the stack traces themselves are missing here so the actual issue is not known all we know is that its failing to obtain the authentication. Anything else special about your setup? Are you using a proxy?
12-16 08:13:22.551 16322 16382 E WebSocketRepository: Websocket: onFailure
12-16 08:13:24.560 16322 16348 E IntegrationRepository: Issue getting new version from core.
12-16 09:02:25.907 24009 24009 E WebViewPresenterImpl: Unable to retrieve external auth
really important to know why it cant authenticate as that answer is held in the stacktraces themselves
I am on a pixel 6 pro on android 12 and do not have this issue.
How do I retrieve the stack trace? It’s probably somewhere in this thread. I’ll look it up.
It’s not a Hass issue I’m sure now, as as of that same moment in time I cannot retrieve any other local hostname anymore from this Android device. Also my wife’s Pixel 3 apparently has the same issue. My Android 10 Lenovo tablet, works without a problem.
Ah I see, I fear there’s nothing interesting in there. Here’s an example of a full log after a failed try to open a dashboard in the app:
--------- beginning of main
12-16 17:16:50.970 4783 4783 E mpanion.androi: Not starting debugger since process cannot load the jdwp agent.
12-16 17:16:50.972 4783 4783 D ProcessState: Binder ioctl to enable oneway spam detection failed: Invalid argument
12-16 17:16:50.990 4783 4783 D CompatibilityChangeReporter: Compat change id reported: 171979766; UID 10271; state: ENABLED
12-16 17:16:51.046 4783 4783 W mpanion.androi: Entry not found
12-16 17:16:51.047 4783 4783 W mpanion.androi: Entry not found
12-16 17:16:51.050 4783 4783 W mpanion.androi: JIT profile information will not be recorded: profile file does not exist.
12-16 17:16:51.055 4783 4783 V GraphicsEnvironment: ANGLE Developer option for 'io.homeassistant.companion.android' set to: 'default'
12-16 17:16:51.056 4783 4783 V GraphicsEnvironment: ANGLE GameManagerService for io.homeassistant.companion.android: false
12-16 17:16:51.057 4783 4783 V GraphicsEnvironment: Updatable production driver is not supported on the device.
12-16 17:16:51.058 4783 4783 D NetworkSecurityConfig: Using Network Security Config from resource network_security_config debugBuild: false
12-16 17:16:51.064 4783 4783 I FirebaseApp: Device unlocked: initializing all Firebase APIs for app [DEFAULT]
12-16 17:16:51.072 4783 4783 I FirebaseInitProvider: FirebaseApp initialization successful
12-16 17:16:51.073 4783 4783 D WM-WrkMgrInitializer: Initializing WorkManager with default configuration.
12-16 17:16:51.079 4783 4818 I DynamiteModule: Considering local module com.google.android.gms.measurement.dynamite:55 and remote module com.google.android.gms.measurement.dynamite:59
12-16 17:16:51.079 4783 4818 I DynamiteModule: Selected remote version of com.google.android.gms.measurement.dynamite, version >= 59
12-16 17:16:51.080 4783 4818 V DynamiteModule: Dynamite loader version >= 2, using loadModule2NoCrashUtils
12-16 17:16:51.080 4783 4783 D Sentry : io.sentry.auto-init read: false
12-16 17:16:51.080 4783 4783 I Sentry : Retrieving auto-init from AndroidManifest.xml
12-16 17:16:51.085 4783 4821 D CompatibilityChangeReporter: Compat change id reported: 160794467; UID 10271; state: ENABLED
12-16 17:16:51.088 4783 4818 W mpanion.androi: ClassLoaderContext type mismatch. expected=PCL, found=DLC (PCL[] | DLC[];PCL[/data/app/~~W4AnAvUVTUHY8OaRmuj2Sg==/io.homeassistant.companion.android-WYoyStYDuyxPr6Ff9dqI4g==/base.apk*1399441106:/data/app/~~W4AnAvUVTUHY8OaRmuj2Sg==/io.homeassistant.companion.android-WYoyStYDuyxPr6Ff9dqI4g==/base.apk!classes2.dex*3965918447:/data/app/~~W4AnAvUVTUHY8OaRmuj2Sg==/io.homeassistant.companion.android-WYoyStYDuyxPr6Ff9dqI4g==/base.apk!classes3.dex*1589194302:/data/app/~~W4AnAvUVTUHY8OaRmuj2Sg==/io.homeassistant.companion.android-WYoyStYDuyxPr6Ff9dqI4g==/base.apk!classes4.dex*3880881534])
12-16 17:16:51.106 4783 4841 D Sentry : SU isn't found on this Device.
