AM43 blinds control through MQTT
I have installed the sample yaml via esphome and changed to my mac address etc.
When I install the code i get this error
Compiling /data/lounge-blinds/.pioenvs/lounge-blinds/src/esphome/components/am43/am43.cpp.o
Compiling /data/lounge-blinds/.pioenvs/lounge-blinds/src/esphome/components/am43/am43_base.cpp.o
Compiling /data/lounge-blinds/.pioenvs/lounge-blinds/src/esphome/components/am43/cover/am43_cover.cpp.o
In file included from src/esphome/components/am43/am43.cpp:1:0:
src/esphome/components/am43/am43.h:6:46: fatal error: esphome/components/sensor/sensor.h: No such file or directory
compilation terminated.
*** [/data/lounge-blinds/.pioenvs/lounge-blinds/src/esphome/components/am43/am43.cpp.o] Error 1
esphome:
  platform: ESP32
  board: nodemcu-32s
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "fabe33f968e45454259943641816"
wifi:
  ssid: "xxxxxxxxx"
  password: "xxxxxxxxx"
  ap:
    ssid: "Lounge-Blinds Fallback Hotspot"
    password: "YZwaINo1VDpB"
captive_portal:
external_components:
  - source: github://buxtronix/esphome-am43
esp32_ble_tracker:
ble_client:
  - mac_address: 02:4B:xx:xx:3C:E5
cover:
  - platform: am43
    ble_client_id: am43_lounge
What am I doing wrong?
Hi All,
If anyone is interested I have got this working with ESP32-Wroom-32. Initially had some issues with the BLE connection but the NimBLE people sorted it almost immediately.
https://www.amazon.co.uk/ESP-32S-Development-2-4GHz-Bluetooth-Antenna/dp/B071JR9WS9
Was wondering though which custom component you guys are using for this to control the curtain manually?
can someone explain this to me please?
#define SHADE_1 “02:e6:93:bf:85:ce”
#define SHADE_2 “11:22:33:44:55:66”
#define SHADE_3 “11:22:33:44:55:66”
#define DEVICE_ALLOWLIST “”
//#define DEVICE_ALLOWLIST SHADE_1
//#define DEVICE_ALLOWLIST SHADE_1 “,” SHADE_2 “,” SHADE_3
I have been with this for two days and I am not able to make it work, it only “publishes” “lwt” and “enabled” no more data
You can use this without external_components.
AM43 is now supported in ESPHome by default.
Thanks Chris for a greate template, i’ve continued your job, and here what i got:
  1. fixed ‘Unknown’ battery’s state issue
  2. two blinds are controled, and easelly extend their count if necessary.
  3. blinds are merged to single (don’t necessary to create group in HA), i guess that here is no problem to split them if you’d like to conrol blinds separatly
  4. adding position control
esphome:
  platform: ESP32
  board: esp-wrover-kit
  on_boot:
    - script.execute: main
    - script.wait: main
wifi:
  ssid: !secret wifi_ssid
logger:
  level: INFO
api:
ota:
  password: "f3c4853547d70265da463e82f7d66947"
esp32_ble_tracker:
globals:
  - id: position
    type: int
    restore_value: no
ble_client:
  - mac_address: 02:7B:F1:3A:C6:63
    on_connect:
      - binary_sensor.template.publish:
          state: ON
    on_disconnect:
          state: OFF
  - mac_address: 02:BD:67:49:4B:0D
    on_connect:
          state: ON
    on_disconnect:
          state: OFF
cover:
  - platform: am43
    ble_client_id: bedroom_left_blind
    pin: 1234
    internal: true
  - platform: am43
    ble_client_id: bedroom_right_blind
    pin: 1234
    internal: true
    has_position: true
    lambda: |-
      return (id(bedroom_left_blind_cover_internal).position + id(bedroom_right_blind_cover_internal).position) / 2;
    open_action:
      then:
        - script.execute: open_action
        - script.wait: open_action
    close_action:
      then:
        - script.execute: close_action
        - script.wait: close_action
    stop_action:
      then:
        - script.execute: stop_action
        - script.wait: stop_action
    position_action:
      then:
        - lambda: |-
            id(position)=pos;
        - script.execute: position_action
        - script.wait: position_action
script:
  - id: open_action
    mode: restart
    then:
      - script.execute: enable_ble
      - script.wait: enable_ble
      - if:
          condition:
            and:
              - binary_sensor.is_on: bedroom_left_blind_connected
              - binary_sensor.is_on: bedroom_right_blind_connected
          then:
            - cover.open: bedroom_left_blind_cover_internal
            - cover.open: bedroom_right_blind_cover_internal
  - id: close_action
    mode: restart
    then:
      - if:
          condition:
            and:
          then:
            - cover.close: bedroom_left_blind_cover_internal
            - cover.close: bedroom_right_blind_cover_internal
  - id: stop_action
    mode: restart
    then:
      - if:
          condition:
            and:
          then:
            - cover.stop: bedroom_left_blind_cover_internal
            - cover.stop: bedroom_right_blind_cover_internal
  - id: position_action
    mode: restart
    then:
      - if:
          condition:
            and:
          then:
            - lambda: |-
                auto call = id(bedroom_left_blind_cover_internal).make_call();
                call.set_position(id(position));
                call.perform();
                call = id(bedroom_right_blind_cover_internal).make_call();
                call.perform();
  - id: enable_ble
    mode: restart
    then:
      - logger.log:
          format: "Enabling BLE..."
