spyro-po
(Spyro Po)
January 18, 2023, 9:37am
123
I’m duble check and looks good, below config and logs:
esphome:
platform: ESP32
board: esp-wrover-kit
on_boot:
- script.execute: main1
- script.wait: main1
#esphome:
# name: ble
#esp32:
# board: esp32dev
# framework:
# type: arduino
# Enable logging
logger:
# level: VERY_VERBOSE
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
password: "xxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
use_address: 192.168.1.107
ap:
ssid: "Ble Fallback Hotspot"
password: "xxxxxxxxxxxxxxxx"
web_server:
port: 80
captive_portal:
ble_client:
- mac_address: 02:9E:88:EB:B5:F6
on_connect:
- binary_sensor.template.publish:
state: ON
- logger.log:
format: "CONNECT LEFT"
level: INFO
on_disconnect:
state: OFF
- logger.log:
format: "DISCONNECT LEFT"
level: INFO
binary_sensor:
device_class: connectivity
name: "Left connected"
device_class: opening
- platform: uptime
- platform: ble_rssi
name: "Bedroom Left Blind RSSI"
- platform: am43
ble_client_id: bedroom_left_blind
illuminance:
name: "Bedroom Left Blind Light"
filters:
- filter_out: nan
battery_level:
name: "Bedroom Left Blind Battery"
filters:
- filter_out: nan
update_interval: 30sec
switch:
- platform: restart
name: "Bedroom Blind ESP Reboot"
- platform: ble_client
name: "Bedroom Left Blind BLE"
cover:
- platform: am43
pin: 8888
internal: true
on_open:
state: ON
on_closed:
state: OFF
has_position: true
lambda: |-
return (id(bedroom_left_blind_cover_internal).position);
open_action:
then:
- script.execute: open_action
close_action:
then:
- script.execute: close_action
stop_action:
then:
- script.execute: stop_action
position_action:
then:
- script.execute:
value: !lambda return pos;
script:
- id: open_action
mode: restart
then:
- script.stop: close_action
- script.stop: stop_action
- script.stop: position_action
- script.stop: update_sensors
- logger.log:
format: "Open ..."
level: INFO
- script.execute: enable_ble
- script.wait: enable_ble
- cover.open: bedroom_left_blind_cover_internal
- while:
condition:
not:
and:
- binary_sensor.is_on: left_open_status
then:
- logger.log:
format: "... opening ..."
level: INFO
- delay: 1sec
- logger.log:
format: "... opened"
level: INFO
- script.execute: update_sensors
- id: close_action
mode: restart
then:
- script.stop: open_action
- logger.log:
format: "Close ..."
level: INFO
- cover.close: bedroom_left_blind_cover_internal
- while:
condition:
not:
and:
- binary_sensor.is_off: left_open_status
then:
- logger.log:
format: "... closing ..."
level: INFO
- delay: 1sec
- logger.log:
format: "... closed"
level: INFO
- id: stop_action
mode: restart
then:
- logger.log:
format: "Stop ..."
level: INFO
- cover.stop: bedroom_left_blind_cover_internal
- logger.log:
format: "... stoped"
level: INFO
- id: position_action
mode: restart
parameters:
value: float
then:
- logger.log:
format: "Set position %f ..."
level: INFO
args: [ value ]
- cover.control:
position: !lambda return value;
- id: enable_ble
mode: restart
then:
- script.stop: disable_ble
- logger.log:
format: "Enabling BLE..."
level: INFO
- if:
condition:
- switch.is_off: bedroom_left_blind_ble
then:
- switch.turn_on: bedroom_left_blind_ble
- while:
condition:
not:
and:
- binary_sensor.is_on: left_connected
then:
- logger.log:
format: "... waiting connection ..."
level: INFO
- delay: 1sec
- logger.log:
format: "...BLE enabled"
level: INFO
- id: disable_ble
mode: single
then:
- logger.log:
format: "Disabling BLE ..."
level: INFO
- switch.turn_off: bedroom_left_blind_ble
- logger.log:
format: "... BLE disabled"
level: INFO
- id: update_sensors
mode: single
then:
- logger.log:
format: "Updating sensor ..."
level: INFO
- delay: 1min
- while:
condition:
or:
- script.is_running: open_action
- script.is_running: close_action
- script.is_running: stop_action
- script.is_running: position_action
then:
- logger.log:
format: "... domething Still executing ..."
level: INFO
- delay: 10s
- script.execute: disable_ble
- script.wait: disable_ble
- logger.log:
format: "... sensors updated"
level: INFO
- id: main1
mode: single
then:
- while:
condition:
- lambda: "return true;"
then:
- script.wait: update_sensors
- delay: 60min
INFO Reading configuration /config/esp.yaml...
