<!-- READ THIS FIRST:
- Make sure you run the latest version of the Android app…
- Make sure you run the latest version of Home Assistant
- Make sure to check the Companion docs for troubleshooting and configuration: https://companion.home-assistant.io/
- Make sure the bug you found is not already reported, we love to put work in bugfixes instead of closing duplicate bug reports
DO NOT DELETE ANY TEXT from this template! All requested information is important.
**Home Assistant Android version:**
Home assistant for Wear OS 2022.2.1
**Android version:**
One UI Watch Version 4.0
**Phone model:**
Samsung Galaxy Watch 4
**Home Assistant version:**
Home Assistant 2022.3.3
**Last working Home Assistant release (if known):**
**Description of problem:**
Cant switch switches buttons and so on, when application ran at background (not closed) status of switches reset and does not get updated, when application is restarted statuses of switches and buttons getting updated however they do not operate on press.
**Traceback (if applicable, to get the logs you may refer to: https://companion.home-assistant.io/docs/troubleshooting/faqs/#android-crash-logs):**
2022-03-12 23:26:45.273 16517-17093/? E/SensorReceiver: Exception while updating sensors.
io.homeassistant.companion.android.common.data.integration.IntegrationException: com.fasterxml.jackson.databind.exc.MismatchedInputException: No content to map due to end-of-input
at [Source: (okhttp3.ResponseBody$BomAwareReader); line: 1, column: 0]
at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:607)
at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
at kotlinx.coroutines.internal.LimitedDispatcher.run(LimitedDispatcher.kt:39)
at kotlinx.coroutines.scheduling.TaskImpl.run(Tasks.kt:95)
at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
Caused by: com.fasterxml.jackson.databind.exc.MismatchedInputException: No content to map due to end-of-input
at com.fasterxml.jackson.databind.DeserializationContext.reportInputMismatch(DeserializationContext.java:1741)
at com.fasterxml.jackson.databind.ObjectReader._initForReading(ObjectReader.java:359)
at com.fasterxml.jackson.databind.ObjectReader._bindAndClose(ObjectReader.java:2041)
at com.fasterxml.jackson.databind.ObjectReader.readValue(ObjectReader.java:1459)
at retrofit2.converter.jackson.JacksonResponseBodyConverter.convert(JacksonResponseBodyConverter.java:33)
at retrofit2.converter.jackson.JacksonResponseBodyConverter.convert(JacksonResponseBodyConverter.java:23)
at retrofit2.OkHttpCall.parseResponse(OkHttpCall.java:243)
at retrofit2.OkHttpCall$1.onResponse(OkHttpCall.java:153)
at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:519)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
at java.lang.Thread.run(Thread.java:923)
2022-03-12 23:26:45.294 16517-17066/? I/WM-WorkerWrapper: Worker result SUCCESS for Work [ id=935d8f36-922b-4220-9238-451957459faf, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
2022-03-12 23:26:45.298 567-1818/? D/BaseRestrictionMgr: callerPkgName:io.homeassistant.companion.android calleePackage:io.homeassistant.companion.android action:ACTION_STOP_FOREGROUND for type:startService
2022-03-12 23:26:45.298 567-1818/? I/BaseRestrictionMgr: begin mask is CHECK_ISFREEZED:false CHECK_ISRESTRICTED:true MATCH_ANYRESTRICTION:false CHECK_ISALLOWED:false
2022-03-12 23:26:45.298 567-1818/? I/BaseRestrictionMgr: restrictions:536870912 mask is CHECK_ISFREEZED:false CHECK_ISRESTRICTED:true MATCH_ANYRESTRICTION:false CHECK_ISALLOWED:false
2022-03-12 23:26:45.298 567-1818/? I/BaseRestrictionMgr: mask is CHECK_ISFREEZED:false CHECK_ISRESTRICTED:false MATCH_ANYRESTRICTION:false CHECK_ISALLOWED:true
2022-03-12 23:26:45.324 567-1818/? I/SamsungAlarmManager: setLocked to kernel - W:2 / NW:28741364, now=28540322
2022-03-12 23:26:45.324 567-1818/? I/SamsungAlarmManager: setLocked to kernel - W:3 / NW:28554998, now=28540322
2022-03-12 23:26:45.324 567-1818/? D/SamsungAlarmManager: setInexact (T:3/F:0/AC:false) 20220312T224145(O:29440293/E:29440293/ME:30115272/RI:0) now=28540322 - CU:1000/CP:567/L:ab6cc18:*job.delay*
2022-03-12 23:26:45.423 16517-16517/? I/WM-SystemFgDispatcher: Stopping foreground service
2022-03-12 23:26:45.430 567-689/? D/ConnectivityService: releasing NetworkRequest [ TRACK_DEFAULT id=150, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Uid: 10124 AdministratorUids: [] RequestorUid: 10124 RequestorPackageName: io.homeassistant.companion.android] ] (release request)
2022-03-12 23:26:45.447 567-1818/? D/SamsungAlarmManager: Cancel Alarm calling from uid:10108 pid :951 / OP:PendingIntent{d68e2d5: PendingIntentRecord{36c841e com.google.android.gms/ startService}}
2022-03-12 23:26:45.448 567-1818/? I/SamsungAlarmManager: setLocked to kernel - W:2 / NW:28741364, now=28540446
2022-03-12 23:26:45.448 567-1818/? I/SamsungAlarmManager: setLocked to kernel - W:3 / NW:28554998, now=28540446