          level: INFO
      - switch.turn_on: bedroom_left_blind_ble
      - switch.turn_on: bedroom_right_blind_ble
      - wait_until:
          condition:
            and:
          timeout: 3min
      - if:
          condition:
            and:
          then:
            - logger.log:
                format: "BLE clients connected"
                level: INFO
          else:
            - logger.log:
                format: "Fail connect BLE clients"
                level: WARN
  - id: disable_ble
    mode: restart
    then:
      - logger.log:
          format: "Disabling BLE..."
          level: INFO
      - switch.turn_off: bedroom_left_blind_ble
      - switch.turn_off: bedroom_right_blind_ble
  - id: sleeping_ble
    mode: restart
    then:
      - while:
          condition:
            not:
              and:
          then:
            - logger.log:
                format: "Conencting BLE again..."
                level: INFO
      - logger.log:
          format: "Updating sensors..."
          level: INFO
      - delay: 2min
      - logger.log:
          format: "Check that scripts not running..."
          level: INFO
      - while:
          condition:
            or:
              - script.is_running: open_action
              - script.is_running: close_action
              - script.is_running: stop_action
              - script.is_running: position_action
          then:
            - logger.log:
                format: "Still executing..."
                level: INFO
            - delay: 10s
      - script.execute: disable_ble
      - script.wait: disable_ble
  - id: main
    mode: single
    then:
      - while:
          condition:
            - lambda: "return true;"
          then:
            - script.execute: sleeping_ble
            - script.wait: sleeping_ble
            - delay: 60min
binary_sensor:
    name: "Bedroom Left Blind Connected"
    name: "Bedroom Right Blind Connected"
  - platform: uptime
  - platform: ble_rssi
    name: "Bedroom Left Blind RSSI"
    name: "Bedroom Right Blind RSSI"
  - platform: am43
    illuminance:
      name: "Bedroom Left Blind Light"
      filters:
        - filter_out: nan
    battery_level:
      name: "Bedroom Left Blind Battery"
      filters:
        - filter_out: nan
  - platform: am43
    illuminance:
      name: "Bedroom Right Blind Light"
      filters:
        - filter_out: nan
    battery_level:
      name: "Bedroom Right Blind Battery"
      filters:
        - filter_out: nan
switch:
  - platform: restart
    name: "Bedroom Blind ESP Reboot"
  - platform: ble_client
    name: "Bedroom Left Blind BLE"
    internal: true
    disabled_by_default: true
    name: "Bedroom Right Blind BLE"
    internal: true
Can anyone share a configuration for a single blind with ble on/off etc?
I can’t get it to work…
Thank you for your script, this looks really nice.
What I can’t get to work is setting the position. Does it work for you?
Somehow variable “pos” does not get transfered to global var “position”.
The position_action (cover: template) does have the pos value (see below), but the script does not have the id(position) value (always 0). I double checked that I have the globals set and consulted the docs but can’t figure out whats wrong. (I’m a noob with such scripting.)
[07:52:45][D][cover:076]: 'Buro Cover' - Setting
[07:52:45][D][cover:084]:   Position: 31%
[07:52:45][I][main:161]: Enabling BLE...