INFO Starting log output from 192.168.1.107 using esphome API
INFO Successfully connected to 192.168.1.107
[09:35:53][I][app:102]: ESPHome version 2022.12.3 compiled on Jan 16 2023, 22:43:45
[09:35:53][C][wifi:504]: WiFi:
[09:35:53][C][wifi:362]: Local MAC: CC:DB:A7:02:4E:5C
[09:35:53][C][wifi:363]: SSID: [redacted]
[09:35:53][C][wifi:364]: IP Address: 192.168.1.107
[09:35:53][C][wifi:366]: BSSID: [redacted]
[09:35:54][C][wifi:367]: Hostname: 'esp'
[09:35:55][C][ble_rssi:011]: BLE RSSI Sensor 'Bedroom Left Blind RSSI'
[09:35:57][I][main:264]: ... waiting connection ...
[09:35:58][I][main:264]: ... waiting connection ...
[09:35:59][I][main:264]: ... waiting connection ...
[09:36:00][I][main:264]: ... waiting connection ...
[09:36:01][I][main:264]: ... waiting connection ...
[09:36:02][I][main:264]: ... waiting connection ...
[09:36:03][I][main:264]: ... waiting connection ...
[09:36:04][I][main:264]: ... waiting connection ...
[09:36:05][I][main:264]: ... waiting connection ...
[09:36:06][I][main:264]: ... waiting connection ...
[09:36:07][I][main:264]: ... waiting connection ...
[09:36:08][I][main:264]: ... waiting connection ...
[09:36:09][I][main:264]: ... waiting connection ...
[09:36:10][I][main:264]: ... waiting connection ...
[09:36:11][I][main:264]: ... waiting connection ...
[09:36:12][I][main:264]: ... waiting connection ...
[09:36:13][I][main:264]: ... waiting connection ...
[09:36:14][I][main:264]: ... waiting connection ...
[09:36:15][I][main:264]: ... waiting connection ...
[09:36:16][I][main:264]: ... waiting connection ...
[09:36:17][I][main:264]: ... waiting connection ...
[09:36:18][I][main:264]: ... waiting connection ...
[09:36:19][I][main:264]: ... waiting connection ...
[09:36:20][I][main:264]: ... waiting connection ...
[09:36:21][I][main:264]: ... waiting connection ...
[09:36:22][I][main:264]: ... waiting connection ...
[09:36:23][I][main:264]: ... waiting connection ...
[09:36:24][I][main:264]: ... waiting connection ...
[09:36:25][W][am43:098]: [02:9E:88:EB:B5:F6] Cannot poll, not connected
[09:36:25][I][main:264]: ... waiting connection ...
[09:36:26][I][main:264]: ... waiting connection ...
Not sure , but guess that and is redundant here because you are using single am43. Could you try with
- while:
condition:
not:
volsv
(Volsv)
March 11, 2023, 12:40pm
126
Аддон работал замечательно, но теперь я получаю ошибку: “s6-overlay-suexec: fatal: can only run as pid 1” Есть идеи?
I created a bluetooth proxy in the hope of connecting to my AM43 blinds (Blind Engine app).
They did not get discovered, my toothbrush on the other hand did so that confirmed that my board works and the bluetooth proxy does work.
I saw your code for the blinds and thought i could copy that.
Was i wrong do i need to do something else?
Do i need to remove the code for bluetooth proxy?
Did i mess up some renaming?