2022-03-12 23:26:45.454 1304-1304/? D/WCS: [StreamBackendInit]NotificationService onNotificationRemoved StatusBarNotification(pkg=io.homeassistant.companion.android user=UserHandle{0} id=42 tag=null key=0|io.homeassistant.companion.android|42|null|10124: Notification(channel=Sensor Worker shortcut=null contentView=null vibrate=null sound=null defaults=0x0 flags=0x62 color=0x00000000 vis=PRIVATE))
2022-03-12 23:26:45.455 1304-1660/? D/CollectorHandler: handleMessage, event: ON_NOTIFICATION_REMOVED
2022-03-12 23:26:45.455 1304-1660/? D/WCS: [MigrationStreamManager]onNotificationRemoved: StreamItemIdAndRevision{notifKey=0|io.homeassistant.companion.android|42|null|10124, packageName=io.homeassistant.companion.android, id=42, revision=0, originalRevision=0, updateCount=0}
2022-03-12 23:26:45.455 1304-1660/? D/WCS: [StreamDBQueue]Promised revision #6615 to queue a new op
2022-03-12 23:26:45.456 1304-1660/? D/WCS: [WatchStreamManager]Promised remove @ r#6615 for StreamItemIdAndRevision{notifKey=0|io.homeassistant.companion.android|42|null|10124, packageName=io.homeassistant.companion.android, id=42, revision=0, originalRevision=0, updateCount=0} (@6614): SBN removed: StreamItemIdAndRevision{notifKey=0|io.homeassistant.companion.android|42|null|10124, packageName=io.homeassistant.companion.android, id=42, revision=0, originalRevision=0, updateCount=0}
2022-03-12 23:26:45.456 1304-16356/? D/StreamDatabase: remove. itemId: StreamItemIdAndRevision{notifKey=0|io.homeassistant.companion.android|42|null|10124, packageName=io.homeassistant.companion.android, id=42, revision=6613, originalRevision=6611, updateCount=1}
2022-03-12 23:26:45.457 1304-16356/? D/WCS: [MigrationStreamManager]notifyChange: StreamChangeEvent[modified=0, removed=1, modifiedTop=0, removedTop=1, reorder=false, possibleAlertingItem=none]
2022-03-12 23:26:45.457 1304-16356/? D/WCS: [WcsStreamListener]Notifying WCS client notification updates, modified items = 0
2022-03-12 23:26:45.459 759-4845/? I/WNoti: [WNotiListener] onChangeEvent(237) > StreamChangeEvent[modified=0, removed=1, modifiedTop=0, removedTop=1, reorder=false, possibleAlertingItem=none]
removed:
removedTopLevel:
2022-03-12 23:26:45.459 759-4845/? I/WNotiPopup: [WNotiPopupModule] notifyChange(146) > CustomStreamChangeEvent[modified=0, removed=1, modifiedTop=0, removedTop=1, reorder=false, possibleAlertingItem=none]
removed:
removedTopLevel:
2022-03-12 23:26:45.460 759-4845/? I/WNoti: [WNotiPopupSmall] hide(57) > [6611/6613]
2022-03-12 23:26:45.460 759-4425/? I/WNoti: [WNotiManager] removeInternal(870) > [6611/6613] remove
2022-03-12 23:26:45.463 759-4425/? W/WNoti: [WNotiManager] removeInternal(878) > Removal broadcast did not sent!!
2022-03-12 23:26:45.465 1304-16418/? D/WCS: [StreamDBQueue]Promised revision #6616 to queue a new op
2022-03-12 23:26:45.465 1304-16418/? D/WatchStreamManager: Promised mark-item-read @ r#6616 for StreamItemIdAndRevision{notifKey=0|io.homeassistant.companion.android|42|null|10124, packageName=io.homeassistant.companion.android, id=42, revision=6613, originalRevision=6611, updateCount=1}
2022-03-12 23:26:45.466 759-759/? I/SysUI: [WatchFaceUiController]sendStateToWatchFace
2022-03-12 23:26:45.468 759-759/? I/SysUI: [SecWatchFaceOverlayUi]Unread count : 0
2022-03-12 23:26:45.468 1304-16356/? D/WCS: [WcsStreamDatabaseListener]Notifying SysUI notification listener
2022-03-12 23:26:45.471 567-612/? D/BaseRestrictionMgr: callerPkgName:com.google.android.wearable.app calleePackage:com.google.android.wearable.app action:android.support.wearable.complications.ACTION_REQUEST_UPDATE_ALL for type:broadcast
2022-03-12 23:26:45.473 567-612/? D/BaseRestrictionMgr: callerPkgName:com.google.android.wearable.app calleePackage:com.google.android.wearable.app action:android.support.wearable.complications.ACTION_REQUEST_UPDATE_ALL for type:broadcast
2022-03-12 23:26:45.473 1304-17100/? D/WCS: [ComplicationController]scheduleImmediateUpdateForAllFromProvider ComponentInfo{com.google.android.wearable.app/com.google.android.clockwork.home.complications.providers.UnreadNotificationsProviderService}
2022-03-12 23:26:45.474 567-612/? D/BaseRestrictionMgr: callerPkgName:com.samsung.android.wearable.sysui calleePackage:com.samsung.android.watch.watchface.companionhelper action:com.samsung.android.watch.intent.action.NOTIFICATION_UNREAD_CHANGED for type:broadcast
2022-03-12 23:26:45.477 15775-15775/? I/CompanionHelper: [CommonDataBroadcastReceiver] action:com.samsung.android.watch.intent.action.NOTIFICATION_UNREAD_CHANGED
2022-03-12 23:26:45.477 759-759/? I/SysUI: [SecWatchFaceOverlayUi]sendOverlayView by noti
2022-03-12 23:26:45.477 15775-15775/? I/CompanionHelper: [WatchfaceStylizerTutorialContentsProvider] update uri: content://com.samsung.android.watch.watchface.companionhelper.stylizertutorial.provider/notification_unread