12-16 17:16:51.105 4783 4783 W pool-13-thread-: type=1400 audit(0.0:2614): avc: denied { read } for name="version" dev="proc" ino=4026531958 scontext=u:r:untrusted_app:s0:c15,c257,c512,c768 tcontext=u:object_r:proc_version:s0 tclass=file permissive=0 app=io.homeassistant.companion.android
12-16 17:16:51.123 4783 4783 I WebViewFactory: Loading com.google.android.webview version 96.0.4664.104 (code 466410434)
12-16 17:16:51.143 4783 4783 I cr_WVCFactoryProvider: Loaded version=96.0.4664.104 minSdkVersion=29 isBundle=true multiprocess=true packageId=2
12-16 17:16:51.144 4783 4838 I FA : App measurement initialized, version: 50018
12-16 17:16:51.144 4783 4838 I FA : To enable debug logging run: adb shell setprop log.tag.FA VERBOSE
12-16 17:16:51.144 4783 4838 I FA : To enable faster debug mode event logging run:
12-16 17:16:51.144 4783 4838 I FA : adb shell setprop debug.firebase.analytics.app io.homeassistant.companion.android
12-16 17:16:51.151 4783 4783 I cr_LibraryLoader: Successfully loaded native library
12-16 17:16:51.151 4783 4783 I cr_CachingUmaRecorder: Flushed 7 samples from 7 histograms.
12-16 17:16:51.173 4783 4838 I FA : Tag Manager is not found and thus will not be used
12-16 17:16:51.180 4783 4783 W mpanion.androi: Accessing hidden method Landroid/content/res/Resources$Theme;->getKey()Landroid/content/res/Resources$ThemeKey; (max-target-o, reflection, denied)
12-16 17:16:51.192 4783 4839 I AdrenoGLES-0: QUALCOMM build : 4783c89, I46ff5fc46f
12-16 17:16:51.192 4783 4839 I AdrenoGLES-0: Build Date : 11/30/20
12-16 17:16:51.192 4783 4839 I AdrenoGLES-0: OpenGL ES Shader Compiler Version: EV031.31.04.01
12-16 17:16:51.192 4783 4839 I AdrenoGLES-0: Local Branch : QPR2
12-16 17:16:51.192 4783 4839 I AdrenoGLES-0: Remote Branch :
12-16 17:16:51.192 4783 4839 I AdrenoGLES-0: Reconstruct Branch :
12-16 17:16:51.192 4783 4839 I AdrenoGLES-0: Build Config : S P 10.0.4 AArch64
12-16 17:16:51.192 4783 4839 I AdrenoGLES-0: Driver Path : /vendor/lib64/egl/libGLESv2_adreno.so
12-16 17:16:51.192 4783 4839 D hw-ProcessState: Binder ioctl to enable oneway spam detection failed: Invalid argument
12-16 17:16:51.194 4783 4839 I AdrenoGLES-0: PFP: 0x016dd093, ME: 0x00000000
12-16 17:16:51.199 4783 4839 W AdrenoUtils: <ReadGpuID_from_sysfs:197>: Failed to open /sys/class/kgsl/kgsl-3d0/gpu_model
12-16 17:16:51.199 4783 4839 W AdrenoUtils: <ReadGpuID:221>: Failed to read chip ID from gpu_model. Fallback to use the GSL path
12-16 17:16:51.206 4783 4839 D hw-ProcessState: Binder ioctl to enable oneway spam detection failed: Invalid argument
12-16 17:16:51.216 4783 4783 D SensorReceiver: Sensor audio_sensor corresponding to received event android.media.RINGER_MODE_CHANGED is disabled, skipping sensors update
12-16 17:16:51.220 4783 4783 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:51.220 4783 4783 D UrlRepository: Using internal URL
12-16 17:16:51.225 4783 4783 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:51.227 4783 4826 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:51.239 4783 4825 D SensorWorker: Updating all Sensors.
