A few minor fixes and additions - most important is AppDaemon now supports PyPi installation to make things a lot simpler! No more need to use git and pull repositories, just a simple pip command is all you need to install and upgrade
So, if you are currently running appdaemon v1 or v2 (not the beta), all you should need to do is:
$ pip3 install appdaemon --upgrade
This should be run as the user you installed the original with, and you may need to use sudo depending on whether or not you did for the first install.
2.0.4
Features
AppDaemon is now on PyPi - no more need to use git for installs
Allow time_zone directive in appdaemon.cfg to override hass supplied time zone
Add API calls to return info on schedule table and callbacks (get_scheduler_entries(), get_callback_entries())
Add get_tracker_details()
Add sub entity to sensor
Add hass_disconnected event and allow Apps to run while HASS is disconnected
Fixes
Fix startup examples to match new -c semantics and add in docs
Fix Time Travel
Fix for crashes on HASS restart if apps weren’t in use - contributed by shprota
Attempted a fix for NaN showing for Nest & Ecobee thermostats when in auto mode
Follow the docs in the repository, linked from the docs page on the hass website. AppDaemon and HADashboard are all contained in the same package, so yes, do the pip install then it’s just configuration.
Just diving into setting up Appdaemon in order to venture towards Dashboards.
Seems like it went fairly well, but seems like I am getting a dependency warning, should I be concerned with this before moving forward?
appdaemon -c /home/homeassistant/appdaemon/conf
/usr/local/lib/python3.4/dist-packages/requests/init.py:80: RequestsDependencyWarning: urllib3 (1.21.1) or chardet (2.3.0) doesn’t match a supported version!
RequestsDependencyWarning)
2017-07-18 22:19:36.274409 INFO AppDaemon Version 2.0.5 starting
2017-07-18 22:19:36.274915 INFO Configuration read from: /home/homeassistant/appdaemon/conf/appdaemon.yaml
2017-07-18 22:19:36.480548 INFO Got initial state
2017-07-18 22:19:36.481734 INFO Loading Module: /home/homeassistant/appdaemon/conf/apps/hello.py
2017-07-18 22:19:36.484143 INFO Loading Object hello_world using class HelloWorld from module hello
2017-07-18 22:19:36.623711 INFO hello_world: Hello from AppDaemon
2017-07-18 22:19:36.626871 INFO hello_world: You are now ready to run Apps!
2017-07-18 22:19:36.627705 INFO App initialization complete
2017-07-18 22:19:36.628513 INFO Dashboards are disabled
2017-07-18 22:19:36.639872 INFO Connected to Home Assistant 0.49.0
I’ve run in to a problem with appdaemon 2.0.5. I get the following on the Javascript console whilst loading a dashboard:
jquery-3.1.1.min.js:2 Uncaught ReferenceError: Unable to process binding "text: function (){return state_text }"
Message: state_text is not defined
at text (eval at parseBindingsString (knockout-3.4.1.js:68), <anonymous>:3:57)
at update (knockout-3.4.1.js:98)
at function.a.B.i (knockout-3.4.1.js:72)
at Function.Qc (knockout-3.4.1.js:51)
at Function.Rc (knockout-3.4.1.js:51)
at Function.aa (knockout-3.4.1.js:50)
at Object.a.m.a.B (knockout-3.4.1.js:49)
at knockout-3.4.1.js:72
at Object.q (knockout-3.4.1.js:11)
at m (knockout-3.4.1.js:71)
This is in Chrome, similar error in Firefox. I am pretty sure I haven’t changed any of my dashboard config since recently updating from repo install to PiPy install. I run appdaemon in a venv, so I also tried installing from a fresh venv dir, but alas same error. I’m running Python 3.5.3.
Same here,
I just installed fresh from the latest git version because I created a docker container from it for the raspberry pi.
The base image is resin/raspberrypi-python:3.6.
When opening the example “Hello” dashboard, it does not load (only a black screen with a grey square). The chrome developer console shows the error above.