2022-03-12 23:26:45.477 15775-15775/? I/CompanionHelper: [WatchfaceStylizerTutorialContentsProvider] unreadState:false
2022-03-12 23:26:45.478 567-1324/? I/DisplayOffload: [DisplayOffloadService$BinderService] sendStatusBar(2093) > HIT
2022-03-12 23:26:45.478 567-1324/? D/DisplayOffload: RECEIVED STATUS BAR: 97
2022-03-12 23:26:45.478 567-1324/? D/DisplayOffload: [DisplayOffloadService$BinderService] sendStatusBar(2103) > mCurrentLayoutType: 2, mDisplayOffloadIsControlling: false
2022-03-12 23:26:45.480 15775-15775/? I/CompanionHelper: [CommonDataBroadcastReceiver] setting value updated to : false result = 1
2022-03-12 23:26:45.484 1304-16356/? D/WCS: [NewStreamAdapter]Publishing revision #6615 to adapter clients
2022-03-12 23:26:45.484 1304-16356/? D/WCS: [MigrationStreamManager]notifyChange: StreamChangeEvent[modified=0, removed=0, modifiedTop=0, removedTop=0, reorder=false, possibleAlertingItem=none]
2022-03-12 23:26:45.484 1304-17100/? D/WCS: [ComplicationController]scheduleImmediateUpdateForAllFromProvider ComponentInfo{com.google.android.wearable.app/com.google.android.clockwork.wcs.notification.complication.TopNotificationProviderService}
2022-03-12 23:26:45.485 1304-16356/? D/WCS: [WcsStreamDatabaseListener]Notifying SysUI notification listener
2022-03-12 23:26:45.486 1304-16356/? D/WCS: [NewStreamAdapter]Publishing revision #6616 to adapter clients
2022-03-12 23:26:45.591 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:45.595 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"result","success":true,"result":null}
2022-03-12 23:26:45.603 16517-16517/? D/WebSocketRepository: Sending message 6: {type=subscribe_events, event_type=area_registry_updated, id=6}
2022-03-12 23:26:45.606 16517-16517/? D/WebSocketRepository: Message number 6 sent
2022-03-12 23:26:45.909 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:45.910 16517-17082/? D/WebSocketRepository: Message number 6 received: {"id":6,"type":"result","success":true,"result":null}
2022-03-12 23:26:45.914 16517-16517/? D/WebSocketRepository: Sending message 7: {type=subscribe_events, event_type=device_registry_updated, id=7}
2022-03-12 23:26:45.915 16517-16517/? D/WebSocketRepository: Message number 7 sent
2022-03-12 23:26:45.991 302-302/? I/io_stats: !@ 179,0 r 233769 6224674 w 35929 704344 d 20551 535108 f 37707 16519 iot 217868 0 th 51200 0 0 pt 0 inp 0 0 5701.772
2022-03-12 23:26:46.377 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:46.380 16517-17082/? D/WebSocketRepository: Message number 7 received: {"id":7,"type":"result","success":true,"result":null}
2022-03-12 23:26:46.385 16517-16517/? D/WebSocketRepository: Sending message 8: {type=subscribe_events, event_type=entity_registry_updated, id=8}
2022-03-12 23:26:46.386 16517-16517/? D/WebSocketRepository: Message number 8 sent
2022-03-12 23:26:46.858 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:46.860 16517-17082/? D/WebSocketRepository: Message number 8 received: {"id":8,"type":"result","success":true,"result":null}
2022-03-12 23:26:47.614 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:47.618 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.inverter_voltage","old_state":{"entity_id":"sensor.inverter_voltage","state":"214.8","attributes":{"unit_of_measurement":"V","device_class":"voltage","friendly_name":"Inverter voltage"},"last_changed":"2022-03-12T19:26:38.666602+00:00","last_updated":"2022-03-12T19:26:38.666602+00:00","context":{"id":"fcfe7501f68f51c7c2cc1d78823e4c22","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.inverter_voltage","state":"217.1","attributes":{"unit_of_measurement":"V","device_class":"voltage","friendly_name":"Inverter voltage"},"last_changed":"2022-03-12T19:26:48.666917+00:00","last_updated":"2022-03-12T19:26:48.666917+00:00","context":{"id":"1f0867f69100b535ad364d2b468b9485","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:48.666917+00:00","context":{"id":"1f0867f69100b535ad364d2b468b9485","parent_id":null,"user_id":null}}}
2022-03-12 23:26:47.757 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:47.758 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.grid_voltage","old_state":{"entity_id":"sensor.grid_voltage","state":"215.6","attributes":{"unit_of_measurement":"V","device_class":"voltage","friendly_name":"Grid voltage"},"last_changed":"2022-03-12T19:26:38.805589+00:00","last_updated":"2022-03-12T19:26:38.805589+00:00","context":{"id":"f536d8b0912589028e0a3b53afe1ffcd","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.grid_voltage","state":"217.9","attributes":{"unit_of_measurement":"V","device_class":"voltage","friendly_name":"Grid voltage"},"last_changed":"2022-03-12T19:26:48.806368+00:00","last_updated":"2022-03-12T19:26:48.806368+00:00","context":{"id":"212571da9e5690de5d8bf82d3bb8bd02","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:48.806368+00:00","context":{"id":"212571da9e5690de5d8bf82d3bb8bd02","parent_id":null,"user_id":null}}}