12-16 17:16:51.241 4783 4834 I WM-Processor: Moving WorkSpec (a3694cc2-a97a-469d-92bf-678faae96bb3) to the foreground
12-16 17:16:51.259 4783 4918 D LocBroadcastReceiver: Registering for zone based location updates
12-16 17:16:51.261 4783 4918 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:51.307 4783 4824 D NextAlarm: No alarm is scheduled, sending unavailable
12-16 17:16:51.347 4783 4783 D CompatibilityChangeReporter: Compat change id reported: 171228096; UID 10271; state: ENABLED
12-16 17:16:51.350 4783 4824 D SensorReceiver: Nothing to update
12-16 17:16:51.362 4783 4824 D LocBroadcastReceiver: Registering for location updates.
12-16 17:16:51.371 4783 4825 D NextAlarm: No alarm is scheduled, sending unavailable
12-16 17:16:51.381 4783 4783 D RenderScript HIDL Adaptation: IRenderScriptDevice::getService()
12-16 17:16:51.390 4783 4825 D SensorReceiver: Nothing to update
12-16 17:16:51.391 4783 4821 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=a3694cc2-a97a-469d-92bf-678faae96bb3, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-16 17:16:51.408 4783 4783 D RenderScript HIDL Adaptation: IRenderScriptDevice::getService() returned 0xb4000076c9e30420
12-16 17:16:51.408 4783 4783 D RenderScript HIDL Adaptation: HIDL successfully loaded.
12-16 17:16:51.409 4783 5019 E RenderScript: Failed loading RS driver: dlopen failed: library "libRSDriver_adreno.so" not found
12-16 17:16:51.409 4783 5019 E RenderScript: Failed to load runtime libRSDriver_adreno.so, loading default
12-16 17:16:51.417 4783 4783 D mpanion.androi: Successfully queried cache dir: /data/user_de/0/io.homeassistant.companion.android/code_cache
12-16 17:16:51.417 4783 4783 D RenderScript: Setting cache dir: /data/user_de/0/io.homeassistant.companion.android/code_cache
12-16 17:16:51.421 4783 4783 I System.out: recordForce value 5
12-16 17:16:51.421 4783 4783 D WebviewActivity: Current webview package com.google.android.webview and version 96.0.4664.104
12-16 17:16:51.437 4783 4832 E WM-WorkerWrapper: Didn't find WorkSpec for id a3694cc2-a97a-469d-92bf-678faae96bb3
12-16 17:16:51.471 4783 4783 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-16 17:16:51.476 4783 4783 I WM-SystemFgDispatcher: Stopping foreground service
12-16 17:16:51.502 4783 4825 D SensorWorker: Updating all Sensors.
12-16 17:16:51.503 4783 4834 I WM-Processor: Moving WorkSpec (ee8b67da-b1c4-4859-9e51-82bb31609d4c) to the foreground
12-16 17:16:51.515 4783 4783 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
12-16 17:16:51.526 4783 4783 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
12-16 17:16:51.530 4783 4783 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-16 17:16:51.531 4783 4783 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:51.531 4783 4783 D UrlRepository: Using internal URL
12-16 17:16:51.567 4783 4783 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
12-16 17:16:51.587 4783 4825 D NextAlarm: No alarm is scheduled, sending unavailable
12-16 17:16:51.607 4783 4825 D SensorReceiver: Nothing to update
12-16 17:16:51.608 4783 4821 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=ee8b67da-b1c4-4859-9e51-82bb31609d4c, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-16 17:16:51.613 4783 4783 I WM-SystemFgDispatcher: Stopping foreground service
12-16 17:16:53.071 4783 4792 I mpanion.androi: Background young concurrent copying GC freed 172777(8789KB) AllocSpace objects, 58(1928KB) LOS objects, 93% free, 6651KB/102MB, paused 337us,47us total 103.261ms
12-16 17:16:53.688 4783 4783 D LocBroadcastReceiver: Received geofence update.
