Thanks for this, also how do use this as trigger?
I need to turn on my tivo 4k stick when hdmi 3 is selected
TCL 98P74 LCD
HDMI 1:
service: androidtv.adb_command
command: >-
adb shell am start -a android.intent.action.VIEW -d
content://android.media.tv/passthrough/com.tcl.tvinput%2F.TvPassThroughService%2FHW15
entity_id: media_player.android_tv
hi. Thank you for sharing, Works great on my 848 as well.
This one changed my tcl c635 to tv program. So how do i find out the code to use for HDMI1 and HDMI2? thanks
Manage to find out myself. Post it here for those use TCL 43C635 TV
HDMI 1
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.passthrough.TvPassThroughService%2FHW1413744128
HDMI 2
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.passthrough.TvPassThroughService%2FHW1413744384
I’m struggling with this. I have the TCL C805 and the codes I’ve tried here only allow me to switch to HDMI1 (this is despite changing the HW reference at the end of the command for the other HDMI inputs).
Does anyone have a solution for TCL C805 on how to change source to HDMI 2, 3 & 4?
EDIT: Solution for my TV in my follow up post here
Hello again.
Now that this feature works nicely on my TV, I was wondering if I could implement one more with the help of ADB send command.
So, instead of using the remote control to go home_screen > Settings > System > Power & Energy > and lastly “Screen off”… could I just send a code?
This is what I see via the logcat, but I really don’t know how to convert this info into a command (if even possible):
02-24 09:59:44.687 1309 11400 D MtkLog : 8
02-24 09:59:44.687 1628 11402 D MtkLog : 8
02-24 09:59:44.688 1433 11403 D MtkLog : 8
02-24 09:59:44.700 3315 11406 D MtkLog : 8
02-24 09:59:44.806 1352 2070 D LogKeyEvent: : key=23,scan=353,src=3,sys=0
02-24 09:59:44.806 2073 3000 D TvPowerManagerService: scanCode = 353, src = 3
02-24 09:59:44.806 2073 3000 D TvInactivityTimer: mService android.os.Messenger@e873fb2
02-24 09:59:44.806 1352 2839 D DrvCustomNative: setInt
02-24 09:59:44.807 1352 2839 D DrvCustomNativeJni: <Java_org_droidtv_tv_drvcustom_DrvCustomNative_set:111> set: 2,1,1
02-24 09:59:44.806 1380 2676 D TPTvServiceAgent: ScreenOffGreenMute: false,false,23
02-24 09:59:44.807 546 546 D TPVDrvCustomService: <tpvdrvcust_hidl_set:44> type=2, value=1
02-24 09:59:44.807 546 546 D tpv_drv_cust_leds: <ir_blinking:132> ir_blinking called
02-24 09:59:44.807 546 809 D tpv_drv_cust_leds: <irLedService:40> irLedService IR blinking start...
02-24 09:59:44.808 2198 2198 D TvInactivitySvc: UserActivity
02-24 09:59:44.808 1352 2839 D DrvCustomNativeJni: <Java_org_droidtv_tv_drvcustom_DrvCustomNative_set:113> set: ret=0
02-24 09:59:44.808 546 809 D tpv_drv_cust_leds: <set:124> Set Leds ON/OFF. on_off=1
02-24 09:59:44.809 1681 1740 D candeebug.Gateway: Returning successfully for event: {"event-type":"unknown.15","boot-count":52,"standby-count":4,"kernel-time":47380912,"data":{"original-event-type":15,"device_name":1,"key_group":11,"rc_side":0,"ver":5}}
02-24 09:59:44.810 553 571 E FmsOledSaver: mark:0, logo:0, bmessage:0, #diff pix: 0, change:0, noClapse: 0, sSaving:0
02-24 09:59:44.810 553 571 E FmsOledSaver: sLevel:2, pMotion:0, bchange:0, noBClapse: 6, sDimming:0, ssFlag:0
02-24 09:59:44.909 546 809 D tpv_drv_cust_leds: <set:124> Set Leds ON/OFF. on_off=0
02-24 09:59:44.910 546 809 D tpv_drv_cust_leds: <set:124> Set Leds ON/OFF. on_off=0
02-24 09:59:44.910 546 809 D tpv_drv_cust_leds: <irLedService:56> irLedService IR blinking end...
02-24 09:59:44.918 1628 4305 I ImageStickingService: Amith keyCode23
02-24 09:59:44.918 1628 4305 D DreamerService: OnKeyPressed received:true
02-24 09:59:44.918 1628 4305 D DreamerService: isScreenSaverTriggered=0globalosdcount:0forceTrigger:0gResetCounter0
02-24 09:59:44.918 1628 1628 E DreamerService: SSS:false:null:null:false
02-24 09:59:44.920 1433 1433 D TpvPowerAndEnergyFragment: onPreferenceTreeClick() key = screen_off
02-24 09:59:44.920 1433 1433 I TpvPowerAndEnergyFragment: enterScreenOff()
02-24 09:59:44.920 1433 1433 D KeyInputDevImpl: set: 6,1
02-24 09:59:44.920 1433 1433 D KeyInputDevN: setCustomValue: 6:1
02-24 09:59:44.920 1433 1433 D KeyInputDevN: Get ksvc
02-24 09:59:44.921 1380 2530 D TPTvServiceAgent: POWER_SCREEN_OFF_UI: 1,false,false
02-24 09:59:44.921 1804 1952 D UsbBreakinService: POWER_SCREEN_OFF_UI: 1,false,false
02-24 09:59:44.922 1433 1433 D GtvNotificationManager: All GTV notifications are canceled
02-24 09:59:44.923 919 1073 W DevicePolicyManager: Unknown user type: UserInfo{10:new_user:1010}
02-24 09:59:44.929 919 919 I AlarmManager: Change Wakeup Alarm type to non Wakeup type, current type=[2] packageName = android statsTag = *walarm*:NotificationManagerService.TIMEOUT @91154029 and next wakeup alarm is @Sat Feb 24 20:41:02 GMT+01:00 2024
especially this part:
Any help/pointer is appreciated, thank you.