2022-03-12 23:26:47.836 16517-17057/? I/mpanion.androi: Background young concurrent copying GC freed 46031(1761KB) AllocSpace objects, 0(0B) LOS objects, 5% free, 20MB/21MB, paused 1.648ms total 208.939ms
2022-03-12 23:26:48.338 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:48.342 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.grid_current","old_state":{"entity_id":"sensor.grid_current","state":"7.6","attributes":{"unit_of_measurement":"A","device_class":"current","friendly_name":"Grid current"},"last_changed":"2022-03-12T19:26:39.376168+00:00","last_updated":"2022-03-12T19:26:39.376168+00:00","context":{"id":"f537040bda975ae46f40f74150e05236","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.grid_current","state":"5.0","attributes":{"unit_of_measurement":"A","device_class":"current","friendly_name":"Grid current"},"last_changed":"2022-03-12T19:26:49.368591+00:00","last_updated":"2022-03-12T19:26:49.368591+00:00","context":{"id":"0b92d7f6880167b278619a9f4d81faf1","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:49.368591+00:00","context":{"id":"0b92d7f6880167b278619a9f4d81faf1","parent_id":null,"user_id":null}}}
2022-03-12 23:26:48.452 567-672/? D/InputReader: Btn_touch(2): value=1 when=5704.235105
2022-03-12 23:26:48.452 567-672/? I/InputReader: Touch event's action is 0x0 (id=5, t=0) [pCnt=1, s=0.1001 ] when=5704.235105
2022-03-12 23:26:48.454 16517-16517/? I/ViewRootImpl@a75b282[HomeActivity]: ViewPostIme pointer 0
2022-03-12 23:26:48.456 567-671/? I/InputDispatcher: Delivering touch to (16517): action: 0x0, f=0x0, d=0, '4383994', t=1
2022-03-12 23:26:48.459 790-790/? D/SYSTEM_UI: QuickpanelInputMonitor$3.onInputEvent(97): touch down position Y: 221.0
2022-03-12 23:26:48.462 567-671/? D/PowerManagerService: UserActivityStateListenerState: 1
2022-03-12 23:26:48.491 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:48.493 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.load_current","old_state":{"entity_id":"sensor.load_current","state":"7.2","attributes":{"unit_of_measurement":"A","device_class":"current","friendly_name":"Load current"},"last_changed":"2022-03-12T19:26:39.516396+00:00","last_updated":"2022-03-12T19:26:39.516396+00:00","context":{"id":"73e561985e16bd417a58dcc524044b00","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.load_current","state":"4.5","attributes":{"unit_of_measurement":"A","device_class":"current","friendly_name":"Load current"},"last_changed":"2022-03-12T19:26:49.506144+00:00","last_updated":"2022-03-12T19:26:49.506144+00:00","context":{"id":"5541c07f318e0114a73a72c62e5794f2","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:49.506144+00:00","context":{"id":"5541c07f318e0114a73a72c62e5794f2","parent_id":null,"user_id":null}}}
2022-03-12 23:26:48.548 567-672/? D/InputReader: Btn_touch(2): value=0 when=5704.331838
2022-03-12 23:26:48.548 567-672/? I/InputReader: Touch event's action is 0x1 (id=5, t=0) [pCnt=1, s=] when=5704.331838
2022-03-12 23:26:48.548 567-671/? I/InputDispatcher: Delivering touch to (16517): action: 0x1, f=0x0, d=0, '4383994', t=1
2022-03-12 23:26:48.549 16517-16517/? I/ViewRootImpl@a75b282[HomeActivity]: ViewPostIme pointer 1
2022-03-12 23:26:48.556 16517-16517/? D/UrlRepository: localUrl is: false and usesInternalSsid is: false
2022-03-12 23:26:48.612 16517-16517/? D/CompatibilityChangeReporter: Compat change id reported: 147798919; UID 10124; state: ENABLED
2022-03-12 23:26:48.628 411-411/? E/SecVibrator-HAL-AIDL-CORE: V_1_0: Vibrator reporting capabilities
2022-03-12 23:26:48.631 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: isNodeExist node:/timed_output/vibrator/intensity
2022-03-12 23:26:48.632 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: true
2022-03-12 23:26:48.633 567-1324/? D/PhoneWindowManagerExt: f.b. a=false id=0 callingPackage=io.homeassistant.companion.android hapticsEnabled=true touchBezelEnabled=true bezelHapticsEnabled=true Caller=com.android.server.policy.PhoneWindowManager.performHapticFeedback:6546 com.android.server.wm.Session.performHapticFeedback:291 android.view.IWindowSession$Stub.onTransact:1050 com.android.server.wm.Session.onTransact:144 android.os.Binder.execTransactInternal:1154
2022-03-12 23:26:48.633 567-1324/? D/Vibrator: binder call to service pkg=android, effect=SemHaptic{mType=50038, mRepeat=-1, mMagnitude=-1, mMagnitudeType=TYPE_TOUCH}
2022-03-12 23:26:48.633 567-1324/? V/VibratorService: vibrate - package: android, token: android.os.Binder@b0eadb2, usage: 0, effect: SemHaptic{mType=50038, mRepeat=-1, mMagnitude=-1, mMagnitudeType=TYPE_TOUCH}, mag: 10000, TYPE_TOUCH
2022-03-12 23:26:48.634 567-1324/? V/VibratorService: semColorfulVibrate - package: android, reason: null, repeat: -1, token: android.os.Binder@b0eadb2, usageHint : 0, flags: 0, mag: 10000, TYPE_TOUCH
2022-03-12 23:26:48.634 567-1324/? D/VibratorService: Turning vibrator off.