12-16 17:16:53.693 4783 4783 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:53.728 4783 4783 D LocBroadcastReceiver: Event sent to Home Assistant
12-16 17:16:53.729 4783 4783 D LocBroadcastReceiver: Last Location:
12-16 17:16:53.729 4783 4783 D LocBroadcastReceiver: Coords:(52.1051224, 5.1149872)
12-16 17:16:53.729 4783 4783 D LocBroadcastReceiver: Accuracy: 16.337
12-16 17:16:53.729 4783 4783 D LocBroadcastReceiver: Bearing: 117.47831
12-16 17:16:53.729 4783 4783 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
12-16 17:16:53.729 4783 4783 D LocBroadcastReceiver: Received location that is 2729 milliseconds old, 1639671411000 compared to 1639671413729 with source fused
12-16 17:16:53.733 4783 4825 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:53.772 4783 4825 D LocBroadcastReceiver: Location update sent successfully
12-16 17:16:54.441 4783 4783 D WebviewActivity: Authentication successful, unlocking app
12-16 17:16:54.473 4783 4783 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:54.474 4783 4783 D UrlRepository: Using internal URL
12-16 17:16:55.374 4783 4783 E WebviewActivity: onReceivedHttpError: errorCode: -2 url:http://<local hostname>:8123/?external_auth=1
12-16 17:16:55.378 4783 4783 D UrlRepository: localUrl is: true and usesInternalSsid is: true
12-16 17:16:58.741 4783 4839 D OpenGLRenderer: endAllActiveAnimators on 0xb400007759e4a610 (RippleDrawable) with handle 0xb400007669e3a230
12-16 17:16:58.769 4783 4783 D UrlRepository: Using external URL
12-16 17:16:58.770 4783 4783 D UrlRepository: Using internal URL
12-16 17:16:58.851 4783 4825 D SensorWorker: Updating all Sensors.
12-16 17:16:58.853 4783 4834 I WM-Processor: Moving WorkSpec (b347eea5-21e8-4ef3-941b-6a26740ebb0c) to the foreground
12-16 17:16:58.868 4783 4783 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-16 17:16:58.896 4783 4783 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
12-16 17:16:58.902 4783 4825 D NextAlarm: No alarm is scheduled, sending unavailable
12-16 17:16:58.912 4783 4825 D SensorReceiver: Nothing to update
12-16 17:16:58.913 4783 4837 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=b347eea5-21e8-4ef3-941b-6a26740ebb0c, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-16 17:16:58.914 4783 4783 I WM-SystemFgDispatcher: Stopping foreground service
12-16 17:17:05.026 4783 4825 D LogcatReader: Read logcat for pid 4783
12-16 17:17:05.062 4783 4825 D LogcatReader: Done reading logcat for pid 4783
12-16 17:17:51.042 4783 4783 D LocBroadcastReceiver: Received location update.
