Hi all,
I tried android Web Cam component but sensors don’t work. Only switches and image view. Tested with the pro version and same result. In Web interface of the webcam in sensors page I see “No sensors are enabled. Enable sensors in IP Webcam settings to use this functionality. Note that motion detection sensor also requires motion detection enabled.”.
The sensors are enabled and I here beep on motion detected from the app.
EDIT: Fixed After enabled data logging everything is working now
Thank you! Everything started working when I enabled data logging in the app also.