2022-03-12 23:26:48.634 411-411/? E/SecVibrator-HAL-AIDL-CORE: V_1_0: Vibrator off
2022-03-12 23:26:48.634 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:0
2022-03-12 23:26:48.635 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
2022-03-12 23:26:48.636 567-1324/? D/VibratorService: vibratorOn() : 20ms, mag :10000, type : 50038
2022-03-12 23:26:48.636 567-1324/? I/VibratorService: [VIB JNI] vibratorPerformHapticEngine()
2022-03-12 23:26:48.637 272-272/? I/servicemanager: Found android.hardware.vibrator.IVibrator/default in device VINTF manifest.
2022-03-12 23:26:48.638 567-1324/? E/VibratorService: [VIB JNI] getInterfaceVersion aidl remote_ver (2).
2022-03-12 23:26:48.638 567-1324/? I/VibratorService: [VIB JNI] vibratorSupportsHybridHapticEngine()
2022-03-12 23:26:48.639 272-272/? I/servicemanager: Found android.hardware.vibrator.IVibrator/default in device VINTF manifest.
2022-03-12 23:26:48.641 567-1324/? E/VibratorService: [VIB JNI] getInterfaceVersion aidl vendor command (2).
2022-03-12 23:26:48.642 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: supportsHybridHapticEngine
2022-03-12 23:26:48.642 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: isNodeExist node:/timed_output/vibrator/hybrid_haptic_engine
2022-03-12 23:26:48.642 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: true
2022-03-12 23:26:48.642 567-1324/? W/VibratorService: [VIB JNI] supportsHybridHapticEngine aidl vendor : true
2022-03-12 23:26:48.642 567-1324/? I/VibratorService: [VIB JNI] performHybridHapticEngine duration (20).
2022-03-12 23:26:48.642 567-1324/? I/VibratorService: [VIB JNI] performHybridHapticEngine amplitude (10000).
2022-03-12 23:26:48.642 567-1324/? I/VibratorService: [VIB JNI] performHybridHapticEngine type (1).
2022-03-12 23:26:48.642 567-1324/? I/VibratorService: [VIB JNI] performHybridHapticEngine data (9).
2022-03-12 23:26:48.643 567-1324/? I/VibratorService: [VIB JNI] performHybridHapticEngine overdriving (0).
2022-03-12 23:26:48.643 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine
2022-03-12 23:26:48.643 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine amplitude : 10000
2022-03-12 23:26:48.643 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine packet_cnt : 1
2022-03-12 23:26:48.643 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine total_size : 4
2022-03-12 23:26:48.643 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine : 4 20 10000 #9 0
2022-03-12 23:26:48.644 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: do_on for timeoutMs: 1
2022-03-12 23:26:48.644 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:1
2022-03-12 23:26:48.644 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
2022-03-12 23:26:48.644 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine OK
2022-03-12 23:26:48.644 567-1324/? W/VibratorService: [VIB JNI] performHybridHapticEngine aidl vendor : OK
2022-03-12 23:26:48.669 16517-16517/? I/ViewRootImpl@92103e6[Toast]: setView = android.widget.LinearLayout@c22ed27 TM=true
2022-03-12 23:26:48.675 567-567/? E/VibratorService: Vibration finished, cleaning up
2022-03-12 23:26:48.675 567-1818/? V/WindowManager: Relayout Window{5de024 u0 Toast}: viewVisibility=0 req=261x94
2022-03-12 23:26:48.675 567-567/? D/VibratorService: Turning vibrator off.