12-16 17:17:51.043 4783 4783 D LocBroadcastReceiver: Last Location:
12-16 17:17:51.043 4783 4783 D LocBroadcastReceiver: Coords:(52.1051224, 5.1149872)
12-16 17:17:51.043 4783 4783 D LocBroadcastReceiver: Accuracy: 16.337
12-16 17:17:51.043 4783 4783 D LocBroadcastReceiver: Bearing: 117.47831
12-16 17:17:51.043 4783 4783 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
12-16 17:17:51.043 4783 4783 D LocBroadcastReceiver: Received location that is 35 milliseconds old, 1639671471008 compared to 1639671471043 with source fused
12-16 17:17:51.044 4783 4783 D LocBroadcastReceiver: Duplicate location received, not sending to HA
12-16 17:17:51.059 4783 4783 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
12-16 17:18:06.591 4783 4783 D androidtc: Initializing SystemTextClassifier, type = System
12-16 17:18:06.593 4783 4783 W androidtc: TextClassifier called on main thread
12-16 17:18:06.594 4783 4783 D androidtc: Initializing SystemTextClassifier, type = System
12-16 17:18:07.203 4783 4783 W androidtc: TextClassifier called on main thread
12-16 17:18:07.292 4783 4783 I Choreographer: Skipped 31 frames! The application may be doing too much work on its main thread.
12-16 17:18:08.106 4783 4783 W androidtc: TextClassifier called on main thread
12-16 17:18:08.316 4783 4783 D androidtc: Initializing SystemTextClassifier, type = System
12-16 17:18:08.318 4783 4783 W androidtc: TextClassifier called on main thread
12-16 17:18:08.318 4783 4783 D androidtc: Initializing SystemTextClassifier, type = System
12-16 17:18:08.740 4783 4783 W androidtc: TextClassifier called on main thread
12-16 17:18:09.285 4783 4825 D LogcatReader: Read logcat for pid 4783
I’m also having trouble to get the HA Android app working correctly. I’ve set up everything to work with https enabled. If I connect to my instance via desktop computer on chromium everything works fine. Even when I connect locally to https://IP-ADDRESS:8123.
The only thing that makes me sick is the connection issue with the Android app. I can connect to my instance https://domain:8123 without any problems.
When the app is open I can see a message at the bottom of the screen “reconnecting” about 5 times then the connection gets killed and I only have the “Retry” screen. From then on a reconnection isn’t possible.
This works once after every re-installation of the app.
In my HA settings panel I can see an access token ist generated for every reconnection from the app and it seems to be a different IP Adress every time.
In my configuration.yaml the http-integration is set up to NOT use ip_ban!
That’s your problem right there. SSL certificate is not valid locally is only valid with the registered domain. The app does not bypass certificate errors or warnings.
OK, understand. But that doesn’t explain why on https://domain:8123 it’s disconnecting after about 30s.
I found a solution for my problem on Android:
I used Bromite WebView (an ungoogled WebView implementation) on my phone.
After switching to original Google WebView implementation the app doesn’t disconnect anymore and now works without interruption!
we have several closed bugs regarding Bromite alone. Unfortunately there is no easy way for the app to detect its usage as it masks itself as valid webview. Glad you figured it out.
can you tell me if it’s the same with Ungoogled Chromium WebView or Chromium WebView? I want to make use of an alternative WebView because my devices’ WebView Implementation is from April '19.
my tracert (or ping) command does not return IPv4 address, it returns something like [fe80::e91f:3da6:7f76:6d98]
i dont have much knowledge of network, hopefully someone can help
my android app (and ios app) is not working so far
I got the “Unable to connect to Home Assistant” on my Fire tablet and Samsung phone. I added the integration “local_ip” with the numerical ip address and then to access home assistant using the android app replace “homeassistant” with the numerical ip address. http://xxx.xxx.x.xx:8123 . It connects as it is supposed to.
interesting first I have heard of this resolution, do you happen to have the traceback for that error message? Might be worth adding a troubleshooting step in the docs.
I seem to have issues as well. First the versions and setup:
Home Assistant 2021.12.8 in Supervised version, authorization methods are default to homeassistant
Phone: Moto X4, with latest android for this device Android 9
Google Chrome is on the latest version 96.0.4664.104 and the WebView is configured to use Chrome, not the system wide one. I did not customize it, its default.
My connection to the home assistant work from browser internally on IP:8123 as well as externally via the domain name and free DNS on port 80.
