainfall_today
state: >-
{% set count = (states('sensor.aqara_rain_sensor_flips_on_today') | int(0)) + (states('sensor.aqara_rain_sensor_flips_off_today') | int(0)) %}
{% set mm = count * float(states('sensor.aqara_rain_meter_rainfall_per_tick')) %}
{% if count >= 0 %}
{{ mm | round (1) }}
{% endif %}
# Calculate rain volume for yesterday based on flips on and off for yesterday
- name: "Aqara Rainfall (Yesterday)"
unique_id: aqara_rain_sensor_rainfall_yesterday
state: >-
{% set count = (states('sensor.aqara_rain_sensor_flips_on_yesterday') | int(0)) + (states('sensor.aqara_rain_sensor_flips_off_yesterday') | int(0)) %}
{% if count >= 0 %}
{% endif %}
I’m usually pretty good at figuring out what’s going on when there’s a log file, but the “mapping values not allowed” error seems to almost always be caused by a indentation error. I know it’s hard to see your own mistakes, but AFAICS there are no indentation errors.