2022-03-12 23:26:48.677 567-1818/? D/WindowManager: makeSurface duration=0 name=Toast
2022-03-12 23:26:48.681 411-411/? E/SecVibrator-HAL-AIDL-CORE: V_1_0: Vibrator off
2022-03-12 23:26:48.682 567-1818/? V/WindowManager: Relayout hash=5de024, pid=16517: mAttrs={(0,21)(wrapxwrap) gr=BOTTOM CENTER sim={adjust=pan} ty=TOAST fmt=TRANSLUCENT wanim=0x1030004
fl=1000098
pfl=12000000
fitTypes=STATUS_BARS NAVIGATION_BARS CAPTION_BAR
fitIgnoreVis}
2022-03-12 23:26:48.684 16517-16517/? I/ViewRootImpl@92103e6[Toast]: Relayout returned: old=(0,0,450,450) new=(94,335,355,429) req=(261,94)0 dur=9 res=0x7 s={true 3601504256} ch=true fn=-1
2022-03-12 23:26:48.686 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:0
2022-03-12 23:26:48.693 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
2022-03-12 23:26:48.711 567-1818/? D/WindowManager: finishDrawingWindow: Window{5de024 u0 Toast} mDrawState=DRAW_PENDING
2022-03-12 23:26:48.717 567-605/? I/WindowManager: Reparenting to leash, surface=Surface(name=5de024 Toast)/@0xdb71f89, leashParent=Surface(name=WindowToken{e698bb6 android.os.Binder@9e1d751})/@0xf8a5b8e
2022-03-12 23:26:48.718 567-605/? D/WindowManager: makeSurface duration=1 leash=Surface(name=Surface(name=5de024 Toast)/@0xdb71f89 - animation-leash)/@0x3a26faf
2022-03-12 23:26:48.721 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:48.722 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.pinverter","old_state":{"entity_id":"sensor.pinverter","state":"-78.0","attributes":{"unit_of_measurement":"W","device_class":"power","friendly_name":"Pinverter"},"last_changed":"2022-03-12T19:26:39.657951+00:00","last_updated":"2022-03-12T19:26:39.657951+00:00","context":{"id":"ac727ee58d069b2e12fdec57db8224ff","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.pinverter","state":"-67.0","attributes":{"unit_of_measurement":"W","device_class":"power","friendly_name":"Pinverter"},"last_changed":"2022-03-12T19:26:49.646024+00:00","last_updated":"2022-03-12T19:26:49.646024+00:00","context":{"id":"08f5ad77dd37ef97d0b357a0e1b25062","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:49.646024+00:00","context":{"id":"08f5ad77dd37ef97d0b357a0e1b25062","parent_id":null,"user_id":null}}}
2022-03-12 23:26:48.764 421-421/? D/SurfaceFlinger: Display 0 HWC layers:
DEVICE | 0xf6503d00 | 0002 | RGBA_8888 | 0.0 0.0 450.0 450.0 | 0 0 450 450 | io.homeassistant.companion.android/i[...]ompanion.android.home.HomeActivity#0
DEVICE | 0xf6503700 | 0000 | RGBA_8888 | 0.0 0.0 261.0 94.0 | 94 335 355 429 | Toast#0
2022-03-12 23:26:48.775 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:48.776 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.pgrid","old_state":{"entity_id":"sensor.pgrid","state":"-1584.0","attributes":{"unit_of_measurement":"W","device_class":"power","friendly_name":"Pgrid"},"last_changed":"2022-03-12T19:26:39.807842+00:00","last_updated":"2022-03-12T19:26:39.807842+00:00","context":{"id":"31a415864fe2611e6af77bbe076e9dee","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.pgrid","state":"-935.0","attributes":{"unit_of_measurement":"W","device_class":"power","friendly_name":"Pgrid"},"last_changed":"2022-03-12T19:26:49.787258+00:00","last_updated":"2022-03-12T19:26:49.787258+00:00","context":{"id":"b11b6e3718f39af102e9651b2747c64a","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:49.787258+00:00","context":{"id":"b11b6e3718f39af102e9651b2747c64a","parent_id":null,"user_id":null}}}
2022-03-12 23:26:48.783 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:48.790 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.house_energy_negative","old_state":{"entity_id":"sensor.house_energy_negative","state":"1584.0","attributes":{"unit_of_measurement":"W","friendly_name":"house_energy_negative"},"last_changed":"2022-03-12T19:26:39.809630+00:00","last_updated":"2022-03-12T19:26:39.809630+00:00","context":{"id":"31a415864fe2611e6af77bbe076e9dee","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.house_energy_negative","state":"935.0","attributes":{"unit_of_measurement":"W","friendly_name":"house_energy_negative"},"last_changed":"2022-03-12T19:26:49.788960+00:00","last_updated":"2022-03-12T19:26:49.788960+00:00","context":{"id":"b11b6e3718f39af102e9651b2747c64a","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:49.788960+00:00","context":{"id":"b11b6e3718f39af102e9651b2747c64a","parent_id":null,"user_id":null}}}
2022-03-12 23:26:48.808 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:48.809 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.house_energy_used_total","old_state":{"entity_id":"sensor.house_energy_used_total","state":"-3168.0","attributes":{"unit_of_measurement":"W","friendly_name":"house_energy_used_total"},"last_changed":"2022-03-12T19:26:39.811509+00:00","last_updated":"2022-03-12T19:26:39.811509+00:00","context":{"id":"31a415864fe2611e6af77bbe076e9dee","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.house_energy_used_total","state":"-1870.0","attributes":{"unit_of_measurement":"W","friendly_name":"house_energy_used_total"},"last_changed":"2022-03-12T19:26:49.791172+00:00","last_updated":"2022-03-12T19:26:49.791172+00:00","context":{"id":"b11b6e3718f39af102e9651b2747c64a","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:49.791172+00:00","context":{"id":"b11b6e3718f39af102e9651b2747c64a","parent_id":null,"user_id":null}}}
2022-03-12 23:26:48.827 567-663/? D/SSRM:Temperature: SIOP:: AP : 294 CP : -999 BLK : 283 BAT : 278
2022-03-12 23:26:48.852 16517-17057/? I/mpanion.androi: Background young concurrent copying GC freed 30344(1483KB) AllocSpace objects, 0(0B) LOS objects, 8% free, 19MB/21MB, paused 978us total 151.171ms
2022-03-12 23:26:48.907 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:48.908 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.pload","old_state":{"entity_id":"sensor.pload","state":"1508.0","attributes":{"unit_of_measurement":"W","device_class":"power","friendly_name":"Pload"},"last_changed":"2022-03-12T19:26:39.956419+00:00","last_updated":"2022-03-12T19:26:39.956419+00:00","context":{"id":"c245763d4a142a55650ae9da94a9a009","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.pload","state":"853.0","attributes":{"unit_of_measurement":"W","device_class":"power","friendly_name":"Pload"},"last_changed":"2022-03-12T19:26:49.926052+00:00","last_updated":"2022-03-12T19:26:49.926052+00:00","context":{"id":"4e3cff26c4c13055a67839ff659f209e","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:49.926052+00:00","context":{"id":"4e3cff26c4c13055a67839ff659f209e","parent_id":null,"user_id":null}}}