The Android app can connect easily on the internal network and port. The problem starts when I get off WiFi and it wants to use the public domain. For some reason it wanted to connect to internal address first and threw the error Web page not available http://<local_ip>:8123 net: ERR_ADDRESS_UNREACHABLE
Ok so I closed the app cleared the cache. Wen opened the app, it no longer launched its window. Instead it went straight to the Google Chrome browser! and url. But even in browser it showed the “Unable to connect to Home Assistant with RETRY button.” I was like, what the heck ? I just verified that it works in browser. And then I saw the problem why app nor browser could connect.
It was trying to connect to https://<correct_public_domain>/lovelace?exteral_auth=1
This is wrong address and HA responds on with page of logo and RETRY option. But no redirect is happening. If I removed the parameters (just delete the /external_auth=1) and just refreshed that browser with main domain, it redirected to /auth/authorize?response_type=.... I tested that broken URL even on my desktop browser and sure enough that is never allowing access.
So for some reason, the app tries the URL that home assistant does not redirect properly and it gets stuck. I managed to get rid of the issue of opening the Google browser only by removing the app data, because something was caching it internally. That’s kind of poor user experience. So now I have working app again on internal network, but it can never resolve the login screen on external URL on my phone Maybe if it was trying to reach correct url, it would work like browser demonstrated. Browser works from any device and any network. It actually responds with 200 HTTP response, it may be that the websocket JS library issue or something, but responding 200 and saying it cannot connect is little bit an antipatern.
Every time it breaks on the external URL, the app stops working on internal as well and it redirects to external only via opening the Google Chrome window. So reset, remove data, register user again and it works on internal again. I must be careful not to open app outside of house. Also I cannot install it on my family phones cause there is no point.
The app never works outside of local. This has never resolved. App is useless outside of house … including its location as sensors cannot update. Where can I open the github issue for the app ?
I have exactly the same issue, with a Poco F3 and Android 11. Internally all fine, but externally no luck. It indeed keeps on requesting the internal IP outside the local Wifi, even though I have my external address configured. Never had this issue before, did something change?
This is correct per mobile app integration for authenticated webview
Your issue of opening google chrome is strange. what is your network setup like, are you using a proxy? You cant compare to a browser because a browser does not use authenticated webview nor does it make REST API calls or any other communication method that HA accepts. A lot of people are using internal and external URL properly. Try these network troubleshooting tips: Companion App Networking | Home Assistant Companion Docs
sorry we cannot solve failed to connect errors that lead to your own domain. Try to follow some of the outlined troubleshooting steps in the docs. There are network troubleshooting steps and also generic steps on another page.
Hi, thanks for the links, yes the services is behind reverse proxy configured the http2, HSTS and upgraded connection to pass WSS. seems to be all matching the docs when I checked
I looked at the logs from home assistant even at the core container level and there was nothing in there. So I checked the nginx logs and sure enough, home assistant is refusing websocket connection from the app: 2022/01/06 01:54:45 [error] 316#316: *91 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.0.1, server: <my_public_domain>, request: "GET /api/websocket HTTP/1.1", upstream: "http://192.168.0.18:8123/api/websocket", host: "<my_public_domain>"
The biggest issue is, I have no way to debug what headers or other metadata is the app sending, nor can’t tell why HA is refusing the connection, as HA did not log anything. not even an info. Is there other way to find some deeper debug logs ? Supervisor nor core container has any mention of connection even attempting…
As for the behavior that Google Chrome opens instead of the app, I cannot provide more details, because the logs are only accessible within the app itself, and if I can’t get to menu, then can’t see them. Developers may thing about providing some sort of access to logs without needing even to see the HA Companion app menu in future.
bypass everything here and do a straight connection…if it works then you know you have some configuration changes to make. What changes they are depends on your setup, only you can answer that.
That is what ADB logcat is for, otherwise apps only have access to things they post which is only allowed in their own app. Other logcat apps require special permissions to gain access to everything. Apps can only access their own data by default