[07:52:45][D][switch:013]: 'Buro Blind BLE' Turning ON.
[07:52:45][I][main:174]: BLE clients connected
[07:52:45][D][cover:076]: 'buro_blinds_am43_cover_internal' - Setting
[07:52:45][D][cover:084]:   Position: 0%
For testing, I moved the script part to the cover:template like this and it works:
    position_action:
      then:
#        - lambda: |-
#            id(position) = pos;
#        - script.execute: position_action
#        - script.wait: position_action
##temp edit: moved position_action-script to cover-template, replaced id(position) with pos
        - if:
            condition:
              and:
                - binary_sensor.is_on: buro_blinds_am43_connected
            then:
              - lambda: |-
                  auto call = id(buro_blinds_am43_cover_internal).make_call();
                  call.set_position(pos);
                  call.perform();
I am having the same issue and I am not using external_components. Any idea on how to resolve it?
I think you need to describe your problem and what your logs show. Not quite sure what you are referring to when replying to my comment.
Would be great if someone could paste a working configuration and/or short description on how to get it running with ESPhome if NOT using a separate ESP32 (or other device). I can’t install any of the configurations above as I’m trying to install it on the main device which is not a ESP32.
I understand the “external components” line is no longer necessary, right?
How should the ESPhome yaml look like if running on a standalone machine?
Thank you so much!
Got it to work on an ESP32 (Wroom). Kind of, that is: It worked once (both blinds went up), but since then I couldn’t connect to the blinds anymore and it’s very unstable overall.
[14:51:10][I][am43_cover:032]: [right_blind_cover_internal] Logging into AM43
[14:51:11][I][am43_cover:123]: [right_blind_cover_internal] AM43 pin accepted.
[14:51:39][I][ble_client:086]: Attempting BLE connection to 02:97:7a:90:93:1e
[14:51:39][W][ble_client:119]: connect to 02:97:7a:90:93:1e failed, status=133
[14:52:02][I][ble_client:086]: Attempting BLE connection to 02:97:7a:90:93:1e
[14:52:03][W][ble_client:119]: connect to 02:97:7a:90:93:1e failed, status=133
[14:52:08][I][ble_client:086]: Attempting BLE connection to 02:97:7a:90:93:1e
[14:52:09][W][ble_client:119]: connect to 02:97:7a:90:93:1e failed, status=133
Then, all of a sudden, it’s working again:
[14:55:15][I][ble_client:384]:  characteristic 0xFE51, handle 0xe, properties 0x16
[14:55:15][I][ble_client:384]:  characteristic 0xFE52, handle 0x11, properties 0x8
[14:55:15][I][main:172]: BLE clients connected
[14:56:42][I][main:156]: Enabling BLE...
[14:56:42][I][main:172]: BLE clients connected
Does anyone have any idea how to make it more stable?
Hmm, strange thing, i don’t have any trouble with lambda, glade that you have found workaround)
what should i flash it with? or only set it up and connect to the device?
You should read a bit on esphome.io to get a better understanding. There you can also find relevant channels to ask for or find more generic help.
GLHF
when I do sudo ./am43ctrl beef60027245 all I get is the following:
Usage: am43ctrl MAC1 MAC2 --express-port 3000 --url [mqtt|ws][s]://yourbroker.example.com
Options:
  --help                      Show help        [boolean]
  --version                   Show version number        [boolean]
  -d, --debug                 Enable debug logging        [boolean]
  -l, --express-port          Port for express web server (if unset, express will not startup)                               [number]
  --url, --mqtt-url           MQTT broker URL
  --topic, --mqtt-base-topic  Base topic for MQTT                                                          [default: "homeassistant"]
  -p, --mqtt-password         Password for MQTT (if not specified as an argument, will prompt for password at startup)
  -u, --mqtt-username         Username for MQTT
  -i, --interval              Minutes interval for device polling (default is random 10 to 20)                  [number] [default: 0]
  -f, --fail-time             Seconds since last successful device connection before program exit (default is never exit)
Examples:
  am43ctrl MAC1 MAC2 --url [broker_url]  Connect to devices with specific IDs only, publish to MQTT
can you help please?