2022-03-12 23:26:49.190 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:49.193 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.sinverter","old_state":{"entity_id":"sensor.sinverter","state":"163.0","attributes":{"unit_of_measurement":"VA","device_class":"power","friendly_name":"Sinverter"},"last_changed":"2022-03-12T19:26:40.246772+00:00","last_updated":"2022-03-12T19:26:40.246772+00:00","context":{"id":"960f795693b1d77bc288c013b13c9f6e","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.sinverter","state":"173.0","attributes":{"unit_of_measurement":"VA","device_class":"power","friendly_name":"Sinverter"},"last_changed":"2022-03-12T19:26:50.210623+00:00","last_updated":"2022-03-12T19:26:50.210623+00:00","context":{"id":"eff39b039c388bf2c9f79130cfb6ac7f","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:50.210623+00:00","context":{"id":"eff39b039c388bf2c9f79130cfb6ac7f","parent_id":null,"user_id":null}}}
2022-03-12 23:26:49.233 567-605/? I/WindowManager: Reparenting to original parent: Surface(name=WindowToken{e698bb6 android.os.Binder@9e1d751})/@0xf8a5b8e, destroy=true, surface=Surface(name=5de024 Toast)/@0xdb71f89
2022-03-12 23:26:49.240 567-605/? D/PowerManagerService: [api] acquire WakeLock SCREEN_BRIGHT_WAKE_LOCK 'WindowManager' ON_AFTER_RELEASE (uid=1000 pid=567 pkg=android ws=WorkSource{10124})
2022-03-12 23:26:49.317 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:49.320 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.sgrid","old_state":{"entity_id":"sensor.sgrid","state":"1498.0","attributes":{"unit_of_measurement":"VA","device_class":"power","friendly_name":"Sgrid"},"last_changed":"2022-03-12T19:26:40.385889+00:00","last_updated":"2022-03-12T19:26:40.385889+00:00","context":{"id":"63ff54c13221c8bc6bb782c349d07fff","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.sgrid","state":"1097.0","attributes":{"unit_of_measurement":"VA","device_class":"power","friendly_name":"Sgrid"},"last_changed":"2022-03-12T19:26:50.356520+00:00","last_updated":"2022-03-12T19:26:50.356520+00:00","context":{"id":"5326c1c85d7b07b8088a1d4da9f80aab","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:50.356520+00:00","context":{"id":"5326c1c85d7b07b8088a1d4da9f80aab","parent_id":null,"user_id":null}}}
2022-03-12 23:26:49.511 16517-17082/? D/WebSocketRepository: Websocket: onMessage (text)
2022-03-12 23:26:49.516 16517-17082/? D/WebSocketRepository: Message number 5 received: {"id":5,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.sload","old_state":{"entity_id":"sensor.sload","state":"1387.0","attributes":{"unit_of_measurement":"VA","device_class":"power","friendly_name":"Sload"},"last_changed":"2022-03-12T19:26:40.525389+00:00","last_updated":"2022-03-12T19:26:40.525389+00:00","context":{"id":"4c0278542a14ede259eff1db756ba5db","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.sload","state":"981.0","attributes":{"unit_of_measurement":"VA","device_class":"power","friendly_name":"Sload"},"last_changed":"2022-03-12T19:26:50.497641+00:00","last_updated":"2022-03-12T19:26:50.497641+00:00","context":{"id":"269c17d1872ce16049c798107491a457","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-03-12T19:26:50.497641+00:00","context":{"id":"269c17d1872ce16049c798107491a457","parent_id":null,"user_id":null}}}
2022-03-12 23:26:50.177 567-672/? D/InputReader: Btn_touch(2): value=1 when=5705.960467
2022-03-12 23:26:50.177 567-672/? I/InputReader: Touch event's action is 0x0 (id=5, t=0) [pCnt=1, s=0.1002 ] when=5705.960467
2022-03-12 23:26:50.179 16517-16517/? I/ViewRootImpl@a75b282[HomeActivity]: ViewPostIme pointer 0
2022-03-12 23:26:50.183 567-671/? I/InputDispatcher: Delivering touch to (16517): action: 0x0, f=0x0, d=0, '4383994', t=1
2022-03-12 23:26:50.187 790-790/? D/SYSTEM_UI: QuickpanelInputMonitor$3.onInputEvent(97): touch down position Y: 221.0
2022-03-12 23:26:50.285 567-672/? D/InputReader: Btn_touch(2): value=0 when=5706.069455
2022-03-12 23:26:50.285 567-672/? I/InputReader: Touch event's action is 0x1 (id=5, t=0) [pCnt=1, s=] when=5706.069455
2022-03-12 23:26:50.287 16517-16517/? I/ViewRootImpl@a75b282[HomeActivity]: ViewPostIme pointer 1
2022-03-12 23:26:50.290 567-671/? I/InputDispatcher: Delivering touch to (16517): action: 0x1, f=0x0, d=0, '4383994', t=1
2022-03-12 23:26:50.292 16517-16517/? D/UrlRepository: localUrl is: false and usesInternalSsid is: false
2022-03-12 23:26:50.310 411-411/? E/SecVibrator-HAL-AIDL-CORE: V_1_0: Vibrator reporting capabilities
2022-03-12 23:26:50.310 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: isNodeExist node:/timed_output/vibrator/intensity
2022-03-12 23:26:50.312 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: true
2022-03-12 23:26:50.315 567-1818/? D/PhoneWindowManagerExt: f.b. a=false id=0 callingPackage=io.homeassistant.companion.android hapticsEnabled=true touchBezelEnabled=true bezelHapticsEnabled=true Caller=com.android.server.policy.PhoneWindowManager.performHapticFeedback:6546 com.android.server.wm.Session.performHapticFeedback:291 android.view.IWindowSession$Stub.onTransact:1050 com.android.server.wm.Session.onTransact:144 android.os.Binder.execTransactInternal:1154
2022-03-12 23:26:50.315 567-1818/? D/Vibrator: binder call to service pkg=android, effect=SemHaptic{mType=50038, mRepeat=-1, mMagnitude=-1, mMagnitudeType=TYPE_TOUCH}
2022-03-12 23:26:50.316 567-1818/? V/VibratorService: vibrate - package: android, token: android.os.Binder@b0eadb2, usage: 0, effect: SemHaptic{mType=50038, mRepeat=-1, mMagnitude=-1, mMagnitudeType=TYPE_TOUCH}, mag: 10000, TYPE_TOUCH
2022-03-12 23:26:50.316 567-1818/? V/VibratorService: semColorfulVibrate - package: android, reason: null, repeat: -1, token: android.os.Binder@b0eadb2, usageHint : 0, flags: 0, mag: 10000, TYPE_TOUCH
2022-03-12 23:26:50.316 567-1818/? D/VibratorService: Turning vibrator off.
