I want an automation that
- Fires when one of several temperature sensors is below a value
- Time is between 08:00 and 16:00
- Someone is at home
As far as I can tell there is no way to check if anyone is home other than to say Bill is home or Ted is home… If there is that would make things a little easier I guess
I just wanted to check the AND / OR logic I have is correct.
Triggers are OR? so if I specify multiple trigger the automation will fire on any of them?
Conditions are AND? If I add two conditions the automation will only fire if both conditions are met?
The OR condition type only applies to that condition so that is still AND with other conditions
I have this setup, does this achieve the above logic?
alias: House Temp - Day - Heat
description: ''
- platform: numeric_state
entity_id: sensor.temp6_temperature
below: '19'
entity_id: sensor.kitchen_temperature
below: '19'
condition:
- condition: time
after: '08:00'
before: '16:00'
weekday:
- mon
- tue
- wed
- thu
- fri
- condition: or
conditions:
- condition: zone
entity_id: person.bill
zone: zone.home
- condition: zone
entity_id: person.ted
zone: zone.home
- service: climate.set_temperature
device_id: xxx
temperature: 22
mode: single