ESPHome 2022.10.2 has introduced new rssi sensor which breaks previous script version. I’ve update the script which is worked on ESPHome 2022.11.0b4 (but without rssi still):
esphome:
  platform: ESP32
  on_boot:
    - script.wait: main
wifi:
logger:
  level: DEBUG
api:
ota:
  password: "XXXXXXXXXXXXX"
globals:
  - id: position
    type: int
    restore_value: no
  - id: left_connected
    type: bool
    restore_value: no
    initial_value: 'false'
  - id: right_connected
    type: bool
    restore_value: no
bluetooth_proxy:
  active: true
esp32_ble_tracker:
ble_client:
    on_connect:
      - globals.set:
          value: 'true'
    on_disconnect:
      - globals.set:
          value: 'false'
    on_connect:
      - globals.set:
          value: 'true'
    on_disconnect:
      - globals.set:
          value: 'false'
  - platform: uptime
  # - platform: ble_client
  #   type: rssi
  #   ble_client_id: bedroom_left_blind
  #   name: "Bedroom Left Blind RSSI"
  #   type: rssi
  #   ble_client_id: bedroom_right_blind
  #   name: "Bedroom Right Blind RSSI"
  - platform: am43
    illuminance:
      filters:
        - filter_out: nan
    battery_level:
      filters:
        - filter_out: nan
    update_interval: 30sec
  - platform: am43
    illuminance:
      filters:
        - filter_out: nan
    battery_level:
      filters:
        - filter_out: nan
switch:
  - platform: restart
cover:
  - platform: am43
    pin: 1234
    internal: true
  - platform: am43
    pin: 1234
    internal: true
    has_position: true
    lambda: |-
    open_action:
      then:
    close_action:
      then:
    stop_action:
      then:
    position_action:
      then:
        - lambda: |-
            id(position)=pos;
    on_open:
      - logger.log: "Cover is Open!"
    on_closed:
      - logger.log: "Cover is Closed!"
script:
  - id: open_action
    mode: restart
    then:
      - logger.log:
          format: "Open..."
          level: INFO
      - logger.log:
          format: "...opened"
          level: INFO
  - id: close_action
    mode: restart
    then:
      - logger.log:
          format: "Close..."
          level: INFO
      - logger.log:
          format: "...closed"
          level: INFO
  - id: stop_action
    mode: restart
    then:
      - logger.log:
          format: "Stop..."
          level: INFO
      - logger.log:
          format: "...stoped"
          level: INFO
    mode: restart
    then:
      - logger.log:
          format: "Set position..."
          level: INFO
      - lambda: |-
          call.perform();
          call.perform();
  - id: enable_ble
    mode: restart
    then:
      - logger.log:
          level: INFO
      - if:
          condition:
            - switch.is_off: bedroom_left_blind_ble
          then:
      - if:
          condition:
            - switch.is_off: bedroom_right_blind_ble
          then:
      - wait_until:
          condition:
            lambda: |-
              return id(left_connected) && id(right_connected);
          timeout: 1min
      - if:
          condition:
            lambda: |-
              return !id(left_connected) || !id(right_connected);
          then:
            - logger.log:
                format: "... fail connect BLE clients, trying again ... "
                level: WARN
      - logger.log:
          format: "...BLE enabled"
          level: INFO
  - id: disable_ble
    mode: single
    then:
      - logger.log:
          level: INFO
      - wait_until:
          condition:
            lambda: |-
              return !id(left_connected) && !id(right_connected);
      - logger.log:
          format: "...BLE disabled"
          level: INFO
  - id: update_sensors
    mode: single
    then:
      - logger.log:
          level: INFO
      - delay: 1min
      - logger.log:
          level: INFO
      - while:
          condition:
            or:
          then:
            - logger.log:
                format: "Something Still executing..."