2022-03-12 23:26:50.319 411-411/? E/SecVibrator-HAL-AIDL-CORE: V_1_0: Vibrator off
2022-03-12 23:26:50.320 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:0
2022-03-12 23:26:50.321 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
2022-03-12 23:26:50.323 567-1818/? D/VibratorService: vibratorOn() : 20ms, mag :10000, type : 50038
2022-03-12 23:26:50.323 567-1818/? I/VibratorService: [VIB JNI] vibratorPerformHapticEngine()
2022-03-12 23:26:50.326 272-272/? I/servicemanager: Found android.hardware.vibrator.IVibrator/default in device VINTF manifest.
2022-03-12 23:26:50.329 567-1818/? E/VibratorService: [VIB JNI] getInterfaceVersion aidl remote_ver (2).
2022-03-12 23:26:50.330 567-1818/? I/VibratorService: [VIB JNI] vibratorSupportsHybridHapticEngine()
2022-03-12 23:26:50.335 272-272/? I/servicemanager: Found android.hardware.vibrator.IVibrator/default in device VINTF manifest.
2022-03-12 23:26:50.337 567-1818/? E/VibratorService: [VIB JNI] getInterfaceVersion aidl vendor command (2).
2022-03-12 23:26:50.338 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: supportsHybridHapticEngine
2022-03-12 23:26:50.338 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: isNodeExist node:/timed_output/vibrator/hybrid_haptic_engine
2022-03-12 23:26:50.339 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: true
2022-03-12 23:26:50.339 567-1818/? W/VibratorService: [VIB JNI] supportsHybridHapticEngine aidl vendor : true
2022-03-12 23:26:50.339 567-1818/? I/VibratorService: [VIB JNI] performHybridHapticEngine duration (20).
2022-03-12 23:26:50.339 567-1818/? I/VibratorService: [VIB JNI] performHybridHapticEngine amplitude (10000).
2022-03-12 23:26:50.339 567-1818/? I/VibratorService: [VIB JNI] performHybridHapticEngine type (1).
2022-03-12 23:26:50.339 567-1818/? I/VibratorService: [VIB JNI] performHybridHapticEngine data (9).
2022-03-12 23:26:50.339 567-1818/? I/VibratorService: [VIB JNI] performHybridHapticEngine overdriving (0).
2022-03-12 23:26:50.340 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine
2022-03-12 23:26:50.340 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine amplitude : 10000
2022-03-12 23:26:50.340 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine packet_cnt : 1
2022-03-12 23:26:50.340 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine total_size : 4
2022-03-12 23:26:50.340 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine : 4 20 10000 #9 0
2022-03-12 23:26:50.341 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: do_on for timeoutMs: 1
2022-03-12 23:26:50.341 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:1
2022-03-12 23:26:50.342 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
2022-03-12 23:26:50.342 411-411/? E/SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine OK
2022-03-12 23:26:50.342 567-1818/? W/VibratorService: [VIB JNI] performHybridHapticEngine aidl vendor : OK
2022-03-12 23:26:50.373 567-567/? E/VibratorService: Vibration finished, cleaning up
2022-03-12 23:26:50.373 567-567/? D/VibratorService: Turning vibrator off.
2022-03-12 23:26:50.379 411-411/? E/SecVibrator-HAL-AIDL-CORE: V_1_0: Vibrator off
2022-03-12 23:26:50.383 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:0
2022-03-12 23:26:50.384 411-411/? E/SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
2022-03-12 23:26:50.635 421-453/? E/BufferQueueProducer: [Toast#0](id:1a5000001d6,api:0,p:-1,c:421) disconnect: not connected (req=1)
2022-03-12 23:26:50.635 16517-17068/? W/libEGL: EGLNativeWindowType 0xd6aa9808 disconnect failed
**Screenshot of problem:**
Please check the following video: https://youtu.be/8RPoU_sDWl4
**Additional information:**
See discussion at: https://community.home-assistant.io/t/android-2021-12-wear-os-beta/369275/83?u=elik745i
