No, this is the first time I’ve used labels, so they only exist in the package yaml.
Either or is fine with me, I kept both since I figured one would be directed more toward discussing workarounds, and the other would focus on if this would be a good feature to add. I agree that closing one is probably better.
I kinda expected it to do that automatically, thanks.
Here’s my (simplified) configuration.yaml, and the package yaml, zigbee_rain_meter.yaml.
# configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include configurationYamls/group.yaml
automation: !include configurationYamls/automation.yaml
script: !include configurationYamls/script.yaml
scene: !include configurationYamls/scene.yaml
template: !include configurationYamls/template.yaml
sensor: !include configurationYamls/sensor.yaml
binary_sensor: !include configurationYamls/binary_sensor.yaml
homeassistant:
packages: !include_dir_named configurationYamls/projectYamls
# I also tried packages without homeassistant, but then I get "while parsing a
# block mapping in "/config/configuration.yaml", line 2, column 1 expected <block end>,
# but found '<block mapping start>' in "/config/configuration.yaml", line 17, column 3".
# Line 2 is `default_config:`, line 17 is the line that has `packages: ...`.
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.18.0.0/16
system_log:
max_entries: 200
api:
frontend:
extra_module_url:
- /hacsfiles/custom-sidebar-v2/custom-sidebar-v2.js
- /local/custom_sidebar_order.js
themes: !include_dir_merge_named themes/
mqtt_statestream:
base_topic: homeassistant
publish_attributes: false
publish_timestamps: false
influxdb:
zha:
enable_quirks: True
custom_quirks_path: custom_zha_quirks
panel_custom:
# Package: zigbee_rain_meter.yaml
# RAIN METER BASED USING DOOR AND WINDOW SENSOR
# Standard tipping style rain meter, using the Aqara Door and Window sensor
# Model: Aqara MCCGQ11LM
# Battery: CR1632
# Entities used and not defined here:
# HELPER ENTITIES
# Calculate amount of rain in liter or mm per m² based on funnel size and volume required to tip the bucket
# Measurements: 1 liter tips bucket 152, 174 and 168 times. Assuming 170 is correct.
template helper:
- sensor:
- name: "Aqara Rain Meter - Rainfall per tick"
unique_id: '0a7476cc-d6c1-40ba-8351-606518c3497sdfs'
state_class: total
unit_of_measurement: l/m²
state: >
{# Fill funnel radius and ticksPerLiter #}
{% set funnelRadius = 0.055 %}
{% set ticksPerLiter = 170 %}
{# Don't change anything below #}
{% set litersPerTick = 1 / 170 %}
{{ (1 / (pi * ( funnelRadius**2 ))) * literPerTick }}
- sensor:
- name: "TESTTESTTEST"
unique_id: '0a7476csdfc-d6c1-40ba-8351-606518c3497sdfs'
state_class: total
state: 1
# Convert rain meter ticks into rainfall intensity in mm/h / l/h
binary_sensor:
- platform: trend
sensors:
aqara_rain_sensor_rainfall_trend:
friendly_name: "Rainfall trend"
entity_id: sensor.aqara_rain_sensor_rainfall_today
max_samples: 10
sample_duration: 300
template helper2:
- sensor:
- name: "Aqara rain intensity"
state_class: measurement
device_class: precipitation
unit_of_measurement: 'mm/h'
unique_id: aqara_rain_sensor_rainfall_per_hour
state: >-
{% set rain_hour = ((state_attr('binary_sensor.aqara_rain_sensor_rainfall_trend', 'gradient') | float(0)) * 3600) | round(1, 'floor') %}
{% if rain_hour >= 0 %}
{{ rain_hour }}
{% else %}
{{ 0 }}
{% endif %}
# SENSORS & BINARY SENSORS
# Flips ON | TODAY
# Determines how many times the sensor was in the ON state today
- platform: history_stats
unique_id: "aqara_rain_sensor_flips_on_today"
name: "Aqara rain sensor flips/on (Today)"
entity_id: binary_sensor.aqara_dw_2_open_closed
state: "on"
type: count
start: "{{ now().replace(hour=0, minute=0, second=0, microsecond=0) }}"
duration:
hours: 24