                level: INFO
            - delay: 10s
      - logger.log:
          format: "...sensors updated"
          level: INFO
  - id: main
    mode: single
    then:
      - while:
          condition:
          then:
            - script.execute: update_sensors
            - script.wait: update_sensors
            - delay: 60min
Here is a new version with worked position and verified on EspHome 2022.11.0
esphome:
  platform: ESP32
  on_boot:
    - script.wait: main
wifi:
logger:
  level: INFO
api:
ota:
  password: "XXXXXXXXX"
ble_client:
    on_connect:
          state: ON
      - logger.log:
          format: "CONNECT LEFT"
          level: INFO
    on_disconnect:
          state: OFF
      - logger.log:
          format: "DISCONNECT LEFT"
          level: INFO
    on_connect:
          state: ON
      - logger.log:
          format: "CONNECT RIGHT"
          level: INFO
    on_disconnect:
          state: OFF
      - logger.log:
          format: "DISCONNECT RIGHT"
          level: INFO
binary_sensor:
    device_class: connectivity
    name: "Left connected"
    name: "Right connected"
    device_class: opening
  - platform: uptime
  #   id: bedroom_left_blind_rssi
  #   type: rssi
  #   id: bedroom_right_blind_rssi
  #   type: rssi
  - platform: am43
    illuminance:
      filters:
        - filter_out: nan
    battery_level:
      filters:
        - filter_out: nan
  - platform: am43
    illuminance:
      filters:
        - filter_out: nan
    battery_level:
      filters:
        - filter_out: nan
switch:
  - platform: restart
cover:
  - platform: am43
    pin: 1234
    internal: true
    on_open:
          state: ON
    on_closed:
          state: OFF
  - platform: am43
    pin: 1234
    internal: true
    on_open:
          state: ON
    on_closed:
          state: OFF
    has_position: true
    lambda: |-
    open_action:
      then:
    close_action:
      then:
    stop_action:
      then:
    position_action:
      then:
        - script.execute:
            value: !lambda return pos;
script:
  - id: open_action
    mode: restart
    then:
      - script.stop: close_action
      - script.stop: stop_action
      - script.stop: position_action
      - script.stop: update_sensors
      - logger.log:
          format: "Open ..."
          level: INFO
      - while:
          condition:
            not:
              and:
                - binary_sensor.is_on: left_open_status
                - binary_sensor.is_on: right_open_status
          then:
            - logger.log:
                format: "... opening ..."
                level: INFO
            - delay: 1sec
      - logger.log:
          format: "... opened"
          level: INFO
  - id: close_action
    mode: restart
    then:
      - script.stop: open_action
      - logger.log:
          format: "Close ..."
          level: INFO
      - while:
          condition:
            not:
              and:
                - binary_sensor.is_off: left_open_status
                - binary_sensor.is_off: right_open_status
          then:
            - logger.log:
                format: "... closing ..."
                level: INFO
            - delay: 1sec
      - logger.log:
          format: "... closed"
          level: INFO
  - id: stop_action
    mode: restart
    then:
      - logger.log:
          format: "Stop ..."
          level: INFO
      - logger.log:
          format: "... stoped"
          level: INFO
    mode: restart
    parameters:
      value: float
    then:
      - logger.log:
          format: "Set position %f ..."
          level: INFO
          args: [ value ]
      - cover.control:
          position: !lambda return value;
      - cover.control:
  - id: enable_ble
    mode: restart
    then:
      - script.stop: disable_ble
      - logger.log:
          level: INFO
      - if:
          condition:
          then:
      - if:
          condition:
          then:
      - while:
          condition:
            not:
              and:
                - binary_sensor.is_on: left_connected
                - binary_sensor.is_on: right_connected
          then:
            - logger.log:
                format: "... waiting connection ..."
                level: INFO
            - delay: 1sec
      - logger.log:
          level: INFO
  - id: disable_ble
    mode: single
    then:
      - logger.log:
          format: "Disabling BLE ..."
          level: INFO
      - logger.log:
          format: "... BLE disabled"
          level: INFO
    mode: single
    then:
      - logger.log:
          format: "Updating sensor ..."
          level: INFO
      - delay: 1min
      - while:
          condition:
            or:
          then:
            - logger.log:
                format: "... domething Still executing ..."
                level: INFO
            - delay: 10s
      - logger.log:
          format: "... sensors updated"
          level: INFO
  - id: main
    mode: single
    then:
      - while:
          condition:
          then:
            - delay: 60min
Thank you, working really nice!
looks great, but can’t connect to my AM43
16:34:06	[I]	[main:275]
16:34:06	[W]	[am43:098]
[02:9E:88:EB:B5:F6] Cannot poll, not connected
It’s to old (2020) or what I think I’m trying all :confused:
make sure that you have set valid mac in the ble_client.mac_address and sensor.platform: ble_rssi.mac_address. And double check pin, ble_client_id, id for cover.platform: am43 sections. Don’t hesitate to share you conf and logs if there is some issues still.