The error i get is the following:
Below is my code
esphome:
friendly_name: blt-proxy
on_boot:
- script.wait: main
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
encryption:
key: "*redacted*"
ota:
password: "*redacted*"
wifi:
ap:
ssid: "blt-proxy"
captive_portal:
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
# Badkamer 02:49:52:55:0F:E0
# Dressing 02:B2:6C:27:74:6C
ble_client:
- mac_address: 02:49:52:55:0F:E0
on_connect:
state: ON
- logger.log:
level: INFO
on_disconnect:
state: OFF
- logger.log:
level: INFO
- mac_address: 02:B2:6C:27:74:6C
on_connect:
state: ON
- logger.log:
format: "CONNECT RIGHT"
level: INFO
on_disconnect:
state: OFF
- logger.log:
format: "DISCONNECT RIGHT"
level: INFO
binary_sensor:
name: "Right connected"
- platform: uptime
# - platform: ble_client
# id: badkamer_blind_rssi
# type: rssi
# ble_client_id: badkamer_blind
# name: "Badkamer Blind RSSI"
# id: dressing_blind_rssi
# type: rssi
# ble_client_id: dressing_blind
# name: "Dressing Blind RSSI"
mac_address: 02:7B:F1:3A:C6:63
mac_address: 02:BD:67:49:4B:0D
- platform: am43
illuminance:
name: "Badkamer Blind Light"
filters:
- filter_out: nan
battery_level:
name: "Badkamer Blind Battery"
filters:
- filter_out: nan
- platform: am43
illuminance:
name: "Dressing Blind Light"
filters:
- filter_out: nan
battery_level:
name: "Dressing Blind Battery"
filters:
- filter_out: nan
switch:
- platform: restart
name: "Blind ESP Reboot"
name: "Badkamer Blind BLE"
name: "Dressing Blind BLE"
cover:
- platform: am43
pin: 1234
internal: true
on_open:
state: ON
on_closed:
state: OFF
- platform: am43
pin: 1234
internal: true
on_open:
state: ON
on_closed:
state: OFF
has_position: true
lambda: |-
return (id(badkamer_blind_cover_internal).position + id(dressing_blind_cover_internal).position) / 2;
open_action:
then:
close_action:
then:
stop_action:
then:
position_action:
then:
- script.execute:
script:
- id: open_action
mode: restart
then:
- logger.log:
format: "Open ..."
level: INFO
- cover.open: badkamer_blind_cover_internal
- cover.open: dressing_blind_cover_internal
- while:
condition:
not:
and:
- binary_sensor.is_on: right_open_status
then:
- logger.log:
level: INFO
- delay: 1sec
- logger.log:
level: INFO
- id: close_action
mode: restart
then:
- logger.log:
format: "Close ..."
level: INFO
- cover.close: badkamer_blind_cover_internal
- cover.close: dressing_blind_cover_internal
- while:
condition:
not:
and:
- binary_sensor.is_off: right_open_status
then:
- logger.log:
level: INFO
- delay: 1sec
- logger.log:
level: INFO
- id: stop_action
mode: restart
then:
- logger.log:
format: "Stop ..."
level: INFO
- cover.stop: badkamer_blind_cover_internal
- cover.stop: dressing_blind_cover_internal
- logger.log:
level: INFO
mode: restart
parameters:
value: float
then:
- logger.log:
level: INFO
args: [ value ]
- cover.control:
- cover.control:
- id: enable_ble
mode: restart
then:
- logger.log:
level: INFO
- if:
condition:
- switch.is_off: badkamer_blind_ble
then:
- switch.turn_on: badkamer_blind_ble
- if:
condition:
- switch.is_off: dressing_blind_ble
then:
- switch.turn_on: dressing_blind_ble
- while:
condition:
not:
and:
- binary_sensor.is_on: right_connected
then:
- logger.log:
level: INFO
- delay: 1sec
- logger.log:
level: INFO
- id: disable_ble
mode: single
then:
- logger.log:
level: INFO
- switch.turn_off: badkamer_blind_ble
- switch.turn_off: dressing_blind_ble
- logger.log:
level: INFO
mode: single
then:
- logger.log:
level: INFO
- delay: 1min
- while:
condition:
or:
then:
- logger.log:
level: INFO
- delay: 10s
- logger.log:
level: INFO
- id: main
mode: single
then:
- while:
condition:
then:
- delay: 60min
Why have you renamed the main_loop script to main? main is reserved, so just return it back)
Thank you for your reply!