# Flips OFF | TODAY
# Determines how many times the sensor was in the OFF state today
unique_id: "aqara_rain_sensor_flips_off_today"
name: "Aqara rain sensor flips/off (Today)"
state: "off"
type: count
duration:
hours: 24
# Flips ON | YESTERDAY
# Determines how many times the sensor was in the ON state yesterday
unique_id: "aqara_rain_sensor_flips_on_yesterday"
name: "Aqara rain sensor flips/on (Yesterday)"
state: "on"
type: count
start: "{{ now().replace(hour=0, minute=0, second=0, microsecond=0) - timedelta(hours=24) }}"
duration:
hours: 24
# Flips OFF | YESTERDAY
# Determines how many times the sensor was in the OFF state yesterday
unique_id: "aqara_rain_sensor_flips_off_yesterday"
name: "Aqara rain sensor flips/off (Yesterday)"
state: "off"
type: count
duration:
hours: 24
# TEST TEST TEST
# Flips TOTAL | TODAY
# Determines how many times the sensor toggled today
unique_id: "aqara_rain_sensor_flips_total_today"
name: "Aqara rain sensor flips/total (Today)"
state:
- "off"
- "on"
type: count
duration:
hours: 24
template main:
- sensor:
# Calculate rain volume for the current day based on flips on and off for today
- name: "Aqara Rainfall (Today)"
state_class: total_increasing
unit_of_measurement: mm
unique_id: aqara_rain_sensor_rainfall_today
state: >-
{% set count = (states('sensor.aqara_rain_sensor_flips_on_today') | int(0)) + (states('sensor.aqara_rain_sensor_flips_off_today') | int(0)) %}
{% set mm = count * float(states('sensor.aqara_rain_meter_rainfall_per_tick')) %}
{% if count >= 0 %}
{{ mm | round (1) }}
{% endif %}
# Calculate rain volume for yesterday based on flips on and off for yesterday
- name: "Aqara Rainfall (Yesterday)"
unique_id: aqara_rain_sensor_rainfall_yesterday
state: >-
{% set count = (states('sensor.aqara_rain_sensor_flips_on_yesterday') | int(0)) + (states('sensor.aqara_rain_sensor_flips_off_yesterday') | int(0)) %}
{% if count >= 0 %}
{% endif %}
Like mentioned in the other topic, if I put the templates with labels like this, and use
homeassistant:
packages: ...
then the file loads, but none of the template sensors load:
If I put all templates under one template: key, without labels, they load just fine.
An important note: I think we can forget about the duplicates error. While testing this, to make sure I was writing down the correct error messages here, I noticed that HA just repeats the last error message when I use labeled templates. Now if I try loading the packages without having homeassistant: above, it gives me these errors. This makes me think HA isn’t providing proper error messages for this issue. Does anyone see an issue why the labels wouldn’t work?
2023-09-10 10:19:28.276 ERROR (SyncWorker_12) [homeassistant.util.yaml.loader] while parsing a block mapping
expected <block end>, but found '<block mapping start>'
2023-09-10 10:19:28.277 ERROR (MainThread) [homeassistant.components.homeassistant] The system cannot reload because the configuration is not valid: Error loading /config/configuration.yaml: while parsing a block mapping
2023-09-10 10:19:28.278 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140178582534416] Cannot quick reload all YAML configurations because the configuration is not valid: Error loading /config/configuration.yaml: while parsing a block mapping
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 205, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1910, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1950, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 887, in admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 316, in async_handle_reload_all
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Cannot quick reload all YAML configurations because the configuration is not valid: Error loading /config/configuration.yaml: while parsing a block mapping