Hi all, I’ve worked out how to control HDMI Inputs and Home on TCL C805 TV (TCL 75C805 / TCL 75C805K in my case).
HDMI 1
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.TvPassThroughService%2FHW15
HDMI 2
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.TvPassThroughService%2FHW16
HDMI 3
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.TvPassThroughService%2FHW17
HDMI 4
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.TvPassThroughService%2FHW18
Home screen (Google TV Home screen)
am start -a android.intent.action.MAIN -c android.intent.category.HOME
Anyone knows how to change to Cable or Antenna input from HDMI?
Thanks! Works for TCL 75C849
anyone get this to work for an xgimi? I have a horizon pro and I can get the hdmi to switch using the terminal from my pc, but not from homeassistant using that exact same command using androidtv_adb.command.
there is no error I can see using the dev tools for this service call.
this is what I am trying to use and I have verified that the home assistant machine has been allowed to run adb commands.
command: >-
am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.xgimi.tvinput%2F.inputservice.Hdmi2TvInputService%2FHW2
entity_id: media_player.android_tv_192_168_20_166```
I was in here looking for how to do this exact same thing on the exact same hardware! Just wondering, did you have any luck since posting on how to get the XGIMI Horizon Ultra to switch Hdmi inputs using ADB commands?
(I’m a relative noob to scripting stuff, just hoping to overcome the limitation of the remote which doesn’t have a dedicated input change button on it)
Hi Jakub,
I never did work out how to get the XGIMI Horizon Ultra to switch Hdmi inputs using ADB commands. I feel like it should be possible in theory, but in practise nothing I tried worked. I’d be happy to know if someone had more success.
Matthew
How do i use this? What command do i need to use? And where to execute it?
Just for anyone who happens to need it (including me in a month when I forget and need to do it again), this is the command for a TCL C855 HDMI1:
I have a weird problem. On my TCL tv, if I use the correct HDMI command above it does change input no problem. However, if I manually change the input (using remote) it does NOT update ADB at all meaning that they are not in sync. Any solution? Thanks
I was unable to find a reliable way to change the input to HDMI 1 on my TCL 65QM850G Google TV using an adb shell
command with the Android Debug Bridge integration in Home Assistant.
I was able to control many other TV features using it, but just not change the TV’s input to HDMI 1.
So I regressed to just simulating remote key-presses using HA’s Android TV Remote integration.
Fortunately, the TCL/Google TV input selector doesn’t allow “wrapping around”, so my script sends left
one time more than the total number of input options displayed, which leaves it at the far left end.
Then I send right
once to land on Input HDMI 1
. Your counts will likely vary.
Here’s my UI-generated yaml
as copied from scripts.yaml
living_room_tv_hdmi_1:
alias: Living room TV HDMI 1
- action: remote.send_command
entity_id: remote.living_room_tv
command: HOME
metadata: {}
command: F3
metadata: {}
num_repeats: 5
command: DPAD_LEFT
metadata: {}
command: DPAD_RIGHT
metadata: {}
command: ENTER
icon: mdi:television
Sadly neither did I, it’s a real pitty because all the software tech is there without needing to go any other router (like using HDMI-CEC or) but we’re missing a way to know what message to type.
Incidentally, I did look into a different way to switch ports better via installing a different launcher software that removes the bloat of all those adds. But sadly that too had issues pinging the hardware to change hdmi ports.
работает на TCL 85P737. Спасибо!
action: androidtv.adb_command
command: “am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.passthroughinput.TvPassThroughService%2FHW1413744128”
entity_id: media_player.android_tv_192_168_199_11
HDMI1
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.passthroughinput.TvPassThroughService%2FHW1413744128
HDMI2
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.passthroughinput.TvPassThroughService%2FHW1413744384
HDMI3
adb shell am start -a android.intent.action.VIEW -d content://android.media.tv/passthrough/com.tcl.tvinput%2F.passthroughinput.TvPassThroughService%2FHW1413744640
HDMI4 - у меня нет
I am in the same situation with a TCL 65C845 (Android 12). Sending HDMI key codes does not work and I began the ADB journey but noted that some streaming applications had problems with logging in when in debug mode. I will try to pinpoint if that really is the case or if it was a temporary glitch, but can it indeed be the case that applications know when debug mode is on?
Anyhow, I found another potential solution that seems to work for my TV set. The Android TV application Go to HDMI1 input by mpiero actually works! He (assuming here…) has corresponding applications for switching to other inputs as well, but many of them cost money, smart move ! I use the following card snippet then:
tap_action:
action: perform-action
perform_action: remote.turn_on
activity: com.mpiero.android.tvhdmi1
entity_id: remote.smart_tv_pro
I’m not sure how this app is implemented. Could there be a general API in Android TV for controlling video sources? This then begs the question whether a backend app for Android TV and home assistant extended control could then be developed!