I was under the impression that this must be named ‘main’
because it was in the example code
Or am i looking at an older version of the code?
I’ll try to change this ASAP and get back to you!
Hm, i’ve only compared a local version with your and found that discrepancy. I don’t remember that i did it by myself, maybe it was updated by some ESPHome update. Who knows…
No problem, i got it installed, stupid mistake… I am not too familiar with esphome…
I used the bluetooth mac addresses but they won’t connect, do i need to disconnect the AM43 blinds from the Blind engine on my phone or do i need to keep it open while connecting?
Yeah, coding on yaml blows a mind. I would to make configurable by operating with list or array of drivers, but it does not look to be feasible for now.
ESP connects to am43 via bluetooth on demand only to perform user’s action, or to refresh sensor periodically (battery, light, etc.). So, am43 must be disconnected from phones.
This script useful for automation/scenario of am43 because it saves battery, but it not comfortable for direct binding to wall switch/button, since it requires some time to negotiate Bluetooth connection to send command
ok, i’ll try to remove it from the app and hopefully get it connected.
Do i need to reconfigure it then or will it keep the settings set through the Blinds engine app?
i don’t need a direct binding but i would like to automatically let it close when i detect x amount of lumen or when it’s this time or something like that? Or is that not possible with this code / devices?
You don’t need to reconfigure top/bottom point, speed setting, etc. But scheduling in Blinds engine should be disabled.
This exactly purpose of usage for this script. I have an automation which opens blindы every non-holiday morning at time from input_datetime.open_blinds_working_day helper AND closes after sunset
alias: Control blinds
description: Open/close blind by trigger
- platform: time
at: input_datetime.open_blinds_working_day
- platform: numeric_state
entity_id: sun.sun
attribute: elevation
below: -3
condition: []
- choose:
- conditions:
- condition: trigger
- condition: state
entity_id: binary_sensor.workday_sensor
state: "on"
sequence:
- service: cover.open_cover
data: {}
entity_id: cover.bedroom_blinds
- conditions:
sequence:
- service: cover.close_cover
data: {}
default:
- if:
- condition: sun
before: sunrise
after: sunset
then:
data: {}
mode: single
Still not able to connect them, even after removing them from the app…
they don’t get discovered either like my Oral-B.
Any thoughts?
xxgmxx
October 24, 2023, 4:38pm
137
I’ve been struggling to establish a connection with the AM43 for what feels like ages, completely clueless about what was causing the issue. While going through this thread, I stumbled upon a suggestion to try a different board, which I initially overlooked. The board I had been using was my BT proxy, which works perfectly for everything except the AM43. It was a combination of all the problems mentioned here, and none of them seemed to get resolved until I made the switch to the ESP32.
Now, I’ve successfully connected the AM43 to my ESP32-WROOM-32UE with an external antenna. The previous board could detect the AM43 by its name from the Smart Blinds APP, but establishing a connection was a no-go. So, to anyone else grappling with a similar issue, my advice would be to experiment with as many ESP32 boards as possible until you find one that works.
@LiveDrunk , @spyro-po
LiveDrunk
(Andy)
November 10, 2023, 11:26am
138
Could you point me in the right direction on which device you use now?
ESP32-WROOM-32UE with an external antenna, perhaps a link?
LiveDrunk
(Andy)
November 13, 2023, 5:07pm
139
Was able to connect and open and close them! Great success.
Now only i see a massive battery drain (40% gone in a day)
Might need to try the confige from above if i can keep the connection.
The connection is up on demand to avoid battery draining, so make sure the ble switch and binary sensor in appropriate states. In other words, esp should connect to am43 only after get a command (open/close/set position) from HA initiated by user or automation, and after the command is executed esp should terminate BLE connection with am43. Periodically esp connects to am43 by it self to update battery/light sensors
panoriega
(Antonio)
April 23, 2024, 1:16am
141
Thank you very much, this worked for me perfectly!! This save me a lot of work and the implementation is nice.
Guess it is grow enough to have own repo)
panoriega
(Antonio)
April 23, 2024, 3:18am
143
I renamed main, to main_am43 (or main_loop) to make it work
